Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: EPS Foam  (Read 535 times)
Offline Tom_Averwater
  • Semi- retired Carpenter
EPS Foam
« on: August 17, 2004, 07:07:36 pm »
I have access to some aluminum skinned foam panels with eps foam for the core. Is the eps ok for kiln walls ? I think someone said that it absorbed moisture  too much.                         Thanks Tom
He who dies with the most toys wins .
Offline Don_Lewis
  • dry kilns, heat pumps
    • nyle
Re: EPS Foam
« Reply #1 on: August 21, 2004, 06:38:54 am »
Aluminum skinned EPS panels almost always fail when used in kilns. The aluminum expands and contracts and then comes unglued from the foam. However, foam-in-place urethane insulated panels stand up well but stainless steel is better than aluminum because of the big difference in thermal expansion. Glued aluminum/urethane panels should be avoided just like  the EPS /aluminum panels. We did an aluminum urethane glued panel kiln once about 15-20 years ago and after a few months the skins peeled off like a banana. The whole thing had to be redone. We use glued up panels in doors but they are completely framed so that we are not depending on the glue. The glue always lets go over time.
Saw Anywhere!
