valve adjustment
Started by deadeye, May 12, 2005, 11:45:33 AM
deadeye
has anyone got a idea on how to adjust the valves on a onan 24 hp  or know where i can find out online?
sparks
If you give me a fax number I can fax you the pages from the manual.   Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
deadeye
fax number is 450 247 3699 ,  the motor seems to be making a popping in the carb?
KILROY
  Deadeye,
If you have not done so already, try cleaning the carburetor. Water and dirt can collect in the bottom of the carburetor.
Grawulf
And if it has an inline fuel filter, replace or blow it out backward - I have a 20 horse Vanguard that does the same when the filter gets coated.
