Things change in a hurry ...
Started by TexasTimbers, March 19, 2005, 03:56:39 PM
TexasTimbers
Long story that I'll skip, but I just bought a 56" circle saw with a 55' bed. Cut a log with it less than an hour ago (just have to move the behemoth next weekend after I get back from Joey Lowes). Not gonna buy that woodmizer in washington state, so that problem is solved.
I picked this circular up on the cheap, and can still buy a new LM2000 to go with the circle all for less than what the WM would have run before shipping, by itself.
Here's the rub. The circle guy asked why I want a bandmill when I what I should be buying next is a resaw. Says I ought to buy one from Morgan (www.morgansaw.com) in Louisiana. Says it will do everything and more than a bandsaw and faster.
I'm not going to let one guy change my mind but I thought I'd run it by you guys and see what you think about resaws.
My impression is that resaws are for production lumber making. We're building a timber frame and not wanting to go into the lumber business necessarily, except to cut some when we want, after the house is done.
Hope to get some thoughts on this. Thanks. KJ.
Buzz-sawyer
I run a 56" simonds.
If you are making timbers you have what you need already.
You will be able to quickly saw out your timbers on that sawmill. You dont need a resaw for timbers.
But , chances are you will like what you are doin, and find more logs to cut. ;)
Congrats :)
    HEAR THAT BLADE SING!
I agree, You have all you need in the circle saw to cut lumber or timbers or anything you need.
I would add that if you are going in the lumber business and are paying high dollar for the logs and trying to eek out every spec of lumber you can in order to try to make the additional payments on additional equipment that you bought caused you to have to go into the lumber business and buy higt dollar logs, then you should probably consider a resaw.  smiley_flipping
Read my signature.... :)
sigidi
Kevjay, this sawdust making thing - it's a bit addictive, as has been mentioned.
You will find yourself looking at trees as you drive around the country,
you will be able to spot a downed tree from a mile away, out the extreme right corner of your eye, while driving at 60mph down a winding mountain road.
Then you will be kicking yourself if you don't detour your trip to find the 'owner' of this tree and organise to haul it home or cut it up.
You will also get very acute hearing for chainsaws, just the sound of a chainsaw coming off a gentle breeze will fill your head with images of gorgeous boards coming out of the truest log you've ever seen.
Then you will use your further heightened sense of hearing and direction finding to source this chainsaw prior to the operator swithching off, so you can get the log as fresh as possible.
Just hearing about freinds and neighbours stories of "Oh I burned up a cpl of trees just last year" will have you grieving like you lost an old firend...
Suffice it to say, I am an addict, I can't get enough of making boards out of "some old tree I was just gonna burn" (comment of an old guy who let me cut his tree, and was amazed at what comes out)
I'm sure you'll make the right decision for you even if the Missus won't understand ................................. YET
What Sigidi said! He's got it nailed!!!
I was taking detours and looking trees along the road and collecting logs loooong before I had a mill. But now I find I MUST search out that chainsaw I hear running as well. ;)
TexasTimbers
Yeah Buzz, I know I'm going to like it, I do already just cutting one log. I'm hooked.
JeffB, I know about the debt trap from experience. We paid off the last of any of it last year - house and all, and now we don't participate in it anymore. IF I can't afford it I don't need it. My dad used to tell me that and I didn't listen to him when I was younger. Dad gets alot wiser as I get older :)
Sigidi, I know exactly what you mean. I've already been looking at trees for years that way, ever since I've been wanting a bandsaw since 1987 the first time I stood next to one and breathed in that cedar sawdust flying off that blade.
As far as my bride, she's as excited as me if not more so! She doesn't pull me down she participates in everything I do. I'm a blessed man to be sure.
Thanks for the info guys, but I still don't understand the purpose of a resaw, and although I can cut my beams quickly now, I still want the bandsaw to make 1 & 2 bys for flooring, decking, interior studs etc. for the house, storage buildings, kiln/s .... geez, sounds like I'm going into the lumber buisiness or something ... ;)
Buzz-sawyer
You will be making 2x and 1x lumber AS you make your beams...those boards will be comming of the sides , right?
What you may need, though, is a planner to finish those boards, if you dont want rough sawn surface ;)
Ok, stupid question from someone that don't know a whole lot about circle mills............
How do you guys edge your flitches with out an edger or resaw?
TexasTimbers
I have a planer, but it won't accept anything taller than 6", so another reason for a bandsaw right.  But I won't be gettting enuf dimension lumber from knocking off the sides making beams will I? At any rate, I'm thinking I really need a bandsaw to maximize the bf ...?
I thought the whole thin kerf bandsaw blade versus the thick (1/4"?) circle blade is fairly well settled.
The whole point of my question was to determine if I should get a resaw in lieu of a bandsaw and now you got me wondering if I need either one at all  :-\ ....
I'd wait until you have this mill setup and running and see how things are going before spending any $$$ on either a resaw or a bandsaw.
But that's just me.
Buzz-sawyer
Well, as one circle sawyer to another.....The kerf debate IS over...circle saw wins. :) ;)
Do you saw high dollar logs, or common saw logs? If you are cutting 18" or better logs you will get lots of side lumber.
It sounds like you may just really need a bandsaw (want?) ;)
If you are sawing costly wood, a band resaw, or mill is great.....but for what you are doin, you got the right tool...now I like bandsaws too, but they have thier own set of drawbacks balancing out the kerf issue, like blade costs and maitenace, time used in the cut, (on smaller mills)...........So dont believe you bought a Red headed step child....How long is your carriage, and what type engine does it have?
As far as the other saws,
you dont need either one....that mill you have will eat up anything you put on it, and make 3/4" lumber on up.....you will have some saw dust.....but in doing the math, you will find time, and cost of equipment, dont add up to the huge differences some folks talk about.
ESPECIALLY when you are making cants, or beams...I just sawed out an order of 5/8 planks out of sweet gum, for every 3 I cut I had 1 in waste dust.
Now, with 1/8 kerf you would get a few boards  more, but at the price of blocking logs, your still ahead in my area .Maybe you will be on your logs too :)
Use it you will see  :)
Quote from: Furby on March 19, 2005, 07:32:00 PM
Furby, you can pile the flitches right back on the carriage, dog them down and edge them, pretty much the same way you would do it on a bandmill. Actually its easier on a circle saw cause you dont have to stand boards on edge, just pile em flat.
Buzz-sawyer
Another little help(  on a simple mill like mine)  is to leave the board attached by a small corner and return it to the log deck, then just flip it off on the rails........I dothis for different reasons, one being to plain saw through a ways on a big brute I dont want to fight.
Then do as Jeff said and edge up all that remains....clear as mud right? :D :D :D
TexasTimbers
Ya found me out Buzz, I DO want one! But if I really don't need one it's a waste of alot of money I could use on ammo and bait perch :D
Thing is, when we caut that log today it came off the saw with some rough as heck markings on it. Not nearly close to satisfactory for using as timbers in a timber frame home, unless of course as in a super rustic lake cabin, which would be fine.
I guess I'm suffering from cognitive dissonance ...
It'll probably be 3 weeks before I have it moved, re-alighned, and sawing again. I have to rebuild some of the components too. Nothing major, Some of the carriage nbeams should be replaced, and some other parts I don't know the names of yet. Wow, what a newbie I am ....
So I'll try to take your advice and cut with the circ before I buy a bandsaw. No promises. I'm leaving for East Texas tomorrow to go get some TF experience with Joey, so that woodmizer might make get me all starry-eyed for a bandmill ya know ...
Thanks KJ
Buzz-sawyer
Good luck
And If ya need any suggestions I have moved a mill before, as several others here have, and could give some pointers to help.....like set it up at least 2-3 feet above the ground. :P
Thanks, that's what I kinda figured, but really wasn't sure.
Corley5
 8) 8) 8) 8)  We've got another circle miller in our midst.  We're still out numbered but holding our own. ;) ;D ;D
I'd love to have a bandmill but there's just no comparison to the sights, sounds and smells of a big old circle mill at work.
TexasTimbers
This forum is FANTASTIC! 8) 8) 8) 8) 8) 8) 8)
Y,all are great. I really appreciate the wealth of knowledge and willingness to help a total stranger. Muchas Gracias, Domo Ariagato, and спасибо! KJ
When time comes, we'll see if we can get ya on track so that Circle saw is cutting proper. If its leavin the boards real rough there's something going on there...
Bibbyman
All right you circle mill guys,  I'm back....
With a 55' bed,  (and that's a lot longer bed than many circle mills are equipped with.) what is the maximum length log you will be able to saw?  25'?  Or there abouts.
With a band mill,  you can get extensions or build a track as long as you want.  Even most standard bandmills – like the Wood-Mizer LT40 will saw 21' – the big Baker will saw 25'.  And you can stretch that a few more feet with some extra thinking and work – if you only have a few to do.
A 25hp gas engine on a standard bandmill will saw all day on 5 gallons of gas.  The big 40hp+ maybe 10 gallons of diesel.  How much HP does it take to turn that big circle mill blade?  100-200?  How much fuel does that take?
I've not done any cost comparison on circle vs. band but I've always figure my blade cost at .01/bf.  Others have come to the same conclusion.  I've heard talk of how much a circle blade cost initially – I don't have a good idea how long they last.  I guess until they hit something that destroys them.  But I also hear the circle mill guys talk about how much the teeth cost and they're not cheap.
A quality, name brand band sawmill,  kept in good shape,  have always returned pretty much of their initial purchase price on re-sale.   I've seen a few used circle mills go for not much better than scrap prices.  (You say you got yours "on the cheep" – right?  You'll probably find out why...)
If I already had a circle mill and had money to add to the operation,  I think I'd buy an edger.  While you can edge on a circle mill just as you can on a band mill,  It'd be like using a bulldozer to till a garden.  A simple two-blade edger would do the job faster and easier and would take far less fuel to run and maintain.
Sawing since '94
Corley5
10 gallons of gas=approx. 2,500 bdft of softwood lumber with my 60hp gas engine.  I can saw a 22' foot log, that's what will fit through the mill door, on my 16' carriage with 54' of track.  I've edged on the mill for small jobs rather than belt up a tractor to the edger.  It's OK for small amounts but isn't practical for anything else.
Swede
We are talking grits and tatoes, as we are talking band sawmills versus circle sawmills.
I think both can feed a man, depending of what he have to saw (or what his stomic needs.)  :D :D ;D ;)
Sometimes I could use a circle sawmill with two blades on one shaft. There is some small logs I could make boards of but just saw in two peaces and throw into the firewood pile. They don´t fit on a band sawmill.
Congratulations to Your circle sawmill, kewjay!
Swede.
Had a mobile band sawmill, All hydraulics  for logs 30\"x19´, remote control. (sold it 2009-04-13)
Monkey Blades.Sold them too)
Jonsered 535/15\". Just cut firewood now.
RIght on Swede.  The only comparisons I will make is that they both make lumber.  Also the mill I run has the cabability of 30,000 feet a shift. Pretty glaring production difference unless we are talking about a band headrig.
I have sawn with circle blades older then I am.  My record for a set of inserts is over 400,000 feet of aspen. typical is 150,000-200,000 sawing debarked logs.
TexasTimbers
So many valid points and of course circle men are biased one way and band men another. Human nature. I'm sure someone on the forum runs both. Him/they would surely have an interesting perspective.
Bibbs you make a strong argument with what seems like many valid points, and they probably are. He claims it will saw a 30' log. It has a 40 gallon tank and he claims it will run all day using only a 1/4. I'm covering my butt by starting with "He claims..." to let you know I'm green but not necessarily gullible  ::) We'll find out the realities after I start cutting I suppose. I didn't buy the mill based on those "features" ...
I don't mind telling you I paid $2500 for the mill. Probably too much  :'( but it seemed cheap enough to me for a mill that runs and cuts wood. The engine alone is worth a big chunk of that I would think ... Maybe I am gullible after all! :(
lord_kenwolf
well that mill should be able to cut 30 feet.  a sawmiller that helped us get our mill going  has sawed 32 feet on his 14 foot carrage. it all depends on how big of an opening you have for logs, that and how crazy you are  with dealing with big logs.
  as for how much horse power you need, we have been told  from lane sawmills that we would only need about 90 horspower to run our 50 inch blade.  we use a 671 detroit industrial engine so we have plenty of power for it.   the only bad thing is the price od desiel, at 2.35 a gallen it gets expensive. if you have a big tank for it maybe you could get your local heating oil company to bring out off road fuil thats what we do and we save about .40 cents a gallen.
