Get your Forestry Forum Hats while they last!
I sent my favorite Buck knive and had this process. I have not had to sharpen this most usefull cutting tool in over two years.
My only question was as to has any one used this process on a saw chain? Thanks for all the replies, Ken
However I have used this process and I will continue to do so.Ideally you want to send the chain and files as one item. Their is no disputing scientific documentattion!
I never have used this process on a saw chain. My question is, has any one used this process on a saw chain? On Rockwells scale of hardness a saw chain and teeth are on the average a 67. Most files are 72-75 on this scale. If the teeth were any harder you are getting close to carbide.Like I mentioned saw chain is rather soft material.
I feel like I fell in the middle of a spam post .
used this process on tool steels, D2, S7, Vanades 4, in a controlled experiment with out any improvements in tool life.
If some one does test this process, a base line needs to be established to compare against.
