Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: How do you clean your boards  (Read 951 times)
Offline rbarshaw
  • Someday
« on: July 18, 2004, 03:08:50 pm »
These boards right off the band mill have some saw dust left on them, it gets into everything when you handle them,Rather uncomfortable.
Do you do anything to get rid of it?
I've washed every board with a garden hose as it comes off the mill and that seems to work but, uses alot of water.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Offline Bibbyman
    • Warden Sawmill
Re: How do you clean your boards
« Reply #1 on: July 18, 2004, 04:20:30 pm »
I guess I've never had the urge to get all the dust off'n the boards to go to that much work.
Mary likes to pull the board off'n the cant and let it drop on the mill dragback table a good wack,  then she gives it a flip.  That knocks off most of the sawdust.  If the lumber goes to the broker,  he's never complained about a little dust.  If it's going to be sticked,  the wind will blow out any dust that's left and put more back in.
Sawing since '94
« Reply #2 on: July 18, 2004, 05:34:40 pm »
I iniitially do the same as Mary and instruct the off-bearers to do the same.   I have used a broom as I stack the wood.  I have also used a hose but don't like the idea of soaking the wood especially without the application of a fungicide.
Sawdust may mold and stain the board.  You will hear the stain called "shadow", dust stain" or "sawdust stain".  Sometimes it can be planed off of the board and sometimes it can't.  If you are handling construction wood, it may not matter.  If you are handling appearace wood (genereally high dollar) then it would be in your best interest to at least knock the sawdust from the board.
Offline UrbanLogger
  • Don't trash that tree . . . TREECYCLE!
    • Midtown Logging and Lumber Co.
« Reply #3 on: July 18, 2004, 06:23:11 pm »
I'm with Tom and Mary--bang that board around a little gettin it off the mill and then sweep each layer in the stack before laying the stickers down.
I'm especially careful to sweep if I'm stacking spalted wood.
Scott Banbury, Urban logger since 2002--Custom Woodworker since 1990. Running a Woodmizer LT-30, a flock of Huskies and a herd of Toy 4x4s Midtown Logging and Lumber Company at www.scottbanbury.com
« Reply #4 on: July 18, 2004, 06:32:32 pm »
One of those 200 mile per hour blowers that you use to blow your leaves over into your neighbors yard works pretty good too. ;D
Offline Bibbyman
    • Warden Sawmill
« Reply #5 on: July 18, 2004, 06:37:35 pm »
Probably a good shop vac would work well too.  Could set up a set of sawhorses and do one layer at a time and then flip the boards and do the other side.
Sawing since '94
Offline UrbanLogger
« Reply #6 on: July 18, 2004, 06:45:18 pm »
I'm with Tom again--blow it in the neighbors yard  :D :D
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #7 on: July 18, 2004, 08:29:06 pm »
Got a customer that I've sawed for 3 time now and he uses a broom.
Not my wood, so I hadn't given it any thought. :-/
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline Gipper
« Reply #8 on: July 18, 2004, 09:15:44 pm »
I use a thing I found at one of the box stores, Lowes I believe, that is similar to a garden spade, but not real sharp.  It is very easy to scrape the board by holding it at an angle and pushing it along the board.  Works real well on up to twelve inch boards.  Have also tried sweeping, but the scraper works better and does not take much longer.  I only do this for my own lumber, but recommend to customers they do it before stacking.  It definitely makes a difference in the looks of the lumber I have pulled and used.  Before pulling the board I also use the flip and bang method on the mill also.
Offline rbarshaw
  • Someday
« Reply #9 on: July 19, 2004, 08:39:23 pm »
 :)Thanks for all the replies, I thought I may have been going overboard by washing each board ;D.
Saw Anywhere!
