I think Accuset is a real asset on the models with the Command Control option. It would not be possible to read the scale stick on the sawhead. Also, if you’re doing a lot of pattern sawing – as in making board out of the outside of a log and making a RR tie, post, or resaw cant out of the middle.
Once you get the hang of programming Accuset (made a lot easier in the newest revisions) and get comfortable at pokin’ the buttons when you need and want to, I’d say it speeds up the sawing rate around 10%. Maybe more.
The Accuset has a lot more feature and works on a different principle than the Simple Setworks.
I posted some notes on running the Accuset on the Knowlege base. In case you'd like to read more ..
Using the Wood-Mizer Accuset Setworks
I fixed the link so now it works ...
