Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: popular blades  (Read 2518 times)
Offline Swede
    • Maskin & Tryckluft
Re: popular blades
« Reply #20 on: September 19, 2004, 08:40:52 am »
iain;  I pay
35 x 0,90 x 4267 mm  TD 25 tpi    SEK. 227,93/st
32 x 1,00 x 4267 mm  TD 25 tpi    SEK. 222,07/st
+VAT and freight
Euro 1~SEK. 9.20
If You want to buy 25 blades or more I can get a better deal and send them to You.
Swede.
Had a mobile band sawmill, All hydraulics  for logs 30\"x19´, remote control. (sold it 2009-04-13)
Monkey Blades.Sold them too)
Jonsered 535/15\". Just cut firewood now.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: popular blades
« Reply #21 on: September 19, 2004, 11:33:19 am »
 Hey Swede, could you convert that to US $$$$ ???  I would like to do a little research.
Offline Swede
Re: popular blades
« Reply #22 on: September 19, 2004, 12:16:51 pm »
Fla._D.
$1~ SEK. 7.45
So I pay ~ $ 30 for one Swdeish blade in Sweden  >:(
Swede.
Re: popular blades
« Reply #23 on: September 19, 2004, 12:31:03 pm »
  Can you give me your blade size in feet and inches, Swede
Re: popular blades
« Reply #24 on: September 19, 2004, 12:42:21 pm »
It looks like 168 inches, Harold.
http://www.onlineconversion.com/length_common.htm
If that is 25 teeth per inch, it's a lot of teeth for the band.
If that is 2.5 teeth per inch, it's still a lot of teeth.
Offline Swede
Re: popular blades
« Reply #25 on: September 20, 2004, 02:44:16 am »
Widht of my blades: 1 3/8"
Thickness:               0,035"
Length:                    168"  0r 14'
.....and 1 teeth/inch
I don´t know why they wrote the way they did in the e-mail, perhaps lack of language?   :D
Swede.
Offline iain
  • bonnin stuff
    • Leafbone Furniture
Re: popular blades
« Reply #26 on: September 20, 2004, 03:27:16 pm »
woody uk have just started a resharp service $142.25 per box of ten door to door as compared to $340.4 per box of ten new
going to drop them 54 blades on friday at the apf show saves $126.50 in postage for starters 8)
i got a woodys sharpener works good
but its the setting that narfs me off >:(
   iain
Offline iain
  • bonnin stuff
Re: popular blades
« Reply #27 on: September 20, 2004, 03:30:02 pm »
sorry for missing you out sweede i will prob take you up on the 25 or more
i got some friends heading to norway soon that a help in the sending?
iain
Offline Swede
Re: popular blades
« Reply #28 on: September 20, 2004, 05:09:02 pm »
iain;
That will be the cheapiest Monkey blades You ever got! Tell me 3 weeks or more before Your friends are here. I have to find out how to handle VAT.  ::) , I don´t want You to pay 25% extra if You don´t have to.
The setting is 1 right, 1 left, 1 not set. I use to choose a length according to pitchx3.
(ex.: 25,4x3=76.2
4267:76,2=56 groups)
Swede.
Offline Log-ic
    • log-ic mobile sawmill
Re: popular blades
« Reply #29 on: December 19, 2011, 04:34:20 am »
I had recently a quite interesting experience the last few days... So far I used bands which are approx 50mm wide, 1.1mm thick and 25mm tooth spacing (1").  When lastly I had to order new ones, my supplier told me the 1" tooth spacing were no longer available, and that only 22mm was available. (7/8 I think).  I was rather sceptic bacause I always order per 20. In case they would not perform well that would be quite a waste.  With the 1" bands I could saw about a half day when new, but after a few sharpenings that reduces to approx. one or two hours because the hardened tip has gone.
Anyway, I tried with a 22mm band and to my surprise it continued to cut straight and well for a whole day!  I must say that now the days are very short here, (and cold) but they still did cut well for more then 6 hours..  I then sharpend the tips, grinded the gullets with a dremel, and could again cut for a whole day!  I would never believed before now that such a "small" difference in tooth spacing could make such a difference.
At least, there is no other parametre that has changed. Same supplier, same steel (Uddeholm Sweden), same set and same hook angle (10°).  Even the price of 28 Euros ex vat was almost the same. It must be said that with the 1" tpi bands there were 224 tooths, while the 7/8 tpi configuration gives 261 tooths for th same band length.  That must considerably reduce the stress on each tooth, but I am still amazed about the effect...  I was always in the meaning that less tooths should result in higher feed rates and more production but my recent experience seems to prove the opposite..
Pezzolato Timber Queen HD8 + 2 extention tables
Two Prins all-terrain forklifts
Loroch JLM-V sharpener, manual saw setting pliers
Logrite Buck arch
Husqvarna , Stihl and McCullcoch chainsaws
Landrover Rangerover P38 Turbodiesel + flat deck trailer
Saw Anywhere!
