Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Air Drying When Temps Are Freezing  (Read 1038 times)
Offline GF
    • Twisted Oak Sawmill
« on: December 20, 2004, 06:48:17 am »
Are there any problems or concerns air drying newly sawn red oak when temperatures go below freezing?   ???
Home built bandsaw sawmill with 31hp v-twin, Cooks Catclaw Sharpener, Cooks dual tooth setter, John Deere tractor, 35 ton splitter, and home built firewood processor.
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
Re: Air Drying When Temps Are Freezing
« Reply #1 on: December 20, 2004, 06:54:47 am »
The Red Oak will dry but very, very slowly. The area that dries the most will be the ends. I have never air-dried Red Oak but I would guess that you could see some end checks.
Offline Chet
« Reply #2 on: December 21, 2004, 08:50:12 pm »
GF,
I have found that I actually get better results with red oak if the drying process is started in cold temps, thus slowing the initial drying rate.  As Den stated, you can air dry red oak too fast, causing surface and end checks.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline tomtom
« Reply #3 on: December 22, 2004, 06:25:56 am »
I cut in freezing temperatures , the comment that air drying red oak in frosty weather will bring your moisture down slow is correct. My understanding is that most damage occurs above 20% moisture. Most end checking has already started in the log unless it has been end coated fresh cut. I cut pine and hard maple an air dry under cover in a shed. I still like to have it kiln dryed before the summer heat hits. This reduces sticker stain , and fugus stains. Hope this helps . MC&AHNY      TOM  :)
Offline GF
« Reply #4 on: December 22, 2004, 06:30:53 am »
I just was not sure if there would be a problem with the moisture in the boards freezing, and causing more problems.
Offline JohnnyF
« Reply #5 on: December 22, 2004, 11:52:08 am »
You will also get some drying effect from sublimation.  It is still slower but some is better than none.  Good luck!
Offline Norm
  • What's for supper!
« Reply #6 on: December 22, 2004, 01:11:11 pm »
I wondered the same thing too GF the first year I tried it. I've done it for two years now and have not noticed any difference from wood air dried during the rest of the year.
I'm thinking of marketing it as freeze dried lumber. ;D
WM LT30HDD-E25
Offline woodmills1
  • the truth shall set you free
« Reply #7 on: December 29, 2004, 05:00:42 pm »
You won't get the surface checks that happen in the hot sun of summer.  Oak doesn't like direct sun at all.  In winter it is important to keep the top of the pile covered to keep the rain and snow off.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Saw Anywhere!
