Author Topic: What are you working on?  (Read 28550 times)
Offline rasman57
  • Location: Manistee National Forest Pine River Michigan and Home in Illinois
  • When you come to a fork in the road...take it.
Re: What are you working on?
« Reply #200 on: September 19, 2017, 06:19:39 pm »
That is very nice.  Great work!
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #201 on: September 19, 2017, 07:38:03 pm »
 I'm finishing the 12x16 Sobon Shed and giving it to my mother for her Kubota RTV and her new lawn mower. I'm going to raise it at a local fall festival next month as a demonstration.
    • My homepage
« Reply #202 on: October 27, 2017, 08:02:06 pm »
I'm just about finished with the cherry sills for the shed. Going to try to get them set tomorrow. I made these 2" thick, but next time I am definitely going to go 3". Cutting through mortises near the ends really weakens the sill. I drilled pilot holes and ran 8" headloks in the ends.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #203 on: October 27, 2017, 08:48:58 pm »
Raised two bents. It snowed towards the end of the day. Felt good going vertical. I am using a telehandler for raising and am surprised how well its working giving the lack of swing.
Offline flyingparks
« Reply #204 on: October 28, 2017, 10:45:52 am »
Dave, This joint confuses me.
[/quote]
    • My homepage
« Reply #205 on: October 28, 2017, 11:24:18 am »
The top piece is a long sill with a stub mortise. The notch is a cog to locate the end sill. The two lower pieces make up another long sill. There is an elaborate, and unnecessary, scarf joint around the bent II post stub tenon.
Half the scarf. You can see blue lumber crayon where the stub tenon goes.
Offline flyingparks
« Reply #206 on: October 28, 2017, 12:14:03 pm »
That is so cool
    • My homepage
« Reply #207 on: October 28, 2017, 12:36:04 pm »
 First loose fit up on the slab. There will be an 8" Headlok on either side of the scarf.
    • My homepage
« Reply #208 on: October 28, 2017, 06:37:56 pm »
Sills are on, bents are up.
    • My homepage
« Reply #209 on: November 08, 2017, 03:55:56 pm »
Hewing rafters for a barn repair.
Offline logman
    • M&K Timber Works
« Reply #210 on: November 10, 2017, 11:23:40 am »
Finally put up this 36x96 douglas fir event barn.
LT40HD, 12' ext, 5105 JD tractor
M&K Timber Works
Offline rjwoelk
    • countrysidefirewood
« Reply #211 on: November 10, 2017, 12:00:43 pm »
That is a nice event barn. Looking for more pics
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline logman
    • M&K Timber Works
« Reply #212 on: November 10, 2017, 07:28:26 pm »
It's probably just me but I find it an ordeal to post pictures on here.
M&K Timber Works
Offline flyingparks
« Reply #213 on: November 10, 2017, 07:29:45 pm »
Thats a fine looking structure. Maybe it's just us...
Offline logman
    • M&K Timber Works
« Reply #214 on: November 10, 2017, 07:40:19 pm »
Thanks, I only meant that I find it hard to post pictures.  I usually end up putting the same picture in my gallery a few times before I get it on my post.
M&K Timber Works
Offline thecfarm
« Reply #215 on: November 12, 2017, 01:33:38 pm »
I myself find it's much easier to post pictures on here than build an event barn.  ;)   :D
Offline Dan Miller
« Reply #216 on: November 12, 2017, 06:11:25 pm »
A little project I've been working on. It is the woodshed from the small buildings TFG book, designed by Will Beemer. Simple looking building, bit of a PITA to build, particularly solo. Plus, my framing skills got a bit rusty since finishing my shop, so don't look too closely.
Will finish the rafters once I sort out why the shop heater is working properly.
Offline flyingparks
« Reply #217 on: November 14, 2017, 10:03:40 pm »
Bent C is now up...the tallest one. I clocked 150MPH winds last week. My big ponderosas were swaying like crazy but the frame wasn't moving a hair.  8)
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #218 on: November 20, 2017, 02:34:45 pm »
Great work, guys.
Logman, that event barn is fabulous!
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
