I recently took in a woodmaster 725 single side planer for repair. Owner says it leaves bad marks on the planed surface. A little investigation revealed this sequence of events, things you DO NOT want to do to ANY planer.
1..Planing some 4/4 lumber with severe dives and climbs down to 7/8 in one pass. Thick spots kept hanging on the bar across the infeed, so just removed the bar and lost it. I replaced the missing part with a piece of 2X2 angle iron. It will be cleaned up and painted.
(https://forestryforum.com/gallery/albums/userpics/14000/planer03.jpg?easyrotate_cache=1504750225)
2...Thick boards now don.t hang on the bar, but hard to get them started under the feed rollers, so removed the springs that apply down pressure to the feed rollers ( and mis-placed them). New ones in the pic
(https://forestryforum.com/gallery/albums/userpics/14000/planer01.jpg?easyrotate_cache=1504750543)
3...Started getting kickbacks and marks on the lumber. Here's why..broken 25 inch planer blades, NOT cheap..
(https://forestryforum.com/gallery/albums/userpics/14000/planer02.jpg?easyrotate_cache=1504750447)
I did ask, why not just lower the bed a bit and make 2 passes ? OH, I can't find the crank to lower the bed.. ::)
Yikes!
If you don't like your planer and it makes you mad, don't tear it apart? Send it to me, I'll give it a happy home! 8)
Quote from: pineywoods on September 06, 2017, 10:39:33 PM
..........I did ask, why not just lower the bed a bit and make 2 passes ? OH, I can't find the crank to lower the bed.. ::)
yep, cant fix stupid. :( ::)
Quote from: DDW_OR on September 07, 2017, 03:04:12 AM
:D :D :D Some people should not be allowed to have corded tools. I had a Grizzly Tech tell me that he had a dude call about a problem with his 1023 table saw. After diving into the problem, he also discovered that the man wasn't using a blade guard. When he asked him why, he replied that he doesn't use it, "...because I am blind and it gets in the way!". :o :o
Quote from: PA_Walnut on September 07, 2017, 05:09:01 AM
That's one job I hated working at Grizzly was phone tech talk with someone that has not a clue.
I almost cry when I see something like that, I love good tools. The trouble is the guy likely hasn't learned anything, will continue in his ways and expect future repairs done on warranty for free. I worked on the sales and tech desk for the Ridgid/Ryobi parts distributor, the consumers would phone us and complain when they couldn't get anywhere with the service center. One guy was mad when he couldn't get warranty on a new table saw, a call to the dealer revealed he had changed the plug so he could run it off 240 volts. ::)
I have the Woodmaster 18 for a long time with no trouble. The only thing that i didn't like was the dust collector
would not pull all the chips out. A lot was coming out the in feed side. I talked to Pineywoods and he said i might
try lowering the hood down. I did and A lot, no more chips coming out that side.
Sawwood
Some of these can be attributed to ID 10T errors.
if the 725 is going to be yours i would get the spiral cutter head.
less chatter, tear-out and quieter.
will be getting one for my 725.
I bought a planer "that wouldn't plane worth a flip". It was cheap, figured I'd give it a try. Worked pretty good after I turned the knives around :D.
:D :D Now that is funny.
Don, I've seen that one also. Took the blades out for re-sharp and re-installed them backwards. shoved in a wide ash board and actually cracked the head, letting the blades go loose...
but but if it wasn't for us stooped people some of you would be out of business :D :-X
Quote from: sawwood on September 07, 2017, 12:52:48 PM
Sawwood
I also have a 718. I took the cover off and made one of plywood, with the dust port relocated on the infeed side instead of on top. This put the port where the chips were going anyway. Reduced the escaping chips by about 95%. I plan to modify the original cover and re-install it when time permits.
The original design had the chips bouncing off the inside front of the cover and scattering all directions, with some percentage being collected by the dust port.
