Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Tree Felling  (Read 2484 times)
Offline abeyanko414
  • Osama Bin Laden: Executed by means of chainsaw
Tree Felling
« on: September 24, 2004, 10:09:24 am »
Ok folks, now be nice to me on this one, I am just looking for some clarification.
I am by no means what most would consider a "seasoned" sawyer. But I have cut down a lot of trees and seen a lot cut down. And since I can first remember I have heard the dangers of the tree "kicking back" or "kicking out", ect. However, I have never once seen it happen. I have been told how it happens, why it happens, how to be safe about it, ect, ect... I have also gotten a lot of conflicting theories....
What is some input you folks could offer me.
Offline leweee
  • Illegitimus non tatem carborundum
Re: Tree Felling
« Reply #1 on: September 24, 2004, 11:28:52 am »
Read the "Scary Tree" post on this forum ... ;D
Offline Ianab
Re: Tree Felling
« Reply #2 on: September 24, 2004, 02:55:19 pm »
Hi Abeyanko
I'm not an expert either, but I think what you are talking about is the butt log bouncing back past the postion of the stump. More common in heavily branched 'springy' trees or on rough terrain. The tree hits the ground and the branches act like springs and push the tree back toward the stump. Not a good thing if you are standing there  :o. Thats why it's recomended you walk clear of the stump at a 45 deg angle as soon as the tree starts to fall. Hopefully the butt just hits the ground in front of the stump, but it could roll to the side or bounce back toward the stump.. or even both. Being safe means planning for things that MIGHT happen :P
This log has kicked back a couple of feet over the stump, and could also have rolled off if I had been unlucky. Dont worry I expected this to happen as it was falling uphill. I was 10ft away behind the next tree when it hit the ground ;)
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Re: Tree Felling
« Reply #3 on: September 24, 2004, 03:15:34 pm »
A log will slide back over the stump if you make your back-cut even or below the apex of the notch.  If you will cut to the hinge above the apex of the notch, that little bit of a lip will often times catch the tree and keep it going forward.
If you cut through your hinge the tree can do all kinds of strange things.  You lose all control.
If the notch is too narrow it will close before the tree breaks the hinge.  that stops the log from falling but the top is still trying to go to the ground.  That's  what causes a Barber Chair.   The top exerts too much pressure on the log and it splits right up the middle.
A friend of mine got his head caught in the split of Barber Chair once.  DanG near Killed him.  He, nor anyone there is quite sure how it happened.  The tree split and he reached in with the bar to cut some of the hinge and the tree began falling.  The split closed and his head was in there. The tree started falling but didn't fall all the way down.  It knocked him silly, almost tore his ears off and skinned him up pretty good.  His brother  began relieving some of the stress by cutting the split part above his head.  They were lucky that he was able to relieve enough pressure for them to get his head out of the crack. By all rights he shouldn't be here today, and he knows it.
Offline Oldtimer
  • Anyone ride sleds?
Re: Tree Felling
« Reply #4 on: September 24, 2004, 08:47:54 pm »
In winter, if you don't back-cut a hardwood fast, (and have the heart bored out in good order!) it can split like Tom said. And, it can send the "outer/uppper" portion flying out and up into the air...taking you with it if you are not careful! Ash is a great one for this. It could easily kill you if it hit you right.
My favorite things are 2 stroke powered....
My husky 372 and my '04 F-7 EFI....
Offline rebocardo
  • Atlanta GA
Re: Tree Felling
« Reply #5 on: September 24, 2004, 10:19:55 pm »
re:kicking back
I have seen trees bounce pretty good with the butt going up into the air, especially ones that are all branches,  once they hit the ground. So I could see one bouncing back towards the stump and over it, especially on a low stump. I have had them jam back into the stump pretty good too. Once I cut a water oak that bounced and then the trunk (36 dbh) split in 1/2 so it was over 7 feet high on the ground.
Offline Ron Scott
    • Ron Scotts Web
Re: Tree Felling
« Reply #6 on: September 25, 2004, 01:57:48 pm »
I had one of my fallers injured quite bad from a "kickback" while we were working some mountain sides in West Virginia years back. A yellow poplar caught him breaking ribs, puncturing a lung, etc.
He had to be carried out to an ambulance and spent a couple weeks in the hospital. It was some time before he was able to get back to work. Awareness is always needed for possible "kickback".
~Ron
Offline Ed_K
Re: Tree Felling
« Reply #7 on: September 25, 2004, 05:54:21 pm »
 In my younger day,before getting smart  :-[, I watched a 14" white birch fall into a forked oak. I was standing next to the stump. Before I realized what was happening it jamed my foot into the stump  :o. Broke every bone from the toes to ankle, one was broke in 5 places  :'(. I now bore cut almost all of the trees, so I can WALK away from it before it falls. I back cut only when I know I can cut to the hinge quick, and still move away before it falls.You never know what a tree will do as it hits the ground. Especialy brushy ones.
Ed K
Offline abeyanko414
Re: Tree Felling
« Reply #8 on: September 25, 2004, 08:53:47 pm »
appriciate all the input
I understand it a bit better now.
Thanks....
Offline Engineer
    • BLAZE Design Inc
Re: Tree Felling
« Reply #9 on: September 27, 2004, 05:04:45 pm »
Not a pro, but I have been dropping trees for half my life.  Best lesson learned, is never take any tree for granted, even one that's dead straight and in the middle of a field.  I have gotten to the point where, nine out of ten trees fall within a few feet of their intended resting spot, but it's always the tenth tree that hangs, barberchairs or gets rolled or blown out of target.
Worst experience I have had so far was a big forked ash tree, fork was right about eye level and the only way to drop it was to put each fork down opposite each other.  Well, I managed to notch and backcut one side, and it started to drop, and then I realized that the tree was being held up by a giant wild grapevine.  It was then that the wind came up and leaned that critter right back onto the other fork.  Only thing that saved a really big mess was that I managed to cut a nice even hinge.  We wound up cabling the two halves of the tree together and I dropped both halves the other way after cutting the grapevine out.  That vine wound up tearing off half a dozen widowmakers on the way down.
On the other hand, yesterday I was cutting some more trees around my house site and I got full of myself, and drove a stake in the ground about thirty feet away from a 14" dbh ash I wanted to cut.  Told my dad I was gonna drive that stake in using the tree trunk, and he started laughing.  Well, I was proud of myself 'cause I put that tree right on top of the stake.  ;D
Lucky I guess.  One of these days I'm gonna forget to move my truck and wind up with branches in the cab.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
R. J. Wiedemann LtCol. USMC Ret.
Offline DanG
Re: Tree Felling
« Reply #10 on: September 27, 2004, 07:02:00 pm »
"Lucky I guess.  One of these days I'm gonna forget to move my truck and wind up with branches in the cab."
I done that one time, too!  :-[
Offline WV_hillbilly
  • Work can be shocking at times . Bellaire , OH
Re: Tree Felling
« Reply #11 on: September 27, 2004, 07:13:03 pm »
  Me too  DanG.   But i only put  it across the bed of the truck . It was one of those DanG grape vines that caused it to roll out about 120 degrees to the left .  My dad  was probably  500 yards away and he came fast to see what the ruckus was about . A new used bed and all was fine . The plus I quess was I didn't have far to carry the firewood that day .  ::)
Hillbilly
Offline DanG
Re: Tree Felling
« Reply #12 on: September 27, 2004, 07:35:36 pm »
Well at least you had a grapevine to blame it on.  Mine was just too easy. Pine tree was limb-heavy in just the right direction, with at least 150 degrees margin of error. Problem was, it was so easy, it didn't appear to require any thinkin', so I didn't do any.  I put the DanG thing right where I intended, but didn't figger on those big ol' stout limbs. Didn't figger how long they were, either. They didn't look all that big when they were 75' up in the air. Anyway, the limbs hit the ground just as the tree released from the stump, and took a big rolling bounce to the right. One limb crunched the truck door, costing me a severe tongue-lashing from my better half, whose truck it was. :-/
Re: Tree Felling
« Reply #13 on: September 27, 2004, 07:46:33 pm »
  I did learn something that day . I don't park any of my equipment anywhere near the felling area . I have learned alot since that happened 17 yrs. ago . Alot of it has come from the words of wisdom on here . I have just started using wedges in the last year . I have been Practicing on small cull trees . I have cut some leaners with out barberchairing them also lately using the plunge cut method then cutting the holding strap .
Hillbilly
Hillbilly
Offline DanG
Re: Tree Felling
« Reply #14 on: September 27, 2004, 07:54:56 pm »
Same here. That plunge cut is a neat trick. I've been using it on some of these uprooted hurricane trees, too. Many of them are "bridged" from the rootball to the branches, making them hard to buck without pinching your saw. The plunge cut sure makes it a lot easier. :)
Offline rbarshaw
  • Someday
Re: Tree Felling
« Reply #15 on: October 04, 2004, 07:35:09 pm »
I was felling a 18" dbh SYP several years back and realized my tractor was too close, so I moved it out further and away from where I expected it to fall. Yep' you guessed it, it fell right across the engine of the tractor, just lucky it was the top small branches and only did some sheetmetal damage.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Offline leweee
Re: Tree Felling
« Reply #16 on: October 05, 2004, 09:06:47 am »
Park them vehicles away from the work site. ;D
& spectaters ::)
Offline bighoss550
Re: Tree Felling
« Reply #17 on: October 05, 2004, 03:57:10 pm »
thats some impressive carnage!!!!!!!!!!! 8)
too bad theres not a video of that occorance:)
Offline Ed_K
Re: Tree Felling
« Reply #18 on: October 05, 2004, 05:48:29 pm »
 If you run into a double bole at eye height, try this. I determine the two directions of fall, and notch accordingly. I then bore cut from back of one hinge to the other. I then cut straight down from the crotch, watch carefully as the trees start to split, move out of the area at 90*.
Ed K
Offline Kevin
    • The Milling Masters
Re: Tree Felling
« Reply #19 on: October 11, 2004, 10:50:46 am »
Ed;
That sounds a little risky to me.
I would prefer to fall one at a time providing the branches weren't intertwined or fall both in the same direction at the same time.
Saw Anywhere!
