stihl 032 starting problems
Started by fruitcakesa, March 05, 2005, 06:04:29 PM
fruitcakesa
My Stihl 032 super chainsaw will start and run on 1or 2 pulls when cold but after a few minutes of running will quit dead and not restart until a day has passed!  I have put in a new spark plug with the same results. The gas is fresh and the plug is not fouled when I pull it out. During the dead period I get little or no spark when I spin it to check. This saw has an electronic ignition module. Do these units gradually fail? I thought they just quit and were done.  Any help?
Minnesota_boy
The normal spark with the electronic ignitions is quite faint, but very hot.  If you want to really know what it is doing, get a spark indicator that uses a neon tube to give you a brighter flash.  If you done't have spark when it dies, then you will know that you need a new ignition module.
Kevin
Defective switch or wiring could be another cause too but more than likely the module.
