Author Topic: Thinking of starting  (Read 1872 times)
Offline Candlex
« on: August 04, 2017, 10:05:41 pm »
Been doing a lot of reading and lots of different opinions for everything. A lot of good people though.
So i have probably 40 acres of mostly red oak, some blacj walnut and cedar.
I wanted to start offering cleanup behind my dozer friend, possibly for free for the wood. Not sure if this was a good idea or not. I have no codes to follow for building permits etc soi figured a small barn for storing and a kiln and a covered saw.
I have a 89 1 ton dump truck, 55hp tractor, and a couple nice chainsaws and a lot of wood tools.
This will be just me in my off time and weekends. Paying for wifes nursing school right now so would be nice to make small tables or cabinets with my wood.
Is this too much to do at once? Also, i have to quarter saw all my wood since its red oak is that correct? And would a low end saw work for my needs?
It is a very large investment and i love woodwoking so i wont mind, but very daunting. My part of oklahoma isnt exactly filled with lots of equipment and sawyers. Only 2 near me.
Thanks for your time.
Offline Grizzly
  • I wanna go camping!
Re: Thinking of starting
« Reply #1 on: August 04, 2017, 11:50:32 pm »
Welcome here, Candlex. Yep, lots of opinions here and mostly all useable.
Low end and low cost are very different so I'll choose low cost. There'll be more chiming in but I've read lots on here of small mills cutting some fantastic wood. No need to go expensive with all the gadgets if you're not needing big production. Lots of choices as well and a bunch of them are sponsors of the Forum here. Enjoy the shopping.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws
   2149 - 111S - 90?
Cooks Cat Claw & Dual tooth setter
2000 Miners 3-31 Board Edger
Offline Candlex
« Reply #2 on: August 05, 2017, 01:36:06 am »
Offline Ianab
« Reply #3 on: August 05, 2017, 02:01:44 am »
I think it's perfectly practical to get yourself a small manual sawmill.
As long as they are set up right the smaller mills will cut the exact same boards as a fancy expensive one. They just wont do it as fast, and you have to do more of the work manually yourself. So obviously if you are sawing as your main job, you want the higher production that the automated mills provide.  But if you are basically hobby sawing, it's not such an issue. Also, if you are harvesting logs yourself, then drying and building stuff, the actual % of your time spend sawing is quite low. Having an expensive mill that's going to be sitting idle most of the time doesn't make a lot of sense. But having a ~$5000 (or less) mill that you only use a couple of days a month is easier to justify.
As for sawing the Oak. Quarter sawing gives you a more stable board, it shouldn't cup as it dries. But you need a large and good quality log to be practical. Smaller logs give you such narrow boards it's not worth it, and if the log has any knots, Q-sawing leaves that as a "spike" right across your board, which then breaks in 1/2. A knot in a flat sawn board goes through the face of the board, and if it's small the board is still usable, or you can cut around it to get the pieces you want. So smaller or lower quality logs are usually best flat sawn. You can Q-saw with a small manual mill, just like I said, you have to work harder moving the part cut logs around.
This is my manual mill, and a mornings sawing. About 300 bd/ft of Port Orford cedar which will keep me busy in the wood shop for some time.
Offline Candlex
« Reply #4 on: August 05, 2017, 01:28:07 pm »
Well awesome that answered most of what i needed to hear.
How small it too small? I'm guessing 6" radius? Also what what blade should i use?
I noticed the swingmills were super quick, but from my reading a bandmill would probably be better? Since my stuff isnt monster big.
We have so many types of trees here. i bought a book to identify them. Not sure if all are harvestable. Blackjacks, pecan,horseapple, the trees with the 1 inch spikes, etc.
Offline Candlex
« Reply #5 on: August 06, 2017, 05:17:38 am »
I am looking at the woodland mill either the 122 or the next one up. It looks like the 126/130 model (identical diffrent motor?) is built a little more robust though
I can pay cash straight up for those though. I can always weld fancy stuff on. I just figure ill have to raise it up since im a tall dude.
Offline thecfarm
« Reply #6 on: August 06, 2017, 07:38:48 am »
Canlex,welcome to the forum.
6 inch logs are kinda of a bother. BUT if that's all you can get,than they will work. Just makes for narrow boards.
I have an all manual mill. Lots more work to using it,but I only use it for my own lumber. I have not even used it this year. But I do have a building project for it.
You will want to get some lumber sawed up for the furniture building.It needs time to dry. Building a shed,barn,I put it up green. Not like I am sheetrocking and putting insulation on lumber that is green and still drying.
You will need a cant dog or a peavey to turn your logs. Logrite on the left has them and the website tell which is which on there. I myself prefer a peavey. I am not doing high end lumber. The point can leave a small mark on the wood.
Make yourself a place to put your logs on,and than roll the logs on to the mill. You do not want to hit your mill,drop a log on it either, with the tractor. Two pieces of wood,flat on the top side,just a little higher than the mill,works good.
Offline Candlex
« Reply #7 on: August 06, 2017, 10:49:55 am »
Thanks, thats a good idea.
I also thought about building another rack to stack the first cuts so i dont have to bend over and pick them all up.
I read that whole article on the kiln from virginia tech and i guess in oklahoma i would be lowland red oak?
So it can only lose like 1 to 3 % moisture a day. It doesnt sound like i can speed dry it, and that i shouldnt even show it sun at all just air.
With the smaller logs do you run into board strength problems? I would like to clear some land at a couple other properties, but im not sure they are all ginormous trees.
Offline mike_belben
  • Pulp Friction
« Reply #8 on: August 07, 2017, 10:13:13 pm »
1" spikes on the trunk sounds like distressed honey locust. Makes great fence posts.
Offline Ianab
« Reply #9 on: August 07, 2017, 11:54:23 pm »
Quote
Not so much a strength problem, it's more about grade and stability. Small logs mean you are sawing close to the pith, which usually means knots, and the grain direction can change a lot across the board. If the grain is different, expect the drying shrinkage to be different. Now if you just want to build a shed, this isn't the end of the world. A board with small knots is usually still plenty strong enough, and once it's nailed down it wont move much. But if you want to build high end furniture, you want clear straight grain boards, and to get those you need decent logs.
Minimum size of the logs depends on various things. Too small and you don't get much good lumber, and spend a lot of time putzing about for very little return. Now I've sawn cedar "logs" down to about 6" dia, and we made 4x4 posts from them, as my friend wanted some for a project. They didn't need to be high quality, just hold up a pergola in the wife's garden. So a jig to hold the logs, and 3 passes with the swing-blade and we had a useful post, and we actually got decent production. But most species / logs you might want more like 12"+ dia to start getting much useful wood and decent production.
Don't worry too much about a log deck and supports for the mill up front. Set it up on the ground and saw out some heavy bearers to support the mill up off the ground, and build some sort of log deck etc. You will get plenty of low grade logs that can be sliced up into posts / sleepers etc.
Offline DDW_OR
« Reply #10 on: August 08, 2017, 01:23:54 am »
Useful sawmill mods
http://www.forestryforum.com/board/index.php/topic,7789.msg1397352/topicseen.html#msg1397352
start small with the ability to upgrade the mill.
Hydraulic log rotator, toe boards, log stops are nice.
also are you going to be doing any firewood?
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline mike_belben
  • Pulp Friction
« Reply #11 on: August 08, 2017, 01:11:39 pm »
Im curious what youll say, can we suppose he said yes to firewood operation?
I have lumber and wood processing in mind for the future and would appreciate suggestions
Offline DDW_OR
« Reply #12 on: August 08, 2017, 03:34:40 pm »
all lumber operations have 4 "products"
dimensional lumber
usable scrap
sawdust
bark
have been thinking of a wood pellet mill to make the sawdust into pellets
need to do more research.
maybe use a hammer mill on the bark, then mix with sawdust, then feed into the pellet mill
Offline Candlex
« Reply #13 on: August 08, 2017, 06:41:37 pm »
Thanks all for the reply's and thanks for the mod list.
Yes i plan on fire wood as well. Like i said i hate to waste wood. I have a basic understanding on how wood processors work. I did look into peletizers and they are pricey, but some people build their own. Basically you need the die, the roller, and a motor. Not too bad to build if you can find the parts. Sawdust pellets are nice but you would have to bag or bucket it to keep it genuine, as I know smokers use them and they want only oak or hickory apple etc.
Also, they sell an outdoor furnace that uses pellets that has an auto feed. That would be great. It would pay itself off in a few years just by you recycling.
One of my co-workers is pushing to do firewood with me. So i should hopefully have him running it while i saw.
I think the little kohler power plant will be fine on the 126. If i was to upgrade id go to a Chinese knockoff diesel.
I should be building most of it all this winter. So ill make sure to put up all my plans
Most of our trees are 30 ft tall so you figure 10ft boards then the rest firewood. I'd rent a chipper and do all the branches at once and make a nice trail around the property.
One of the nurses i work with had an old mill when he was younger so he said its not so bad. He has a ton of cedar he wants me to mill. Tbh what scares me now is the kiln portion. I bought a 5 gallon bucket of anchor seal 2 from csp or something. So i figure ill start cutting and storing first off.
Ive been laid up from an ankle surgery for 3 months and finally getting my ankle jail off tomorrow so. Lots of work to do.
Offline Candlex
« Reply #14 on: August 08, 2017, 06:47:19 pm »
Ankle jail
Offline DDW_OR
« Reply #15 on: August 08, 2017, 09:00:55 pm »
glad you are getting out of ankle jail.
also look at the firewood processor from Woodland Mills
http://woodlandmills.ca/us/product/woodland-firewood-processor/
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #16 on: August 08, 2017, 09:22:27 pm »
That looks a might painful.  What did you do to that lower limb.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline thecfarm
« Reply #17 on: August 08, 2017, 09:55:16 pm »
I betcha that slowed you down some.  :(
Offline Candlex
« Reply #18 on: August 08, 2017, 11:04:22 pm »
Four wheeler wreck in 2014. Arthritis got in the fractures and ate the bone up. Found it by accident at work testing the magnet.
Offline Candlex
« Reply #19 on: August 10, 2017, 11:27:54 am »
Survived surgery.
I looked at that wood processor. Thats a lot of money for a manual chainsaw. I dont mind building no precision things.
So all of those types ive seen run a ram into an adjustable stop. A saw comes down and cuts. The log falls into a lower trough. Then another lower ram pushes it through a die. You can make the die move up and down as well to adjust to log size. Then they usually drop out on a conveyor or just on the ground.
If you were to pay 6k for a processor and were able to sell oak woods at 100 a rick. You would need to sell almost 75 ricks to pay it off. But if you build a homebuilt with hydraulics it would be more feasable.
Ill draw something up. But you basically need a reservoir, pump, engine, 2 big rams, 2 small rams for saw and adjustable die. Runing auto return valves would save a lot of time. A conveyer setup which that one looked like they used a skid steer belt and an electric motor. I think a steel mesh would be stronger.
Also a hydrualic set if rams for loading and a chain roller setup would be super sweet.
