attic drying
Started by wooddog, March 24, 2005, 10:25:18 PM
wooddog
Hi all,  Some good reading here, just sitting back taking it all in.
I have some pine to dry, Its been air drying for about 5 to 6 months  inside of a unheated building, the last month it's been inside a heated garage. My garage has a big enough attic  to put the wood in, If I had fans in the ends of it would it work to dry the wood and  is there a bad side to this? The wood is at about 10 to16% moisture.
Thanks.
Simple answer, yes that will work.
As you have already got the pine air dried you can store / dry it basically anyplace dry and it will settle to whatever moisture content the conditions dictate. Fans are probably not necessary as you aren't going to be moving a lot of water, it's probably only going to dry a few percent more over the next month or so.
Be aware that the pitch wont be set in the air dried wood, this could be a problem in some applications as it can foul up the final finish if the wood ever gets hot.
Apart from that it sounds like you have got a pile of good air dried pine.
oh...  And welcome to the forum  :)
pep
Hey Wooddog, Welcome to the FF.  It's about time you started to post.
Pep :D :D :D
Lucas 827 w/slabbing bar
JD 410B
Wood Wiz Surfacing Attachment
