Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Pressure Washer  (Read 2305 times)
Online Jeff
  • Lead Administrator
    • THEE Forestry Forum
Pressure Washer
« on: April 24, 2004, 12:24:35 pm »
Thinking about getting one.  Who makes the best small engine Honda or Briggs & Stratton?
Offline Norm
  • What's for supper!
Re: Pressure Washer
« Reply #1 on: April 24, 2004, 12:34:51 pm »
I like the Honda's better than the BS ones Jeff.
WM LT30HDD-E25
Re: Pressure Washer
« Reply #2 on: April 24, 2004, 12:37:41 pm »
There is a brand new, in-the-box,  Honda pressure washer for sale around here somewhere, probably cheap.  It used to be mine. >:(
Online Jeff
Re: Pressure Washer
« Reply #3 on: April 24, 2004, 12:38:49 pm »
I see Lowe's has a 6 horse Honda on a troy built. 2500 PSI  for $299. Anybody have any specific recommendations on a good one? $299 is more then I want to spend but it looks like what I'll HAVE to spend to get something worthwhile.
Offline D._Frederick
Re: Pressure Washer
« Reply #4 on: April 24, 2004, 12:53:12 pm »
Jeff,
I would go for the Honda over the Briggs, althought there is not much different in design and they are both built in Japan. The only thing going for Brigg is that parts are cheaper than Honda. The igniton module for the Honda is over $100 while the Briggs has a life time warranty.
Make sure you get a 3 cylinder pump for your washer, it reduces the surging.
Offline florida
Re: Pressure Washer
« Reply #5 on: April 24, 2004, 02:17:11 pm »
Jeff,
You can't get a decent pressure washer for less than about $900.00. Pressure isn't everything. A good PW also needs to be able to pump at least 4 gallons of water a mnute or you'll wear yourself out. You need at least 10 HP unless you have lots of time. A good PW should last 10 to 15 years.  MY current PW has a Honda engine, probably has 5000 hours and is still going strong after 10 years of heavy use.
General contractor and carpenter for 32 years.
Online Jeff
Re: Pressure Washer
« Reply #6 on: April 24, 2004, 03:20:40 pm »
I'm not washing heavy equipment, this is for household tasks like cleaning the driveway and the deck on occasion or cleaning the eaves troughs.  I dont plan on spending 50 hours of the rest of my life using a pressure washer let alone 5000! :D
Offline Danny_S
    • www.ve9dks.ca
Re: Pressure Washer
« Reply #7 on: April 24, 2004, 04:20:13 pm »
WWW.VE9DKS.CA
Drill operator at Craig Manufacturing
Offline SwampDonkey
  • Large Tooth
Re: Pressure Washer
« Reply #8 on: April 24, 2004, 04:33:24 pm »
I bought a cheepie at Wallyworld 2 years ago. Its a Karcher, 2.1 HP, 7800 Kpa max pressure. I only wash the vehicles with it. I think it was $175 CDN. If your going to go with a gasoline model, Honda, Tecumsa, or Briggs, wouldn't matter to me. We used the same old Briggs Motors here on equipment for over 20 years. My snow blower is Tecumsa with electric start and my tiller and woodsplitter are Briggs. No matter what you buy, you just have to look after it. Not lending stuff helps too, cause when ever we lent stuff in the past it always came back broke. So I don't lend anything with a motor anymore. :) If the neighbors need a wood splitter, here's a $10 axe you can use. :D :D
Dirty Harry
Offline Larry
Re: Pressure Washer
« Reply #9 on: April 24, 2004, 04:43:55 pm »
I’ve had a Karchner 1,650 psi with a 4 hp Briggs on it for about 6 years now.  No problems and more than adequate for household duties.  Got to watch it on the cedar deck as it will eat the wood away pretty fast.  I sometimes use it at the sawmill to wash muddy logs.  Not near enough pressure to be efficient at that job.
Price sounds quite good to me.  Seems like I paid about the same amount for the one I have with a lot less power.
You ever think about getting an electric one?  I had one and liked it a lot more than the gas model for around the house.  Pump quit on it and couldn’t get parts.
Larry
Nine out of ten trees recommend wood for your building project.
Offline SwampDonkey
  • Large Tooth
Re: Pressure Washer
« Reply #10 on: April 24, 2004, 04:53:56 pm »
My washer is electric also Larry. I like it. And its light. You get one of those gasoline ones and remember you have to lug it out to the deck.I also keep my washer in the basement in winter so stuff doesn't freeze and bust inside.  :D :D
Dirty Harry
Re: Pressure Washer
« Reply #11 on: April 24, 2004, 05:59:09 pm »
I had a refurbished McCulloch, electric, 1200 lb. pressure washer that did a good job until the wand broke and the water attachment inside the box broke.  I was afraid of shock and threw it away.
I thought it was a real deal at Big Lots for $99.00
I used it to clean the vehicles, the house, about 2000 feet of pine that mildewed and various other things.  The power was sufficient for cleaning.  It did a good job on the mill if I could get it close enough to the house.  It's power line was about 20 feet long and I could get away with a 20 foot extension but wouldn't want to go further than that. The wand hose was about 20 feet long too, so reach wasn't much of a problem.  I didn't like being limited so close to the house or barn though.  That's why we bought the gas washer, so we could take it to the mill.
I'd buy another one of those electric washers if they get them in again.
Offline Haytrader
Re: Pressure Washer
« Reply #12 on: April 24, 2004, 06:27:25 pm »
Jeff,
I have always thought Honda was hard to beat so I just bought a 6 1/2 HP Briggs for my farm sprayer.....go figure. I got it from BrandNewEngines.com for right at $200. They also have power washers.
One of my brothers paints houses (among other things) and uses power washers to strip the old paint off. He buys his at Wally World cause if anything goes wrong, he gets a new one free. They have even replaced tips, nozzles, and hose, all free of charge.
But if you can get one with a Honda on it for under $300, you may have found "the deal".
Haytrader
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Pressure Washer
« Reply #13 on: April 24, 2004, 06:31:15 pm »
We have an electric PW and I take it up on the roof, to clean the mildew from the shingles. Used it for years on Teak Boat decks. Ya gotta be careful around wood, like Larry said.
 It's slow on concrete. Use a Tennis ball to jam the trigger and prevent "the Claw". ;D :D
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: Pressure Washer
« Reply #14 on: April 24, 2004, 06:45:41 pm »
I got a 5 hp honda ... 2300 psi  There a good machine not much I havent done with this unit , only thing you got to be carefull on wood with it , it will do like that horse with the chickens .... eat it .... For winter storage I run windshield washer fluid throught it  and don't afta worry about the cold doing it any harm....
   Marcel
Offline wiam
Re: Pressure Washer
« Reply #15 on: April 24, 2004, 08:29:32 pm »
I have a 5hp electric with a comet pump 2300psi.  Yes what they said about wood.  Works good to strip paint if using fan spray pattern.  It will take color out of fire hose.  (someone told me that) ::)
William
Online Jeff
Re: Pressure Washer
« Reply #16 on: April 24, 2004, 08:33:37 pm »
Maybe electric is the way to go. They seem to be less expensive and I cant think of any reason why I would need one away from electricity.
Offline Chet
Re: Pressure Washer
« Reply #17 on: April 24, 2004, 09:13:10 pm »
I'll bet you'll think of a reason as soon as you buy that electric one.   ;D
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline ADfields
  • I need less profile!
Re: Pressure Washer
« Reply #18 on: April 24, 2004, 10:28:57 pm »
I got a electric from Walmart a couple months back for $80 and it works just fine for around the house.   If I was to get something bigger I would get a steam cleaner not a just a pressure washer, but the 80 buck one works just fine.
Andy
Offline old3dogg
  • You can twist perception but reality won't budge.
Re: Pressure Washer
« Reply #19 on: April 25, 2004, 03:08:43 am »
Jeff.
Rent one if you are not going to use it all that much.
Dont get an electric washer.They are pretty useless.
Mike.
It has been a year already. I think I am going to like my new job!
www.prochemtech.com
Saw Anywhere!
