Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Dangerous stuff... Jeff bought an old chainsaw  (Read 2575 times)
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« on: July 24, 2004, 04:02:44 pm »
Yep, its not a good thing cause I dont know nothing about them 'cept I like old stuff.  :D
Could not pass this up for a 20 dollar bill. It came from an estate sale and seems to be well maintained. It says Sears, could it be an old clinton?  It turns over, has compression, chain looks almost new, inside of tanks are extremely clean although it does ahve some gas and bar oil in it yet.  I have not tried to start it.  Can you guys help me figure out what I have so I know what gas mix, etc, before I try to do anything with it?
Offline Chet
Re: Dangerous stuff... Jeff bought an old chainsaw
« Reply #1 on: July 24, 2004, 04:09:51 pm »
Most of dem old saws were heavy on da mix. Usually 16/1
Being a sears tool, it could be just about anyones. It looks very much like an old Diston I worked on for a guy.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Chet
« Reply #2 on: July 24, 2004, 04:12:23 pm »
Be careful if ya fire her up with dat side cover missing.
Offline SasquatchMan
  • Get it done.
« Reply #3 on: July 24, 2004, 06:17:37 pm »
 :o
Senior Member?  That's funny.
Offline Lewis Brander
  • Lewis with 1953 PM Rocket
« Reply #4 on: July 25, 2004, 02:26:47 pm »
Hi to Jeff B. Don't know for sure what your saw is but, if you want to go to Mike Acres website: www.acresinternet.com and click on the brouse saw tab and go to Craftsman, you might find your saw. If you know the model number you could find it easier. Give it a try. lonebear30....
My hobby is restoring old saw. Just because it's old, doesn't mean she can't run and look good again. Take care. Lewis Brander.
« Reply #5 on: July 25, 2004, 04:37:07 pm »
Well, Jeff B. I checked out Mike's site and the saw you have looks similar to a Clinton, model D-35, made in 1959. Have you checked Mike's site as yet? Take care. lonebear30.
Offline Bro. Noble
« Reply #6 on: July 25, 2004, 08:21:19 pm »
Jeff,
When you look up that site,  you might want to check out the Barkers too :)
« Reply #7 on: July 26, 2004, 02:40:42 pm »
Well, don't believe it's a Barker. According to Mike's site if its a Clinton (D-35) the oil mix ratio is 16/1 or 8oz. of oil/gallon of gas. Some of my old saws call for 16/1 and I run them at 32/1 mix using Mobil 1, MX2T synthetic oil. With the newer more improved oils that are made today, I have no problems running at 32/1 ratios and all my old saws seem to run just fine. Just note that I'm just starting and runnig occasionally, for people to see and not actually using them to cut wood. Although I think they would also work fine during that process also using that oil and mix ratios. Take care. lonebear30.
Offline Jeff
« Reply #8 on: July 26, 2004, 07:48:18 pm »
When I get a chance I'll check the saw closer for numbers. It looks now like maybe parts are missing. Chet says its missing a cover, but I cant figure out how it would have been on there.
Offline Michael
  • I have saws and parts.
« Reply #9 on: July 26, 2004, 09:53:20 pm »
I think it is a Power Products saw. Those were very strong motors and used in go karts of the bygone era. It does not look like it is missing any covers to me. Those old saws had the chain and sprocket hanging out for all the world to see.  Mike
If you need saws or parts I may be able to help.
Offline Dean Hylton
    • Washington Hot Saws
« Reply #10 on: July 26, 2004, 10:36:52 pm »
This looks similar to a David Bradley made for Sears after they bought them out. ???
Offline etat
  • Member*
« Reply #11 on: July 27, 2004, 07:56:53 am »
I'm guessing it's either a a Clinton, a Barker, David Bradley, or possibly an old Sears chainsaw.  ;D pretty sure it's not a Husky. :D
Offline Bro. Noble
« Reply #12 on: July 27, 2004, 08:07:07 am »
It's definately not a Barker-----Jeff has a Barker Rim Saw so I thought he might want to look at the Barker Chainsaws while he was at that site. :)
Offline Lenny_M
« Reply #13 on: July 31, 2004, 03:06:46 pm »
Watch your knuckles on dat spark plug :D
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #14 on: August 01, 2004, 07:21:46 am »
More JUNQUE  ::);) ;D ;D 8) 8) 8)  You've got the bug BAD!! :) :) :) :)
Offline SwampDonkey
  • Large Tooth
« Reply #15 on: August 01, 2004, 10:40:43 am »
 :D :D
I've got to agree with Lenny_M and Corley5. I bet you'll only touch that plug once when she's fired up.  :D ::)
Dirty Harry
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #16 on: August 01, 2004, 12:41:02 pm »
"Touching the plug"
Reminded me of when I was a teenager building a '33 Ford hotrod.
The old-timer mechanic dropped by and proceeded to put his hand on each of the flathead V8 sparkplugs, commenting, in turn, that's good, that's good, that's not as good, etc.
I tried it and jumped back so fast I almost dislocated my shoulder!  :D
-Doug
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
http://www.xmission.com/~sherwin/sawyer1.
Offline Corley5
    • Whittaker Farms
« Reply #17 on: August 01, 2004, 08:24:33 pm »
Reminds me of the time I inadvertantly touched one of the plug wires coming out of the mag on my JD 12A combine engine.  WOW :o :o :o :o :o :o :o :o  I can still feel the tingle ;D ;D  My Grandpa Bob never used an electric fence tester he'd just touch it.  He could hold on to it and say it wasn't working so someone else would try it.  I did it once ;) ;D ;D
Offline Jeff
« Reply #18 on: August 14, 2004, 07:11:08 pm »
It runs!  Chet tore it all apart the day before the pig gig. I mean ALL apart. Guess what? Chet and Mr. Spark plug made friends a couple times. :D
Offline Chet
« Reply #19 on: August 16, 2004, 06:31:53 pm »
Friends wouldn't be my first choice of words.
Saw Anywhere!
