Electric brake controller
Started by Junior437t, April 20, 2005, 09:13:09 PM
Junior437t
I am looking at putting a trailer brake controller on my truck. I have been told that it makes it better when pulling a trailer. Seems like there are a million to pick from.  Mainly it looks like there are Solid state and pendulum styles. The only trailer I would be pulling with electric brakes is my Woodmizer.  Looking for suggestions. Pros and cons of each. I searched the archive and could not find anything on this. Thank
bitternut
I did some research on them and ended up buying a tekonsha prodigy. I have a 2002 chevy 2500HD and it plugged right in to a socket under the dash. It was one of the easiest hook ups I have ever done. If you have a later model truck I am sure they have a plug for your truck or suv.
I built a 6 x 12 single axle trailer for hauling firewood home and the first load with it showed me I needed brakes on the trailer. When I got home with the load the first thing I did was order 10" electric brakes, backer plates,  new hubs and a brake controller. The brakes work great. Stopping is real easy and the controller is real simple to use.
I am like everyone else with a trailer. You always seem to pile a little more on and pretty soon you are way overloaded. It handles a full cord of split green beech, sugar maple, ironwood and black birch like the trailer is empty.
Stump Jumper
i have the prodigy as well and it is great it has 3boost levels and a gain control for adjusting to different trailers and loads
Brucer
Solid state:
  • Trailer brakes are applied whenever you step on the brake pedal.
  • If you touch the brake pedal lightly, you can apply the trailer brake without applying the truck brakes. Nice if your trailer starts to sway, but that's not likely with a Wood-Mizer.
  • Trailer brakes work even if your truck loses its brakes.
  • Simple to wire up.
  • If your brake light switch fails, or the brake light circuit fuse blows, you've got no trailer brakes.
Pendulum/inertia:
  • Trailer brakes are applied whenever your truck is pointed downhill.
  • Trailer brakes are applied whenever your truck slows down.
  • If your truck's brake light circuit fails, the trailer brakes will still work.
  • Even simpler to wire up.
  • You have to make sure the controller is mounted level (or make adjustments).
  • If your truck's brakes fail, the trailer brakes won't come on except when you're going downhill.
  • If you're trying to back your trailer up hill, the trailer brakes will come on ('cause the trucks pointed downhill). You might find a controller that will disable the trailer brakes when the truck is in reverse, but that complicates the wiring.
Personally I chose the solid state design because I want the trailer brakes to come on when I actually press the brake pedal. I bought a very basic generic unit from a well-know auto parts chain. I figured they wouldn't be selling trash.
Bruce    LT40HDG28 bandsaw
ScottAR
Check out Brakesmart.  Measures master cylinder pressure.  More brake pedal, more trailer brake.   Kinda expensive...  HTH
Scott
[Magicman]
