Author Topic: lincoln welder generator  (Read 1732 times)
Offline dustyhat
« on: October 18, 2015, 09:54:48 pm »
My welder/ generator started making a loud buzzing humming sound when i use the power. such as using grinders, drills etc. can anyone diagnose my trouble.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline r.man
Re: lincoln welder generator
« Reply #1 on: October 19, 2015, 08:56:55 am »
Does it make that noise when you are welding?
Offline dustyhat
« Reply #2 on: October 19, 2015, 07:08:53 pm »
seems to weld fine,  just makes the loud sounds when i power up my grinder or drill etc.
Offline dhp3228
« Reply #3 on: January 12, 2016, 10:04:03 pm »
Take an armature stone to the exciter armature and clean it off. While your at it clean off the main armature as well. I'd bet that noise is coming from your brushes. Your local welding supply should have the stone if not I can recommend a few websites.
Offline fishpharmer
« Reply #4 on: January 12, 2016, 11:41:19 pm »
Dustyhat, I cannot help you. I want to welcome dhp3228 to forestryforum!
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline dustyhat
« Reply #5 on: January 13, 2016, 03:20:50 pm »
Thanks , dhp3228, i had that done and all is good now. welcome from me also.
Offline dhp3228
« Reply #6 on: January 26, 2016, 09:23:26 pm »
Your welcome and thanks for the greetings. I'm a welder by trade and have made my living running Lincoln Welders like what your talking about for the last 5 years they are great machines.
