your ideas on fence post treatment
Started by Buzz-sawyer, April 28, 2005, 12:57:26 PM
Buzz-sawyer
They still sell penta and creosote post here.....just not the stuff to do it yourself...........I would get a licencse to do it if economical.....
Kirk Your on I will give ya a call. ;)
    HEAR THAT BLADE SING!
etat
I remember buying creosote by the gallon and mixing it with diesel fuel.  Nasty stuff but I wouldn't mind having a couple a gallons around if I could still get it.
Wanna know what's really miserable.  Tear off a OLD pitch flat roof.  Creosote and tar mixed together.  I haven't been aholt of one in several years, mostly they're all gone now.  Number one rule, don't touch your face.  Don't wipe your face.  If it gets dusty with that pitch, leave it alone.  Until you can get to soap and water.  I once saw a boy go blind by dinner, not kidding.  He kept rubbing his face with his gloves.  It just rubs the pitch in deeper and by dinner his eyes were swole shut.
I was working for someone else then.  They didn't care but I took him at dinner and bought a bottle of dishwashing liquid.  Had him wash his hands good, and then fill em with dishwash and take it straight to his face and eyes.  And then I had him do it again, and again until we went through the whole bottle.  He was crying, but by the end of dinner he could see, sorta.  I told him 'no authority to do so' to take the rest of the day off and go home and keep potato peelings on his eyes to pull the heat out.
I would of bet anything that anybody wanted to bet that he wouldn't be back at work the next day, but he was.  But he didn't touch his face or rub his eyes with them dusty pitch gloves.
Rod
Rod
this stuff might work to
Link
Application
Above Ground Contact:
The best results will be obtained if wood to be treated is immersed for 3 minutes or longer.
If dipping is not possible, 2 brush coats, roller, or spray applications should be applied.
Allow at least 1 hour between applications.
Make certain all areas are fully treated to get the maximum benefits.
Allow 24 hours or longer after application of the preservative prior to painting.
Ground Contact:
Seasoned or green wood may be treated.
Make certain the wood is free of bark, then immerse in Dock & Fence Post Preservative for 12 to 48 hours or until the sapwood is completely penetrated.
Coverage
One gallon covers 100 - 300 sq. ft. depending upon the wood species, porosity of wood, and method of application.
rebocardo
On large sticks (4x4 or 6x6) I like a bed of gravel, stick in the post, then pour cement around it, then cap the post with plastic. I use plastic covers for electrical boxes (from Home Depot) because they are cheap and quick to install with one deck screw on each side to hold the cover to the post. The cement should be sloped and higher then the ground around it so the water does not pool around the base of the post.
For a mile of fencing, what seems to work in GA, is people stick the poles into a bucket of roofing tar and then set that into the ground and pack the hole with dirt.
KiwiCharlie
Id go for the western red cedar - Ive just started working with it and its light, easy to handle, and lasts!  What more do you want!!  :D ;)
Oh yeah - it smells great too!  :D
Cheers
Charlie.
Walk tall and carry a big Stihl.
How about yellow cedar/cypress......smell that aroma (peeled carrots)....sniffffff...and even more resilient than red cedar. It's probably expensive though. Most of the market for it in BC is for Asia I think.
QuoteYellow cedar's natural decay resistance makes it a popular material for sills (dodai) in both post and beam and 2x4 construction (20 % Asian Market). Six foot sorts and lower grade material go to sills or laminated sills. The most common yellow cedar sill material is solid-sawn, and undried and generally milled into 105mm x 105, and 120mm x 120mm squares. Competition in the sill market comes from treated hemlock, treated Japanese cedar (sugi), and increasingly from laminated radiata pine (LVL) and laminated whitewoods. In spite of the competition, yellow
cedar has been gaining market share in the sill market and this has been partly attributed to its natural decay resistance, which makes the use of toxic preservatives unneccesary.
Original Document
maple flats
I heard once that black locust posts with no treatment were still holding gates up in England after 150 years in the ground. Try looking further into black locust if you can.
wiam
Here is my post treatment.  White cedar 3 x 3.
Will
Buzz-sawyer
Rod
Thanks for the link to the forestry service link seems like a good possibilty ;)
Buzz-sawyer
The forestry report mentioned only SOME hardwoods take this type of treatment...any one been down this path? Which hardwoods take treatment best???
Rockn H
Buzz-Sawyer, I'm no expert, but I'm in the same boat you are.  I need to treat some post.  From a question I asked in Drying and Processing, I would say that your white oaks would not do well because of their closed cell structure.
I need someone to tell me if I'm wrong, probably am but here goes.  In Rod's second post the product contains Naphthenic acid an accelerant used in hardening paint?  Could something like mineral spirits be substituted?  The other main ingredient is Copper salt.  Is this not the same as Copper sulfate which has been mentioned already in this post.  I'm trying to figure out if the product could be roughly duplicated or if it's not what more or less keeps coming up as a means to treat wood.  I'm starting to think Copper sulfate is a good way to go I just like 2nd, 3rd , 4th oppinions. ;D
Quote from: Buzz-sawyer on April 30, 2005, 10:10:27 PM
Rod
dido ;D
Rod
this link leads to a company that makes the Naphthenic acid stuff to treat wood.I called home depot and they don't have noting for treating wood they said.
http://www.merichem.com/COPPER/Main.HTM
Rod
and here is how long the post lasted with all the different ways to treat fence post
http://fcg.cof.orst.edu/rc/rc26.pdf
wiam
Rod said "I called home depot and they don't have noting for treating wood they said."
I called Home Depot and asked if they had orange construction fence.  "Nope, don't have it.  Never heard of it." I went in for someting else next day and found about 30 rolls. ::) ::)
Will
wiam,
That's just exactly what I run into 'sometimes'. Employees with no clue.  ::)
Buzz-sawyer
Well I took the good advice and looked into geting a private applicators license, and found out it costs 15 buck........I take the test next thursday in Springfield. I can then purchase and use on my farm ANY RESTRICTE USE pesticide, including creosote, penta , CCA , AND any of the good pesticides..I feel good , because now, I found out the rights I thought I had lost.....they are STILL there I just have to pay for them.
Buzz,
They done the same up here. And if ya buy the consumer products at the hardware store there is 10 times mark-up for 500 ml.  Go get round-up at the agri-mart and for $35 I can get 10 times the amount. So what does a certificate proove, that I can read and write maybe?? ::)
Actually that says a lot now days SD!  :D
Kirk_Allen
Hey Buzz,
Check out this site:
http://www.cedar-vadek.co.za/catalog/index.php?cPath=30&osCsid=d590b2bc5ef03cd3cfe7d0599cae825f
They have Creasote listed as being available.
Also you might check on Carbolinium.  Its on the same site.
My dad uses it for fence posts and fence boards.  Most of the first posts he put in the ground 20 years ago are fine.  Out of over 300 posts he has about 10-15 that have rotted.
Buzz-sawyer
UNCLEBUCK
The private applicators license I found has more to do with safety than anything else and disposal .
Rod
Looks lke from the test Creosote worked the best on any kind of wood.I guess that must be the reason they still use Creosote on RR ties.
hey also said
The pressure-treated test posts were produced commercially. Commercialtreatments offer the widest selection of preservatives and can result in a product having excellent durability. Modern preservatives used by commercial plantsare now more effective than some early formulations that leached more easilyfrom treated wood. Use of less effective zinc meta-arsenite and chromatedzinc chloride (series 33, 43) has been discontinued. Average life of most seriesof pressure-treated posts in the tests should exceed 40 yr. Square-sawed postsof western hemlock treated with aqueous solutions of Chemonite or Tanalithare expected to last longer than similar posts of Douglas-fir. Some series of creosoted posts (series 7, 23) have lasted for 67 yr without failure., ORPermit No. 200
Buzz-sawyer
Well its official I am Certified in Illinois to use GOOD wood preservatives...the ones that work....
Got the booklet and paid my money and took the test....license is in the mail :D :D :D :D :D :D
