what would make the track bushings wear more on one side than the other every thing was new on both sides
The track could have been too tight on that side OR I have seen some dozers that worked on the highway doing slopes that traveled the same direction too long and worn one set of chains a little more than the other.
In addition to the track being to tight, the track spacers could need adjusting such that there is pressure on the bushings.
ok you got me what are track spacers ??? ???
The dozer operator always cleaning the mud/ grit out of one side of the dozer tracks better than the other.
http://www.west-trak.co.nz/wp-content/uploads/2016/03/Undercarriage-Handbook-low-res-1.pdf
the only time it gets cleaned is the winter or if something brakes I'm the operator and never had this with any other tracks
Sorry, the better word is shims, not spacers. They correct the track from tracking from one side to the other which can put pressure on the bushings. They slip in on the track adjuster and need to be checked to see if the track runs one way or the other more. Here is a generic link which shows a pic of the shims.
http://www.epsstore.com/index.php/jd-track-adjusters-gseries.html
Are the sprockets worn equally,or is one worn more than the other? Were the front idlers replaced at the same time,or is the center "ridge" higher on one or the other?
Just a thought but were the tracks the same brand when you replaced them? Maybe the steel is different quality?
Quote from: willysjeeps on July 10, 2017, 05:58:00 PM
I figured that's what you meant ;D its like the sprocket grove is different maybe smaller where the bushing rides most of the time if the track is running off it will wear the side of the links from the sprocket teeth chewing at it
I welded up an old guys under carriage one time the right hand side was way gone.He ran it for about five more years than we put all new parts on.I think it was about six or seven years after that it needed welded up again didn't hand side way gone. We became very curious and after I watched his operations for several days at different locations found that he always sits his loader up at bottom of hills and brings all logs in and turns the dozer left hard and turns up hill to leave. After that I asked why and he said left turns are the beast way to get them close to loader. He would really make a hard turn to get the big logs turned . I could see the track work hard on all the track rollers. The
Stand back and look down the end of your pads for a curve, see if track frame is bent.
