Vacuum dryer a contact method??????
Started by serg, April 11, 2005, 11:19:01 AM
serg
Hello! Russian factory has made flexible heating plates, they work than aluminium as silicone maintains a lot of time than aluminium better!
I have made experiment. Each lining has laid silicone (temperature of 67 degrees), has created vacuum 0.095, or 0.3 residual pressure 130 м a mercury column. Boards made in America to a tape power-saw bench. The big wave. Contact is not present. I have put 45 mm-70мм, thickness of a board.. Accident Has turned out! That it is possible to make, for good contact. The power-saw bench saws плох. Or each board to carry out(spend) through a surface gauge?  ???Sergey.
