Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Chainsaw Workbench  (Read 1155 times)
Offline HolmenTree
  • "Been there.....done that"
Re: Chainsaw Workbench
« Reply #20 on: February 11, 2012, 10:39:58 pm »
so what have you done with those chain loops, peened them all ?
Yep with a small ball peen hammer, even most times reused the pre sets when taking a length of chain off the roll. I never had a shortage of pre sets. ;)
Online Al_Smith
« Reply #21 on: February 12, 2012, 07:19:40 am »
Yeah on that I only have the spinner anvil that will fit 3/8" and .404 .The others like 3/8 Lo ,.325 and rarely 1/2" I peen .
I did turn some concave punchs out of grade 8 bolts that work pretty well for setting rivits also .Wow that's some tough old steel to turn though .Smoke rolls off the carbide .
Offline bandmiller2
« Reply #22 on: February 12, 2012, 08:12:22 am »
Theirs nothing worse than a diddly, rocking, light workbench.Were all woodsmen here build the DanG thing out of oak like your serious,4x4 legs 2" top.Mount a good big american vice. Take your rivet breaker and spinner and mount each to a short heavy piece of angle iron,when you need it clamp it in the vice,then put it under the bench out of the way.This idea also works if your a reloader mount presses in the vice on angle iron. Frank C.
Online Al_Smith
« Reply #23 on: February 12, 2012, 09:07:44 am »
Kind of the same deal .The spinner is mounted on a piece of 3/4" oak .I can either clamp it in the bench vise or c clamp to the bench .It doesn't get used that often .
Having said that though I should get off my lazy behind and repair about 20 loops I have hanging on nails .That tramp metal plays a number on them .
Offline thecfarm
« Reply #24 on: February 12, 2012, 09:09:26 am »
I've got one of them to today,lazy behind that is.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Online Al_Smith
« Reply #25 on: February 12, 2012, 11:23:31 am »
Well it's cold out .The older I get the less enthusiastic I am about cold weather .Florida is starting to look real good as a matter of fact .
Oh you know the tough Eskimo types brag about working in weather that would freeze the tail off a brass monkey but I figured they either have no choice in the matter or are a tad  bit touched in the head .Nobody in their right mind enjoys that ,least not I . :D
Offline Ward Barnes
  • Married 26 years.
« Reply #26 on: February 12, 2012, 08:30:37 pm »
Howdy Folks:
The actual quote is, "Cold enough to freeze the balls off a Brass Monkey".
In the days of wooden ships and iron men a Brass Monkey was a triangle shaped piece of brass that had holes just under the size of a cannon ball which was made of iron.  The cannon balls were stored on deck on the brass monkey in readiness for battle.  Because brass and iron shrink/expand at different rates when subjected to temperature changes the term, "Cold enough to freeze the balls off a Brass Monkey" was indeed a true happening.  When the brass monkey got to cold the iron balls would fall off the brass monkey and roll around on the deck.
God Bless, Ward and Mary.
5 year old Stihl MS 390.  Kubota BX 2200 tractor.
Dull chains cause accidents.  Accidents cause shorter life spans.
You don't sharpen a chain when it gets dull.  You sharpen a chain to keep it from getting dull.
Offline Paul_H
« Reply #27 on: February 12, 2012, 08:36:59 pm »
Maybe not Ward :)
WIKI
and we shiver when the cold wind blows
Online Al_Smith
« Reply #28 on: February 13, 2012, 06:48:04 am »
 :D Ah Ha Ha .Sounds like a bunch of monkey business to me .
Offline AdkStihl
« Reply #29 on: February 13, 2012, 02:47:29 pm »
My operating table ( :D) in the shop is covered with 16ga polished stainless.
The bench in my basement is covered with linoleum. Makes cleanup a breeze!
Offline Ward Barnes
  • Married 26 years.
« Reply #30 on: February 18, 2012, 09:15:39 pm »
Howdy:
Thanks for all the info.  My new workbench is nearing completion.  I think it should be sturdy enough for the job.  :o   The top is made from 4 pcs. of 2X8s 8 feet long.  The legs are 4X4s and held together by 2X8s of the appropriate size.  I will add a solid top to the 4, 2x8s and a shelf will go below the table top just above the floor.  The front legs are recessed to keep my feet from making contact with them.  I will also add casters so the unit can be rolled around as needed.  A back piece of peg hook board will be added later as well as two drawers and a small cabinet.  Another cabinet may go under the workbench.  That decision will come later.  Every thing is put together with screws so I can modify the rig as time and uses dictate.  Thanks again.
Offline Clam77
« Reply #31 on: February 19, 2012, 10:11:06 pm »
Sounds like the only thing you're missing is a light and a few small (2-3" maybe) drawers..
Sounds like you're on the right track though..    8)
Andy
Stihl 009, 028, 038, 041, MS362
Mac 3-25
Offline Migal
  • I'm new! But Old as Dirt!
« Reply #32 on: February 19, 2012, 11:04:10 pm »
I'd recommend rough cut wood all the way... 8)
Stihl learning and picked up my Log Master LM2 Cat 34hp purchase 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebecca.
Saw Anywhere!
