BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Woodmizer guide arm shield breaking  (Read 991 times)
Offline irvi00
« on: December 07, 2017, 06:41:14 PM »
Anyone else experience this? This is the shield that is attached to both ends of the movable guide arm. It cups under to shield the blade on the idle side. The factory weld broke and has been welded back twice. I'm ready to cut the shield off.
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: Woodmizer guide arm shield breaking
« Reply #1 on: December 07, 2017, 06:59:33 PM »
Yep, been there.  You've got to make sure you get a good weld fillet on the back side of the bracket to keep it from vibrating.
Offline irvi00
« Reply #2 on: December 07, 2017, 07:07:01 PM »
My guy did that last time. But I could tell the shake was going to take it out again. Gonna cut that sucker off tommorow and not worry with it anymore. Just glad to know I wasnt the only one to see it.
Offline drobertson
« Reply #3 on: December 07, 2017, 07:12:22 PM »
Can't say I've seen it,, seen more than my share of vibration issues, but not that one.  My best guess is the material, higher carbon,  welded and then it cracks.  Lots of components for all kinds of machinery are made of recycled materials. If these are not QC'd, during the billeting  process, well, this is what you might get, high carbon steel has strength, but if not handled properly it can become very brittle. Just a guess, my suggestion would be to pull it off, heat it to a low cherry, then weld it back then, either pack it in sand or draw it back in the oven at 400°  might as well throw a tater in while your are working on it,  ;D
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: December 07, 2017, 08:28:34 PM »
Cut mine off, Good now. :D :D :D
Then some of the tin shields cracked too they're gone. :D ;)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: December 07, 2017, 08:33:25 PM »
My mill had the blade guide shield "off"  (due to a mod) when I bought the mill, and I had it welded back on, no issues since!   ;)
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider
Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Online POSTONLT40HD
  • G29
« Reply #6 on: December 07, 2017, 08:42:24 PM »
What have you got left? 2 tires and a blade?  :D :D :D
Where's the Spoon?
Offline irvi00
« Reply #7 on: December 07, 2017, 08:44:29 PM »
Its history tommorrow morning. I grew up walking around a 0frick and miner edger without gaurds. Made it this long, I figure one less shield wont hurt. I still use that old miner.
    • A&P Saw mill LLC
« Reply #8 on: December 07, 2017, 09:01:54 PM »
almost Mr goat, :D :D
Sawing since 1987
Offline irvi00
« Reply #9 on: December 07, 2017, 09:09:38 PM »
I figured most was cosmetic anyway.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #10 on: December 08, 2017, 08:18:02 AM »
You need a counter weight to take up the harmonics of the vibrations.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline petefrom bearswamp
  • Location: Finger Lakes region of NY, no more FL in winter
  • made 70-10 and still feelin pretty darned good!
« Reply #11 on: December 08, 2017, 01:30:34 PM »
Most of my mills tin is stored in my pole barn
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #12 on: December 08, 2017, 03:22:51 PM »
You might consider solving the vibration issue.
Jim Rogers
    • A&P Saw mill LLC
« Reply #13 on: December 08, 2017, 07:27:16 PM »
Where would you hang that? :D :D :D :D :D
Sawing since 1987
Offline irvi00
« Reply #14 on: December 08, 2017, 08:09:05 PM »
Problem solved.........
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #15 on: December 08, 2017, 09:26:55 PM »
I Haven't had to remove anything but the flapper on the muffler, so far. DanG thing would rattle at idle and drive me crazy.
Offline Kbeitz
    • My Hobbies
« Reply #16 on: December 09, 2017, 06:56:26 AM »
I would start with a strong magnet.
Just stick it on and watch your vibrations.
Move it around to find the magic spot.
I do this with my boring bar on my metal lathe to stop chatter.
Interesting ...
http://www.physicsclassroom.com/class/sound/Lesson-4/Fundamental-Frequency-and-Harmonics
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline Magicman
  • A "Traveling Man"
« Reply #17 on: December 09, 2017, 03:27:29 PM »
Jim Rogers
I too am wondering why it is vibrating and where it is coming from?  Are you running Wood-Mizer B57 belts?
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline ladylake
« Reply #18 on: December 09, 2017, 03:42:36 PM »
 Seems like most engines vibrate plenty at idle, not so bad when cutting.  Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #19 on: December 09, 2017, 04:20:33 PM »
 Have had to weld mine also a few times. Don't worry about it, keep sawing. If you're not sawing you sure aren't breakin' anything.  ;D ;D
   Marcel
