Commerce => For Sale => Topic started by: ohiowoodchuck on March 19, 2017, 07:22:55 pm
Title: 2001 Ford F-250 diesel.
Post by: ohiowoodchuck on March 19, 2017, 07:22:55 pm
I have read understand and agree to the terms of posting a ad on the forestry forum.
2001 Ford F-250 crew cab shortbed 4x4 lariat 7.3 powerstroke automatic. It has 320,xxx miles on it. Motor has around 200,000 on it. I had to change it due to a cracked cylinder wall. Everything works as it should. Has new brakes, rotors and calipers not to long ago. Changed out the lock out hubs to a better set when I bought it. I drive it everyday to work and around here etc.
the bad part is it's rusty the wheel wells on the bed are bad the rocker panels and the cab corners are bad it needs a front main seal. It leaks about a gallon and half over 7500 miles needs a new up pipe on the passengers side the front axle shaft U joints are bad and it's going to need a set of tires before long. It has a gooseneck hitch and a trailer brake controller. Would make a great farm truck or beat around truck. Asking 5500.00. Truck is in southern Ohio.
Title: Re: 2001 Ford F-250 diesel.
Post by: ohiowoodchuck on March 28, 2017, 02:54:25 pm
new lower price 4500.00
Post by: ohiowoodchuck on May 14, 2017, 10:20:59 am
Make offer. Lots of good parts on it.
