Where do I find a logscale?
Started by RacinRex, April 19, 2005, 11:04:30 AM
RacinRex
I hadn't had anybody ask until today. They have some logs and want an estimate on what I'd charge to cut them. If I have a set price / bdft then I should be able to give a fairly good estimate by scaling the logs, correct? Is there a sheet somewhere that tells me what volume is in a log of a certian diameter... better yet haven't I seen guys running around a header with some kind of cheater stick? Where would I get something like that?
81 Massey Ferguson 275 W/ loader
Stihl 046
Simplicity Bandmill
04 Dodge 2500 4x4 Quad Cab CTD
A whole shop full of wood working tools
and this is my hobby :)
Use the Int'l 1/4" log scale (in the Forum toolbox, click on Forum Extras at the upper right) to get a good estimate of the bf volume in your logs, using the scaling (small end) diameter and log length.
The 'stick' you speak of (isn't for cheating  :D ) is likely a log scale stick, and will have the bf volume by log lengths (diameter by placing the stick on the small end) shown. Available from forestry suppliers. Bailey's (a sponsor) has a scale stick, and they are easy to use.
http://www.baileys-online.com/store/USA.htm
under Log/Lumber Grading tools
GF
If you want to print one out to give out I have one on http://www.twistedoaksawmill.com select the log scale link, it 356K big so if you dial up it might take a few minutes.
Bibbyman
Wood-Mizer prints log and lumber scale on the blade shield.   ::)
If you don't want to go out and get a Wood-Mizer,  then they also have a handy pocket scale that they often give away at shows and demos, etc.
You can also get one through their on-line store for .60 cents.
http://www.woodmizer.com/en/store/index.aspx?pcatID=3
Sawing since '94
RacinRex
And the forestry forum is champion, AGAIN!!!
I found out how to save that sawlogs calc right to my PDA so now I have all three scales right there in my hand when I go to visit a customer. Easier to do estimates with that and a yard stick...
Thanks again.
Stihl 046
Simplicity Bandmill
Bibbyman
Just remember - buy by Doyle,  sale by International! :D
Sawing since '94
GF
Sounds like Bibbyman has that scale all figured out. :D
tnlogger
GF pro sawyer Marys got it figgered out  :D :D bibbys just the gofer  :D :D :D :D :D ;D
sorry bib just couldn't help it ;D
gene
I was thinking the same thing about them scales. If ya got large wood, 14 " top and up there isn't as wide a margin.
Bib, ya have an eye for salesmanship :D
Rockn H
If you want to make yourself a cruising stick (biltmore stick) for determining board feet in a standing log here are a few sites to check out.
http://www.tree-tech.com/reports/biltmore_stick.xhtml
http://www.kbs.msu.edu/Extension/marketing/Tree_volume.html
http://extension.usu.edu/forestry/Management/BiltmoreStick.htm
        http://forestry.about.com/gi/dynamic/offsite.htm?site=http://www.cnr.berkeley.edu/departments/espm/extension/TREESTK.HTM
Russ
Go to the equipment  show in Bangor  and you can get a log stick for free.
Pre Register >>>>http://www.nefpexpo.com/<<<< CLICK HERE
