your ideas on fence post treatment
Started by Buzz-sawyer, April 28, 2005, 12:57:26 PM
Buzz-sawyer
Any suggestions on where to get penta...or any treatment that will actually work on posts?
I am building  about a mile of fence and have the means and patience to treat cut posts....
Problem is the Government is making it difficult to go to the farm store and BUY something that works.........ANY home made recipes of stuff that works on the farm???
    HEAR THAT BLADE SING!
J_T
How about that stuff they use on RR tyes ??? Get you two big tanks one that you can seal the end on put a presher gauge on it pump fluid out the other tank seal and light a fire under it and build up some presher use a pre set reliefe valve . Then drive to my house and we'll watch the 6 oclock news together :D :D
Jim Holloway
Cedarman
Illinois is between Mo and In.  Both states have some good cedar posts. Good red ones don't need treated.
What kind of posts are you wanting to treat?
I like the cedar idea also. Up here no one would consider using anything but cedar and them posts last for years. They used to use them on rail fences here between properties and they could be found and retraced over a 100 years after being installed.  :) Unfortunately, they became kindling wood for the stove when I was young.  :-\
Buzz-sawyer
Cedarman
We have very little erc here, we have osage and black locust. I dont have any erc, osage or black locust. I do have lots mixed hardwoods that I can cut to dimension on my mill for free...hence the need for economical treatment .if there is such a thing anymore. :( >:( :D
Kirk_Allen
Buzz, how many posts are you needing.
I have to find out some more on the Black Locust trees the farmer is giving me but I bet we could cut almost all you need from Osage. It may take a few days to logg them and cut them but its possible.  Im cheap!  Food and blades:)
Cedarman
Kirk, I need beau coup black locust posts between 3" and 5" small end and a little over 8' long.  Can pick up.  Need ASAP  Anyone else got any?  Need about 500 to 600 all together.
Buzz-sawyer
Kirk
i have been thinkin on commin over and helpin you out with you work any how...sound like we may work some fun out of it ...Could bring along a rifle and do some tack driving to (not with mine) :D :D :D
Ironwood
Some old timers say to char the ends. I would follow that up with diesel/oil and than avoid sealing the bottom....ie no concrete on the bottom just gravel , if'in you need to crete them do a ring at he top. We use alot of Locust here as well. Reid
etat
Agree on the concrete part.  It'll trap moisture around the base of the post and rot it lots quicker.
Around here a locust will last a lot longer than a cedar post.
Cedarman
Peel them and char the bottom 3 or 4 feet. What the pioneers did.
Jason_WI
My grandpa soaked cedar fence posts in a wood barrel of saturated copper sulfate solution till the ends sticking out turned blue. You can get copper sulfate in 50# bags at any ag supply store. It is corrosive so use a plastic barrel if you try it.
Most of these posts are still solid after 50 years in the ground.
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
Cedarman
What is that much copper sulfate used for?
etat
Suppliment needed to add to fertilizer for some pasture ground for beef cows.
Rod
I don'tknow if anyone said this or not.But you can but the post in a 55 gal drum filled with used motor oil and leve them in the oil for about 30 days.Then on the fence boards and the part of the post that didn't get oil you can spray or brush the oil on the rest of the fence.
The fence will last about 30 or more years
hiya
One time I put some white oak post in a barrow of 1/2 used motor oil and 1/2 creasoat. Took a 55 gal. drum filled it with post then put in oil-creasoat, lit a fire under it to cook out the water,then let it set a few days. The only thing is I moved to another state so I don,t know how well it worked.
Richard
RichardinMd.
Buzz-sawyer
hiya
If I could get some creosote...that would be the end of my search ;)
Frank_Pender
You can give these folks a call in Portland, Oregon; 1-888-888-6095.  The have a wood preservative that is approved by all government agencies and then some.
  However, If you want to save dollars and no time you can split your White Oak (heart only) build an large fire with the limbs sand char the posts to the p[oint of almost on fire.
   I have posts on this tree farm that were installed after such treatmene that are sitll solid and were planted 75 years ago.   8)
pigman
Quote from: Cedarman on April 28, 2005, 07:44:34 PM
When I was in the pig business, I bought 50 lbs at a time to put in my farm pond to control algae. The algea would stop up the filters in the water system.
Jason_WI
We use copper sulfate on cows with hoof rot. Dig down to the abcess with a hoof knive then pack with copper sulfate. It is a fungicide.
Jason
wiam
Jason beat me to it .  It is also used in foot baths for cattle.
Will
Ernie
I found when treating sheep and goat feet for foot rot, that melted petroleum jelly with coppersulfate and some old expired powdered antibiotics like tetramyicyn (spelling) worked into the trimmed feet worked perfectly as it tended to stick well.
We had over 1500 saanen milking goats as a recipient herd for our angora goat embryo transplant programme and our damp paddocks were a real problem for the feet.  We also put them through weekly footbaths with stones in the bottom for spreading the hooves and alternating weekly between copper and zinc sulphate was very effective.
Sure is great to be making sawdust instead 8) 8) 8) 8) 8)
UNCLEBUCK
In Minnesota for about 30$ you can take the private pesticide applicators test , it comes through the us mail and a book to read and the test with the answers to be found throughout the book . The license is good for 3 years and then go to a farm/fertilizer place and they will order just about anything you need if the state allows and the list of chemicals that can be purchased is huge . Must be the same type of deal in other states happening
Buzz-sawyer
Has anyone ever used coppersulfate on mixed hardwoods.................... ???
Kirk_Allen
Quote from: Buzz-sawyer on April 28, 2005, 06:08:26 PM
Kirk
Buzz your welcome anytime!  I have several Osage to fell and/or skid out of the woods but not sure if we would get near a mile of fence posts.
How close you going to place them to each other.  Boards between or wire?
Guns are good.  Always bring guns....................................but then again we may not get any work done if got more guns ;D
