Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Grease Job  (Read 2227 times)
Offline Kevin
    • The Milling Masters
Re: Grease Job
« Reply #20 on: May 02, 2004, 07:00:22 am »
Thanks Todd;
Did you see the picture in shopteachers link at the bottom of his last message?
Offline ToddC
Re: Grease Job
« Reply #21 on: May 02, 2004, 07:01:28 am »
I found it on the net I'll try and post a link to it
http://www.lislecorp.com/tool_detail.cfm?detail=218
Hope the link works. :)
Offline Kevin
Re: Grease Job
« Reply #22 on: May 02, 2004, 07:04:04 am »
That's different again.
A guy should have one of each.  ;D
They list Canadian Tire as a distributor, I can check there today.
Thanks again.
Offline Kevin
Re: Grease Job
« Reply #23 on: May 02, 2004, 04:08:07 pm »
I bought one like the harbor freight job but it didn't fit the fitting and they only had one size .
I'll try and get it to fit but I don't have high hopes of it working.
Offline Kevin
Re: Grease Job
« Reply #24 on: May 08, 2004, 06:46:58 pm »
I finally got the two grease fittings fed after two weekends and a few modifications!
Thanks for the help.  8)
Offline rebocardo
  • Atlanta GA
Re: Grease Job
« Reply #25 on: May 09, 2004, 08:16:00 pm »
I have one of those adapters, I got it at NAPA. Just snaps on the end of your gun and then you snap it onto the fitting. Works well for drag links and balljoints.Stands about 1.5 inches high so I doubt you could get it into a 1" space.
What you need is an adapter they use for Chrysler FWD cars. It was a cut out on a straight piece of tube and you just slide it right over the zerk from the side. The adapter is only about 1/2 an inch tall. Only draw back is on a clogged up zerk you can not get enough pressue through it to open it up.
Offline Kevin
Re: Grease Job
« Reply #26 on: May 11, 2004, 05:26:25 am »
The tip I bought has a slot in the side where it fits over the fitting.
It has a nylon surface that slides over the top of the fitting but the one I bought didn't fit so I had to grind out the nylon, fabricate a new surface with plastic and even then the only way it would work is with a rigid tube from the gun.
What made matters worse is I had to stand on my head, hold a flashlight and grease the fitting all at the same time.
Offline Furby
  • Blurb....
Re: Grease Job
« Reply #27 on: May 11, 2004, 11:25:53 am »
Quote
So........Where's the pic of that ??? ??? ???  ::)
Offline shopteacher
  • Hiking Sedona, AZ.
Re: Grease Job
« Reply #28 on: May 11, 2004, 01:31:09 pm »
Quote
Sounds like an initiation to a fraternal order.
Offline Kevin
Re: Breaking News
« Reply #29 on: May 17, 2004, 05:32:53 pm »
One of these just came in the mail and the top end in the picture fits over the gresae fitting.
Looks like the real deal
Offline shopteacher
Re: Grease Job
« Reply #30 on: May 17, 2004, 06:22:35 pm »
Quote
Kevin, you mean the Canadian postal service is sending them out?  ???I'm moving ta Canada. :D
Offline Kevin
Re: Grease Job
« Reply #31 on: May 17, 2004, 07:31:49 pm »
Actually,  Western Farm sent it out.
How many can I put you down for?  :D
Offline shopteacher
Re: Grease Job
« Reply #32 on: May 17, 2004, 07:43:26 pm »
In that case I'm staying put. No GST. :)
Offline shopteacher
Re: Grease Job
« Reply #33 on: May 17, 2004, 07:46:24 pm »
Kevin, how far are you from the Falls?  The wife and I used to spend a weekend there every year at the end of the school year. Missed the last couple though. :-[
Offline Kevin
Re: Grease Job
« Reply #34 on: May 18, 2004, 05:08:05 am »
We're just getting into Summer.
The Falls about four months away.  :D
The water job is about a days drive.
Offline shopteacher
Re: Grease Job
« Reply #35 on: May 18, 2004, 08:42:10 am »
Smirt Arse Canadian. :D
Offline Kevin
Re: Grease Job
« Reply #36 on: May 18, 2004, 02:33:19 pm »
Quote
Sounds like the honeymoon might be over, eh?
:D
Offline shopteacher
Re: Grease Job
« Reply #37 on: May 18, 2004, 02:39:45 pm »
Over?  ::)  I must have missed the beginning. :o
Saw Anywhere!
