Author Topic: Ram water pumps  (Read 3230 times)
Offline pabst79
  • The irons have melted
Ram water pumps
« on: February 22, 2016, 07:54:33 pm »
 I'm trying to find out what size pump I need to build, along with size of discharge piping etc. I read through many old posts, but most of the links are no longer valid. I'm curious if any forum members have first hand knowledge of a good working design? I'm trying to keep a pond full that is about 450' away from a creek by my house. The difference in elevation is about 8', but I could dig in the discharge line to lower the amount of head. The web has tons of schematics, but they vary greatly and I would prefer to build this once. :)
4th Generation Plumber/Fitter who moonlights in too many hobbies to master any, 2 little girls are a blessing and ensure that a new mill may be a few months...years away.
Offline landscraper
  • LT4H0DD47. Dyna SC14.
Re: Ram water pumps
« Reply #1 on: February 22, 2016, 08:00:28 pm »
Go to the website for Rife brand ram pumps, the way I remember that had all the design and sizing info on the website.
Firewood is energy independence on a personal scale.
Offline pabst79
Re: Ram water pumps
« Reply #2 on: February 22, 2016, 09:09:43 pm »
Thanks, some good drawings on there. My problem is that the creek is the lowest point on the property, so the pump would be level with no fall. I remember seeing a diagram of a pump that sat right in the water, I believe in a fur fish n game a few years back. I suppose I could call one of the engineers at Rife, but I don't know how much I want to spend without knowing if it will work first. I was thinking of making a cheap one out of pvc, if it works then spend some $ on a big proven pump.
Offline pineywoods
Re: Ram water pumps
« Reply #3 on: February 22, 2016, 10:06:56 pm »
You will likely have to dam up the creek enough to give you 3 ft or so of head. The university of NC web site has a bunch of info on ram pumps.
100k bd ft club
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Ram water pumps
« Reply #4 on: February 23, 2016, 04:38:44 am »
You will need about a 20 foot run of pipe to give you the ram efect. I'm a collector of old rams.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline landscraper
Re: Ram water pumps
« Reply #5 on: February 23, 2016, 07:58:37 am »
Are you talking about a sling pump instead of a ram maybe?
Offline pabst79
Re: Ram water pumps
« Reply #6 on: February 23, 2016, 08:58:10 am »
Sling Pump, Maybe? Its been 6 or 7 years and of course I saved the article, but can't find it. :D
Kbeitz, awesome collection!
I'm wondering if I bury a plastic or steel tank with ballast to get my 4 or 5 feet of fall, that should work eh? If I dam up the creek, the DNR might not be amused. They just released Elk a few miles from me, and the DNR is on heavy patrol, flying etc.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Ram water pumps
« Reply #7 on: February 23, 2016, 05:01:01 pm »
You have to have head. Your Barrel will just fill up then your head is gone. If you have some flow, you can use more pipe, this acts like having more head, as long as there is enough flow to close the clacker.
    • My homepage
Re: Ram water pumps
« Reply #8 on: February 23, 2016, 05:03:03 pm »
It's hard to convey typing on the stoopid phone. Your situation is tough, but might be workable.
Offline pabst79
Re: Ram water pumps
« Reply #9 on: February 23, 2016, 05:12:49 pm »
 My idea with the buried tank would be to keep the pump there, the tank would be dry, but I have no idea if I could get enough drop, I was looking at drawings from the UNC website that showed putting a inlet pipe in the creek and then the pump assembly about 6' feet lower in a ditch, then piping about 100' to a irrigation trough. The tank I would bury would have sides that stick above grade, and a top to keep rain out, in theory it would be just like the drawing with the pump in a ditch, the tank being my ditch. Or am I misunderstanding the drawing and or principle of the ram pump?  :-\
Offline pabst79
Re: Ram water pumps
« Reply #10 on: February 23, 2016, 05:26:11 pm »
Okay, I see in another diagram that there is a waste/dump valve on the pump, which means I would have to keep a solar or deep cycle 12v sump going to keep the tank from flooding, I could spend a bunch of time and money and still be ahead of what a windmill setup would cost. I got a quote from Aeromotor and it seemed insane for keeping a pond full.
    • My homepage
Re: Ram water pumps
« Reply #11 on: February 23, 2016, 06:36:16 pm »
You could just pump the water to the pond if you were going to try and keep that tank empty. The way a ram works is the water flows through it until the velocity builds enough to close the clacker, then it sends a shot through the check valve to whatever you are pumping to. The more head you have, either true vertical, or from the length of the infeed tube, and you can actually coil up a bunch of plastic pipe to lengthen the head, the more force on the output pipe when the clacker closes. This is due to the length of the column of water in the infeed pipe times the speed of the column.
Offline landscraper
Re: Ram water pumps
« Reply #12 on: February 23, 2016, 06:45:49 pm »
Extending the drive pipe is probably a better option than digging the pump down to create head. Put a strainer on the drive pipe inlet and keep it clean.
A sling pump works by laying in the creek water and being rotated by the flow of the creek.  You need some depth and flow for it to work, but not gravity head in the same sense as the ram pump.  There's plenty of videos on utube.
Offline Ianab
Re: Ram water pumps
« Reply #13 on: February 23, 2016, 06:48:23 pm »
Expect to be dumping about 10X the water you pump out the drain, so for every gallon of water you pump up the hill, another 10gal will spill out the overflow and need to drain away.
Now if your stream has a bit of drop over it's course though your property, you can build a small weir (one the doesn't block off fish movement etc) and run a pipe down the stream bed until you have gained enough head to lift it up to the pumps position on the stream bank. The waste water then just runs back into the stream.
But you need "some" head for the ram to work. But what it allows is for a 10ft drop in a stream to pump water 100ft up to where it's needed, basically for "free". The energy needed to pump the water is created by the larger volume  dropping the smaller distance to the pump. Each time the valve slams shut you get a "water hammer" effect, and can use that to pump water to a considerable height.
The water flow may not be high, but it's constant, 24 hours a day.
Offline pabst79
Re: Ram water pumps
« Reply #14 on: February 23, 2016, 07:19:24 pm »
 Thanks for all the info, I will scrap the tank idea. Ianab, I'm going to get my transit/laser out this weekend, I believe there might me about 3 or 4' of fall from the property line coming towards the house in regards to the creek. There is a small dam/waterfall with about 4' drop, but its 30' off my property and on State forest land, so that's out. Somehow I gotta make it work, the pond was full for about 2 wet years, the last 6 its been more of a puddle than a pond, it just moves with the water table, and I'm in sand country so a shopping cart might hold water better.  fiddle-smiley
    • My homepage
Re: Ram water pumps
« Reply #15 on: February 23, 2016, 07:37:48 pm »
You are doing better than the town of Sheffield. From where it enters town, to where it leaves, the Housatonic river drops 13.5 feet in about 5.5 miles, or about thirteen miles as the river flows.
Offline Kbeitz
    • My Hobbies
Re: Ram water pumps
« Reply #16 on: February 24, 2016, 03:42:02 am »
You could make a small water wheel and use it to drive an old piston pump.
They will work even running real slow.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline Ianab
Re: Ram water pumps
« Reply #17 on: February 24, 2016, 04:23:08 am »
True, an undershot water wheel can run with only a couple of feet of head.
Offline Kbeitz
    • My Hobbies
Re: Ram water pumps
« Reply #18 on: February 24, 2016, 09:45:06 am »
This is my over shot wheel. I only have about 3-4 feet of head. But with a 1-1/2" pipe I cant stop it from turning with my hands.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
Offline pabst79
Re: Ram water pumps
« Reply #19 on: February 24, 2016, 08:25:26 pm »
 I will try and get some pics of the creek and and creek bottom posted soon, I know pics may better show my obstacles, and you experienced folks might have some ideas. 60 years ago they tried growing cranberries on my 80 acres, the ditches surrounding the property were water filled, from the creek, which is 8'-20' lower in elevation, without the use of electric or gas pumps, so I know somehow I can get the DanG pond wet!
