three point grapple skidder
Started by moosehunter, June 28, 2005, 01:23:28 PM
moosehunter
Any one using a three point grapple on a 35-50 hp tractor?? I am skidding LOTS of 5-10 inch red pines and am tire of climbing on & off the tractor.
Anyone want to rent me one????? ;D ;D
Moosehunter
Higher than my expectations
moosehunter
Saw this site has an interesting 3pt grapple (look under log skidders).
http://www.logsplitters-ironoak.com/index.php
Bro. Noble
I think there was a post some while back where someone made one of those.  I been thinking about it.
moosehunter
Thanks beenthere, I found that link doing a search but it wouldn't connect. Your link worked.
$3195  :o :o :o
Probubly worth every penny. I ain't got that many pennys to spare!
Bro. Noble, I have not found the thread on building one with a search, ifn ya find it, let me know.
mh
Bro. Noble
/There was a picture of it on the random photos.  It was yellow.  Maybe someone can tell us about it.
There are a few 3pt attachments on this CAD plan site, that may give some ideas.
http://www.cadplans.com/
Seems to me something between the 'grapple' and the simple logging tongs would (could) (might) be made to work. :)
If we could get Cowboy Bob to teach us how to 'lasso' a log from the seat without getting off, and then reel them in (aha - EZ knows how to do that), we'd be half way there.  ;D
maple flats
Not sure i've seen a 20 horse tractor even with weight on the front that could pick much of a log that fer behind the tractor. I have a 20 hp ford compact deisel and can lift and pull a good size log but it is with a 3 point arch and the butt ewnd of the log is meer inches behind the draw bar and even then I need to run a second chain from the log to the drawbar or I just drive out from under the load. (not good!) I think that would need something more like 30 or 35 horse minimum because just lifting is not the problem, you then need to drive with the load.
ironmule2004
I have a 3-point Grapple that I use.  I use it behind an 80hp but a smaller machine would be ok for it.  That one make by iron-oak looks weak!
Do you have a pic of your 3pt grapple?  Or a name/site where we can take a look at it?   :)
Arthur
Doublecut have a self contained one that can be towed behind anything.  Give him a call im sure the price is a lot less than what you have so far and isnt just for a tractor.
Murf
I got halfway thru' buildin' one and stopped to use it as is an' still haven't finished it.
I used the frame of an old 3pth rear grader blade, the blade had been bent up bad an broke thru in a few spots. Got it at the county recycling yard .....  ;) .... the place some people call 'the dump'.
I had to make a new top  for the 3pth cause the old one was bent to bad to be trusted. Where the blade used to swivel I made a swivel plug and just hung tongs, I intended to make a hydraulic grapple, but needed logs moved before time allowed for buildin' em.
It works well, especially with a hydraulic toplink. I can snatch a log off the ground no problem, if it goes along with my wishes I don't even have to leave the seat.  :D
Look around for an old blade an get busy .......  ;D
Kleek
I use a Nokka brand 3 pt grapple behind a 5320 4x4 John Deere.  It is a very impressive unit.  Saves a lot of time, also works good to safely pull down trees which have been hung up when felling in the woods.
BW_Williams
I built one using a back blade frame and a Valby grapple, worked great behind my TO-35 for a post and pole cut I did in a tight wood lot.  Here's the one I used,
http://www.valbysales.com/newpage111.htm,
I didn't use the rotator, because of lift height limit of the 3 pt., it would let the pole spin if needed to get out to the landing.  Next time I have it on the tractor, I'll try to take a pic of it.  BWW
Support your local Volunteer Fire Dept.  (not by accident)
Support your local Ski Patrol (by snowboarding:)
Mayor of Millerdale, Washington, USA (by God)!
ironmule2004
I will try to post a pick of my grapples.
mike_van
northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company [hydraulics]  has one in their latest catalog - 700 lbs. & 3000.00.   Also one for a skidsteer.
