Board feet spread sheets
Started by Tony, March 15, 2005, 08:24:08 PM
Tony
 8) 8) Hello FF, been eavesdropping for awhile.
Got a silly newbie question, are there any spread sheets out there that show the bdft of the most common lumber sizes or cuts? Seems like I spend alot of time at the end of a milling job [ tired] with a calculater. Thanks in advance, more silly questions later. 1st post please be gentle.
        Tony smiley_wavy
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Bibbyman
Welcome to the Forum!
Well,  I think I know what you are asking for .... Something like and Excel spreadsheet with board feet tables on them?  Don't know of any.  Guess it wouldn't be too hard to make one up.
You could check under the "Forum Extras" up in the upper right of this page.  Under it a "Toolbox" with all kinds of calculators.
You'll probably find a number of ways to shortcut your counting anyway.
When we're sawing we generraly saw mostly the same stuff - Like - 8' 1x6s or 5/4 walnut x 8' foot.  Well put this lumber in a stack and then count/measure the stack.
Mary has a marker board in the sawshed with how many board feet are in a bundle of 5/4 walnut so long x 40" wide by so many layers.
Same with our fencing lumber – so many boards wide x length x number of layers = bf in bundle.
Lot of times when we got a bunch of odd stuff,  we just stack it the best we can and just guesstimate the board feet in an average layer x layers and just round down.   Life is too short to calculate every board and add it up.
Sawing since '94
We had a spread sheet. I cant find it. And sorrier yet, I can't remember who sent it to me to post!
HELP!!
spencerhenry
bdft in common sizes are easy to figure in your head. 2x4= 2/3 bdft/ft, 2x6=1 bdft/ft, 2x8= 1 1/3 bdft/ft, 2x12= 2 bdft/ft. an easy way to figure it is multiply thickness by width, and divide by 12. 2x4=8, 8/12= 2/3. in 10 foot lengths its real easy, but all others are pretty simple. or for a large order, count the number of pieces to find total lineal footage.  when i am cutting multiple sizes, i sometimes count # of pcs of each size, and average length, when cutting random width 1x  i count layers of the stack, and muliply by the length and width of the stack.  when i bought my woodmizer, i got a little paper "calculator", a chart of bf in various sizes at various lengths.
Bibbyman
You could simplify all the counting by sawing only boards12" wide or 12' long.
12" wide is just thickness x length = bf.
12' long is just width x thickness = bf.
It's those odd widths that get me.  I'll stack 3 4" wide boards together and count them as 12" wide.  Or 3 8" wide and count them as 2x12" wide. Or a 4" and 8", or 6" and 6".  That sort of thing.
I try to avoid sawing 10" wide boards because they are just too hard to figure up.
Sawing since '94
pappy
Quote from: Bibbyman on March 15, 2005, 08:37:23 PM
Best Way !!!!
Quote from: Jeff B on March 15, 2005, 08:42:31 PM
HELP!!
Whoa Whoa # one ....... Remember...
Life is too short to calculate every ......!
Quote from: Tony on March 15, 2005, 08:24:08 PM
Best time to reflect on your achievements....
Like Bibby pretty much said a block is a block is a block... a cubic foot is what it is...  cubic inches divided by 144
During and at the end of your sawing session ( with practice) you'll be able to tell at a glance what... you sawed ... are sawing ...
Spring is almost here... remember what the flowers smelled like....   Mmmmmm  Life's too short...  but I'm still anxious to see sawdust flying
A little calculator in the truck and a pencil and paper will solve all of the problems with little brain strain.
H" x W" x L' / 12 = BF
You no longer have to worry about odd lengths, odd widths or quantities.  Just fill in the blanks and charge for what you think is fair. :)
Bibbyman
One thing we did do on a spreadsheet that IS very handy.
We get a lot of calls for and sometimes sales of just oak farm construction lumber.
So I made up a spreadsheet with common lengths across – 8',10',12',14',16' and widths down – 4",6",8",10",12"  in one inch and two inch thick. All fit on one standard paper size "landscape".
Then I set a base price for our lumber and to each length over 8' added and extra $.05/bf.  Then for each width greater than 8",  I added another nickel.  So an 8'x1x6 was at the base price but at the other corner was the 16' 2x12 that was about double in price/bf.
That way when the phone rings,  we can pull out simple sheet of paper and tell them the price per board.
When it's time to raise the base price,  I just change the one figure and all the cells update to the new price.
Sawing since '94
Back40x2
    Tony,
    There is a book I got a while back that is very helpful.  It is call "Simply Board Feet" by Douglas E. Maxwell.  THe book is nothing but every calculation set up like the old "Times Table Chart"  very easy and simple.  It covers from 1x1x12(.1bf) upto 16/4 x 25.5x20', in that order
     Lengths stop at 20 feet.
After a while the commons will be automatic ;) ;) ;)  Thats why I still use my book :D :D :D
Hope this helps
My JD 4120 Loader/Hoe/fransgard winch, a 10,000 pound Warn winch, STIHL 460,  Timberking 1600,  Lots of logs, a shotgun, rifle, my German Shorthaired Pointers and a 4-wheel drive, is all this Maine boy needs to survive!! Oh Yeah, and my WIFE!!!!!!
stumpy
I made a spread sheet that takes typical sizes of boards sold a Home Depot. I use it to compare prices. It breaks down standard sizes by lineal feet and board feet. If you want a copy, email me and I'll attach
jvogt@wi.rr.com
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Back40x2
   Stumpy,
   Just sent an email 2ya.  WOuld love to have a copy, if its not too much trouble.
Quote from: stumpy on March 15, 2005, 10:49:55 PM
jvogt@wi.rr.com
Whats the format? we can make it so you can attach it right to a post here...
fstedy
Here is a copy I made on excel if you need 2X sizes just double it Hope this helps you out. It was originally made as a tally sheet.
Size   Board Ft.
1x4x8'   2.7
1x4x10'   3.6
1x4x12'   4.0
1x4x14'   4.7
1x4x16   5.8
1x6x8'   4.0
1x6x10'   5.0
1x6x12'   6.0
1x6x14'   7.0
1x6x16'   8.0
1x8x8'   5.3
1x8x10'   13.3
1x8x12'   8.0
1x8x14'   9.3
1x8x16'   10.7
1x10x8'   6.7
1x10x10'   8.3
1x10x12'   10.0
1x10x14'   11.5
1x10x16'   13.3
1x12x8'   8.0
1x12x10'   10.0
1x12x12'   12.0
1x12x14'   14.0
1x12x16'   16.0
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
PhilD
Jeff,
I've got 2 Excel spreadsheets I use all the time and would be happy to post 'em.  Will the forum take .xls or just the 3 listed?
-PhilD
Ga_Boy
I built a spread sheet that I plug in how many, thickness (in inches) width (in inches)  and length (in feet).  Out spits the total number of bf.  I also can set a price in one cell of the spread sheet and this thing gives you the dollar amount.
Let me know if anyone wants a copy.  I have not been able to post Excel spread sheets.
stumpy
Jeff,
Mines Excel out of Microsoft office professional
FeltzE
I've got one I use with all the standard sizes up through 4 " x 20' with a column to list the customers quantity, size and bf on the right I use it a lot, can't find the original digits but can fax a copy to ya.
Eric
FeltzE
I lied, got one scanned in on digits you can print out and I can email to anyone interested.
Jeff, is there any way we can upload little helpers like documents, excel spread sheets to share with FF members?
Eric
sparks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Quote from: FeltzE on March 16, 2005, 07:55:15 AM
Eric
Yep, there sure is. You can attach .xls by using the additional options when you make a post
beav
   Years ago I got sick of figuring up the bdft of a job at the end of the job. I came up with what I call the cant size method. Basically, when the log is squared into a cant, the amount of wood in it is the same no matter how you slice it. So I measure the cant, and take into account the edge boards that came off, the wane left on the cant, etc, and make one entry in my logbook.
(say it's 10 x10" x 12'- easy to figure 100 bdft comes out of it)
  Running a bandmill, it is easy to convince the customer that he owns the kerfs. I haven't had a problem with this system in years. much less figgerin' at the end of the day 8)
johnjbc
Here is a spread sheet that contains formulas to complete a bill. You will need to go into Tools and unprotect the sheet to make any changes, to the Heading, or Formulas. If you have any question or suggestions please ask.
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
Bavarian in Brazil
This thread just makes me think one thing: Hail to the metric system!
Percy
I have a low tech spreadsheet  that is a MS Works version. It  has 1X4 -2X12 from 6 feet to twenty feet, does all the guzzintas and is easily modified.....if you have Works ;D....I can upload with uhhhh directions.. Like a pic??? Can do..
Back40x2
   There is a book I got a while back that is very helpful.  It is call "Simply Board Feet" by Douglas E. Maxwell.  THe book is nothing but every calculation set up like the old "Times Table Chart"  very easy and simple.  It covers from 1x1x12(.1bf) upto 16/4 x 25.5x20', in that order.  I got it online from either Amazon, or Barnes&Noble.  Just type the authors name, or the name of the Book and it should come up.  Great Book.  No figuring at all 8) 8) 8)
After a while the commons will be automatic ;)  ;)    Thats why I still use my book :D :D :D
Hope this helps
