Author Topic: Bees  (Read 216 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Bees
« on: October 02, 2017, 06:54:29 am »
This time of the year I feed the bees some honey back to them all.
Bumble bees love it.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline gspren
Re: Bees
« Reply #1 on: October 02, 2017, 08:39:43 am »
  Peter, I think you may have the knowledge we need. A friend needs to move some hives for his daughter from a suburban location to a rural location where bears are possible/probable. He is putting some metal T-posts around them to run a solar electric fence. Any words of experience as to spacing, number of wires, or anything else that should be done?
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Bees
« Reply #2 on: October 02, 2017, 09:16:02 pm »
You better have a pretty hot fence to keep them out, my brother worked at a zoo years ago and the electric fence they used to keep the bison in ran off of 220. Just to keep the goats I had in I started the first wire at 6" then 12", 18", 24", 36", 48". I didn't run a ground wire in between the hot wires but for bears it could be a good idea. In the middle of summer when the ground was very dry there wasn't alot of juice from a 15 mile 120v shock box to zap you with.
    • A&P Saw mill LLC
Re: Bees
« Reply #3 on: October 03, 2017, 06:35:37 am »
I have no faith in an electric fence. That's why I have a [Bee House]
Most times the Bear will knock it down and destroy your hives.
Sawing since 1987
