Hi all. Two years ago in an ice storm a tree in my woods was uprooted and fell on another tree partly uprooting that one. Now one is resting on top of the other bending it over.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00826_opt.jpg)
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00828_opt.jpg)
I want to cut them both down for firewood. Both trees are red maples about 12 inches dbh and both are alive.
What I'm asking is which tree should I cut first? It looks like both are under stress, what would be the safest way to go about this?
Any input would be appreciated. Ralph
Well here's my two cents I would wrap a log chain a number of times around the butt about one foot above the ground snap a bummer on it so it's good and tight. Do this to the tree thats on the bottom of the pile ,forget the notch and just start cutting from the back to the leaning side of the tree. Being careful the trees that are stacked on top don't slide down on you. With the chain tight around the butt this will keep it from barber chairing into your face it will barber chair but you have the control of it. Just the way I would do it ,it will be interesting to hear how other fellows do it.
Just another thought be careful theres not tension pushing back towards you like a tree thats its laying in that may spring it back at you when it comes off the stump. Its one of those tree that makes your hair stand up on the back of your neck till its on the ground.
I worked with that kind of blow down many years every day, my nick name was blown down for awhile. I know how i would do it if i was there, I'm not going to get in to do this, do that and get you all confused.
If theres a little bigger tree that you could drop on them, that would solve the problem.
Other wise follow Autocars instructions and be care full.
Don't have a pic of the trees at the stump?
From the tops, looks like I'd do as autocar and take the lower one out first. But the stumps may be a hidden card here.
Beenthere, I don't know if this picture will help or not but this is the top tree. I don't have any stump pictures.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00816_opt.jpg)
Autocar, thanks for the input, I might just go with that.
Lumberjack, There are some big trees nearby, I'll see if any of them can be felled on top of the other two.
Thanks guys, Ralph
That is the pic I had in mind (at the stump).
Do as autocar suggested, and I'd forget the idea of dropping another tree on top. You could very well have three stacked up like that without the advantage of having one of them still fastened to the ground.
Carefully cut the one underneath, watching for any chance it is carrying the load of the one on top.
The one on top doesn't look like it will slide down the one on the bottom if the bottom one is cut off.
Personally I'd be more comfortable cutting the top tree first. With reference to the picture, my first cut would be on the right side of the top tree just ahead of the up rooted ground, I'd do a side cut taking approximately 1/3 the diameter. Then moving to the left side do the same type side cut opposite the right side taking approximately 1/3 diameter. Now if I haven't got my saw stuck I'd make a plunge cut thru the heart from the left side cut and if I didn't feel any tension I'd cut out to the bottom side. If I still haven't got the saw stuck I'm going to try to determine where the tension is by the gap from my cuts and go after the holding wood from either top, bottom or left side. Root ball is probably going to go back down and top tree may or may not slide off bottom tree if cut off is successful. If top tree is still hung I'd start making bottom to top cuts on trunk of top tree from left side until top tree slid off or I'd taken off enough weight that I could put line on the top tree and attempt to pull off.
with a good sharp saw start a very small shallow notch from the front side keep chewing wood enlarging the notch little by little once your about halfway through youll notice the tree weeken just step back n watch it lay down real easy keep in mind this is all done from the front side no backcut at all also need to keep an eye on the one above you
From what I see I would cut the top tree first. It looks like you might be able to get it to slide down the bottom tree. The safest thing is that it slides down and then you are not under anything. If it hangs up then cut the bottom tree like he said. when the bottom tree goes it will fall away from you and take the top tree in that direction also. I haven't been doing it as long as many of you, but I've had a few situations similar to that before and no close calls.
cutterboy, Do you have a machine there that you haul them out with? If so try to push them the rest of the way over and onto the ground first and get rid of most of the tension. Just another thought.
If that little voice in your head is AT ALL leary or uncomfortable with cutting them-leave 'em be. Looks like plenty of other trees there for firewood. :)
Ralph,you should leave them.Other than knocking them over with a machine ,preferably with a cab,there really is no safe way to do this,even for a pro.Not worth an injury or burial.
They will make it to the ground eventually.Even then be carefull.
Leeroy( Logger since'86)
jd540b, I have an old Massey Ferguson tractor I use to haul friewood and logs out of the woods.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00837_opt.jpg)
However I can't get close enough to do any pushing. Soft ground. I can get close enough to get a long chain on the trees once they are on the ground so I can pull them out to an open place I can work on them.
Thank you all very much for taking the time to help me. You've given me a lot to think about.
Leeroy, don't worry, If I don't feel comfortable about it...I will walk away. I have more trees on my farm than I can cut in my lifetime. It's just, you know, the challenge.
I don't think your tractor is heavy enough to push them over safely and like jd540 says if theres any question at all in your mind just leave them stand it's not worth getting your self killed or hurt for life. Things can happen lighting fast and your never hear the thunder. Becareful no matter what you decide to do Bill.
Safety should be your primary concern but it seems that top tree is a reasonable distance from the bottom tension tree so I would cut the top tree first with a plunge cut similar to what has been suggested. If it didn't roll off the bottom tree then put a cable or chain on it and pull it down from a safe distance with your tractor to the ground.
From looking at the pics I'd cut the bottom tree first. You'd have absolutely no control over the top one once it was cut and maybe sliding off or teetering on the bottom one or the added weight my push the bottom tree to the ground which would be good. It could be a very unpredictable event :) Make an upper cut on the bottom trunk until it's almost beginning to pinch your bar but don't get pinched ;) Then cut from the top with control. Don't just lop it off, let it down. A ratchet strap wrapped around it and tightened above your cut will keep it from splitting if you'd like to use one. I probably wouldn't :-\ Make these cuts at a spot on the trunk about waist height or where you're running the saw in a standing position not bent over. If you need to get away it's faster if you don't have to stand up first ;D and keep an eye on what the top tree is doing. That's what I'd do from looking at the available pics but it's also hard to read the entire situation from a couple pics ;D :) If you don't feel comfortable walk away. They'll fall down on their own soon enough 8)
The only safe way is fall a big tree on them as someone else said but if you miss your mark or the big tree isn't big enough you run the risk of building an even worse TP. Unless you are very experienced I would wait for a big winter to take them down, that looks like death or worse and.
I would put your chain near the top,then notch and back cut to the direction you're pulling with the tractor. Leave lots of hinge, if it barber chairs you don't have to split it.
OK, i took a good look, the #3 pic shows more then the first two. You can see the tree underneath isn't up rooted, this means its keeping the tree on top from falling. So the tree underneath has the weight of the top tree on it, this puts a lot of spring in it [ very dangerous ].
Cut the tree on top first, about 4 feet up from the stump, notch underneath just like you going to fall it, be very care full not to get your saw stuck. Looking at the pic start on the right hand side, notch it, then on the side cut in about 2 or 3 inches, do not touch the top side of the tree. Then walk around and do the same on the left hand side of the tree cut in about 2 or 3 inches with out touching the top side. Now your on the left hand side, make sure you have a good path cut to get away. Now make the last cut on the top side, be ready to get out of the way, it might be top heavy, this means the butt end may go 10 or 15 feet in the air. Its going to drop down and slide down the other tree, with that done you go to the other tree. Make the same style cut in that one, again be very care full when making the notch not to get your saw stuck. This style cut is called a box cut, it keeps it from splitting or barber chairing on you. I used this style cut many thousand's of times in blow down or heavy leaning timber.
Now its up to you, if your not sure of your self, leave those two trees on till nature takes them down. I did this for living i had to get-en down.
If you can reach the tree with a chain/cable, why not just tie onto the top tree and pull it off of the bottom tree? If it is a fairly long distance as you say, then you are out of harms way if the trees start doing anything funny. Just make sure you are not putting to much strain on your pull-line. That is the approach I would take with the information given.
I can show you how to put a shaped charge on the bottom tree. That's the most fun way to drop them. I've blown stumps out with properly placed charges before. Other than the slight danger of setting the charge, there is very little danger, the work is being done with you a ways away.
Cutterboy I really like the idea of the shaped charges. ;) That would go over really well ;D here in central Ma. I have a couple hundred feet of 1/2" cable you can borrow. I'm about a half hour away. PM me if you want.. Holmes
If u want to get it on the ground before u cut it off, i would think if u hooked a chain with a slip hook around the tree on top, as far up as the tree as u can for leverage, and just pull it side ways, twisting the stump side ways, should break the roots, and lay it down , should be no problem with your tractor.
If you had a bunch of brush you could try and burn the root ball loose before pulling with the tractor.
I am truly amazed! When I started this thread I thought I would probably get some different ideas but I never thought I'd get so many and such a wide variety of suggestions. THANK YOU ALL VERY MUCH! I love the idea of blowing the stump up ;D but if I did that I'd have the local, state, and environmental police up here, plus the fire dept., board of health, and consevation commission. ::) ::) ::) >:(. Thats how it it in Massachusetts.
I think I would rather cut the top tree first because I'm afraid of the stress the bottom tree is under. I like Lumberjack's method of cutting and might use that. I may try to pull the top tree down first with chain and tractor. But anyway, it's raining hard right now so the project is on hold. The temp is about 40 and I hope the ground doesn't thaw because I need frozen ground there to get my tractor close.
Again, thank you all so much. I'll let you know what I decide and if I cut them down I'll post pictures.
Ralph
I'd go for the top tree first. If there is a chance you'll get it cut and it will still be up in the air on top of the lower tree, I'd tie my chain or cable to it first, and run the other end far eough away from the trees to reach easily later.. If after your cutting, the top tree hasn't come all the way down, you can hook into it with your tractor and give it a tug. (Just make sure your chain or cable is somewhere that it won't get flung at you if the tree starts moving when you are cutting.)
cutterboy, if you can get your tractor in on the left side,with in 10,20 or 30 feet, hook a chain about 3' above the cut i said to make. Leave about 1' of slack in it, this will take the danger out of it , it will keep it from fling up or back at you.
If you can't get the tractor there hook the chain to another tree.
Please be safe
Thanks John. If I cut the top tree and it doesn't fall down off the bottom one, Ill hook a chain to it and pull it down.
Lumberjack, I can't get my tractor in on the left side, (or the right side for that matter) but I could hook a chain to a tree. But shouldn't the chain come in from the right side of the tree? I mean, if the top tree falls down off the bottom tree after it is cut the top of the tree will move to the right, so the butt will move to the left, so the chain wouldn't help if it came in from the left. However, if the chain came in from the right it would keep the butt from moving to the left. Right? Am I overlooking something?
Quote from: cutterboy on January 28, 2012, 07:06:15 PM
My point, not too clearly made, was to hook up the chain before you start cutting. Then, if it doesn't come down, you only have to get to the far end of the chain, rather than mess around under a tree hanging in mid air, trying to get a chain on it.
Hi all. I went into the woods this morning and cut down the top tree. It went very well, I used the method lumberjack48 suggested (thanks lumberjack). I was a little tense while sawing the trunk and I had my run away path well cleared and I was on the balls of my feet ready to use it, but I didn't need to. I decided not to cut the bottom tree today because the ground was too soft. The tractor broke through the surface into the mud and even though I didn't get stuck, I didn't want to take the tractor back into the mud. The bottom tree will have to wait till the ground freezes up again.
Here is the operation in pictures.
First, the tree.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00838_opt.jpg)
I started by cutting a notch underneath the trunk. Then I made a cut down the side about 2-3 inches deep but not going all the way up to the top of the trunk. I did this on both sides.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00842_opt.jpg)
Then I cut down from the top. (this was the tense part) As I cut the tree settled down heavily on the bottom tree but did not twist. I managed to get the saw completly through the tree but it did not fall. There was back pressure pushing the trunk against the stump.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00843_opt.jpg)
I took a heavy dead branch and banged it against the tree and it fell. But the tree did not slide off the bottom tree.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00844_opt.jpg)
I attached a chain to one of the branches and, using the tractor, was able to pull the tree off the bottom one.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00852_opt.jpg)
I then cut the top off the tree and attached the chain to it.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00850_opt.jpg)
The tractor was able (with difficulty) to pull the tree out of the brush to an open area. The tractor did dig up some mud during this move.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00856_opt.jpg)
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00854_opt.jpg)
Then I cut the trunk into 4 footers and some 16 inches.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00860_opt.jpg)
Then I loaded the wood onto the tractor.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00863_opt.jpg)
I then drove the tractor to the barn yard and unloaded the wood onto the wood pile.
(https://forestryforum.com/gallery/albums/userpics/11157/DSC00867_opt.jpg)
Then it was into the house for a couple cups of coffee.
I hope you enjoyed my picture story. I am very happy that tree is down and I'll do the other one when the ground freezes. (if it ever does this winter)
Thank you all so much for your help. May your trees always fall where you want them to. Ralph
Good job! That is a real whack of wood you have stacked there.
Job will done, i kind of figured it would just drop down, but, theres always that but it might do this, so always prepare for the worst.
I liked to leave blow down set for 1 year before cutting, a lot of springiness is gone.
I have cut 40" Norway blow down like that. I would reach as high as i could so i could get a log out of the butt cut. At least 8' and up so there would be no waste. I made that style of cut, when i touched the top, Bang, sometimes it sounded like a rifle shot. The dust would fly, the butt would stand back up. Then clean the dirt away from the stump and saw it down, anywhere from 8' to 16' foot log.
My dad came out one day to watch me cut-em, he shook his head, he said, your crazy.
I found these pic's on the net, this is the some of the kind of blow down i cleaned up, many, many 100'ds of cords.
(https://forestryforum.com/gallery/albums/userpics/21649/16.jpg)
(https://forestryforum.com/gallery/albums/userpics/21649/15.jpg)
Good heavens Lumberjack. I certainly would not want to get into that mess. My two red maples are enough for me.
Its like working on a jigsaw puzzle, you have to take the last ones that blew down first.
If it was a good straight wind its like working behind a feller buncher.
I've cut some so bad i could only get 1 or 2 trees at a time, it plays with your mind.
