Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Chainsaw Workbench  (Read 1155 times)
Offline Ward Barnes
  • Married 26 years.
Chainsaw Workbench
« on: February 10, 2012, 10:28:27 am »
Howdy Folks:
If you were to build a purpose built workbench for working on chainsaws how would you build it?  What equipment would you have on it and what would you permanently mount?
God Bless, Ward and Mary.
5 year old Stihl MS 390.  Kubota BX 2200 tractor.
Dull chains cause accidents.  Accidents cause shorter life spans.
You don't sharpen a chain when it gets dull.  You sharpen a chain to keep it from getting dull.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
Re: Chainsaw Workbench
« Reply #1 on: February 10, 2012, 11:00:36 am »
Working height for you, 8' long, 2' wide, 2x? top, with 3/8 plywood over that, good solid top.
Small vice bolted down, chain breaker, bolted down, chain riveter, bolted down, Drill press, bolted down, small air tank, to clean things up.
A sheet of 4' x 8' pegboard behind table to hang tools, parts, chain, and ect. on.
I owned, 8  Homelite's  , 17 Husqvarna's, 6 Jonsered's,  12 Stihls, 2 Partners,  5 Skidders  4 trucks  3 crawlers 2 tractors
Offline Kevin
    • The Milling Masters
« Reply #2 on: February 10, 2012, 01:24:22 pm »
I'd want a swivel vise and air compressor.
Offline Cut4fun
« Reply #3 on: February 10, 2012, 01:30:43 pm »
I built  bench #2 to work on saws without bending at my back. Just below chest high. My back likes when I am on that bench.  ;D
Learn Chainsaw Repair ChainsawRepair
Offline JDeere
« Reply #4 on: February 10, 2012, 08:56:57 pm »
Lumberjack48 thanks for the info. I have an old camper we use in the winter to store things, have lunch in and get warm. My next project is to build a work bench in it and your suggestions will be very helpful.
2000 Mack Tri-axle, 2007 Volvo EC 140,
2009 John Deere 6115D, 2002 Cat 938G
1997 John Deere 540G, 1996 Cat D-3C
1995 Cat 416B
Offline sawguy21
« Reply #5 on: February 10, 2012, 10:15:50 pm »
I need to build one in the shed when I find my round toit, looking for ideas to hold the saw steady yet be able to turn as necessary.
Offline WildDog
« Reply #6 on: February 11, 2012, 05:11:15 am »
Lumberjack48 has got it nailed.....I have a dedicated bench for chainsaw/postborer work etc nothing special. What I do prefer these days for chain sharpening is my blacksmiths post vise on a post at a good workable height that I can walk around when the saw is clamped.
I'm not below you, I'm not above you, I'm right here beside you.    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Ward Barnes
  • Married 26 years.
« Reply #7 on: February 11, 2012, 09:14:18 am »
Howdy Folks:
 8) Thanks for the input.  I now have a basic idea on how to build the workbench.  Looking on the carport I have a number of 2"X7"X8' boards and a few 2'X4" boards as well.
Scratching around I also located solid 1/2" pressed board (25"X8'4") that can be used as the seamless bench top.  Not as good as plywood, but, it is free.  In your opinion would I be better off with plywood vs the pressed board?  My concern is the press board may come apart over time when exposed to fuels or moisture.
Also on the carport is a number of smaller pegboard sheets from a salvaged store display and 3 wood salvaged storage cabinets that are of various heights and are 31" wide and 12 inches deep with doors attached.
Thanks for the input and if you have other thoughts please let me know.
Offline Cut4fun
« Reply #8 on: February 11, 2012, 09:27:52 am »
After you build one with all the gadgets on it you will learn that you will want another without them on there to work on the saws  and another.  :D  Thats why I have bench #1 #2 #3  ;D
Offline John Mc
« Reply #9 on: February 11, 2012, 09:42:14 am »
Have you thought about screwing down a replaceable sheet of 1/4" masonite, or something similar, on top of your pressboard? If it got trashed, you could just take it off and put on a new piece.
John
Small time fire-wooder in a neighborhood cooperative.
Offline Holmes
  • 1840 house
« Reply #10 on: February 11, 2012, 09:45:24 am »
Go ahead and use the pressed board . You will get the bench built and if you have problems with the pressed board put some plywood on it later.
JDeere if you build your bench in the camper it will also become a dining room table, better stock up on the Pledge to polish it. :)
Think like a farmer.
Online Al_Smith
« Reply #11 on: February 11, 2012, 01:47:12 pm »
I've got a neat contraption made by Kennedy which is actually two in line roller drawer cabinet tool boxes with a maple top one and a half inchs thick .I mounted a vise .It's on rollers and works very well for saw work .Usually it has so much junk on it I need to rid it all off before  I do any saw work though .
Offline sawguy21
« Reply #12 on: February 11, 2012, 01:53:08 pm »
Hmmm, wonder how much a couple of roll cabs would run me on craigslist. That is a great idea, the extra storage is a real bonus.
Offline HolmenTree
  • "Been there.....done that"
« Reply #13 on: February 11, 2012, 02:33:48 pm »
Best advice I can give you for a work bench top is what I did. I got a 4' X 8' - 1/8" sheet of galvanized steel and had the welding shop bend it to shape on their big sheet press. It's got a 2" front lip for the benchs front edge, the horizontal top is 3 feet deep and the last 10" is bent up for the backboard.
This 8 foot long top is bolted down to a 2" X 6" wooden frame 3 feet high. I have my air compressor underneath, drill press and 5" vise on opposite ends with chain breaker and spinner bolted down beside the drill press.
Now at the moment in my backyard I'm building a small 12' X 8' shop with 8' walls, fully insulated floor, walls, & ceilng. It will be heated by a 220 electric heater , even got a 42" X 42" window over the 8' workbench.
Up until now I had my workbench in my 2 car garage where I worked on my saws, but it was foolish heating all that space just to work on saws. So my new 12' X 8' shop will be alot more cozy and practical.
Even put it on skids so if one day I should move I'll just winch it upon a trailer and take it with me. One other thing I did in constructing the mini shop is I screwed everthing thing together in its construction.
Built to last over several moves if it comes down to that.
Online Al_Smith
« Reply #14 on: February 11, 2012, 02:49:23 pm »
These didn't cost me anything .They were discarded cabs  from work as well as the dozen I still have at work plus 15 double stackers in my main shop .--right place ,right time . ;)
On the other hand I did buy a couple the average price at the right auction being 50-60 bucks a pop for a base cab ,Kennedy usually .For some reason Craftsman bring more but they aren't built as well .Evidently the red or grey paint of a Craftsman is more appealing than Kennedy brown or something ???
Online Al_Smith
« Reply #15 on: February 11, 2012, 02:57:49 pm »
Say I am thinking about a small building like Willard .Maybe 8 by 12,12 by 16 on skids .Whatever I can get away with and not pay taxes on which I detest with a passion .
The garage is getting so full of stuff I barely have room enough to get Mrs Smiths automobile in it .The main 60 by 70 shop is 22 miles away so that's not the answer either .
It's a nice shop .Machine tools  ,welders ,overhead tram rails and in ground air over hydraulics  auto hoist .Not too conveniant to drive a half hour each direction to do a 10 minute job though .
Offline HolmenTree
« Reply #16 on: February 11, 2012, 03:13:36 pm »
I didn't even need a building permit because the shed / shop is not permenent being its on skids.
Offline Cut4fun
« Reply #17 on: February 11, 2012, 03:22:20 pm »
Bench #1 all metal, vise on one end, grinder on the other. I use magnetic strips to hold my tools. I dont like my chain breaker or spinner mounted. I only get them out and clamped in when needed.
Offline HolmenTree
« Reply #18 on: February 11, 2012, 03:46:45 pm »
The amount of chain loops I spin the spinner / breaker have to be bolted down in their place along with presets and other sawchain parts sitting right beside them. Only the chain sizing banner I have mounted on a narrow piece of 6 ft long plywood I have leaning against the wall.
BTW only recently I bought my first chain spinner after almost 40 years of making sawchain loops.
The galvanized steel workbench top  sure is nice .....................
Online Al_Smith
« Reply #19 on: February 11, 2012, 06:36:40 pm »
I don't need a permit either however I had no idea the stinkers would tax me if the thing was over 12 by 16 and the shed is 12 by 20 .That fact annoys me to no end . I have half a notion to saw the end off of it  >:(
So what have you done with those chain loops, peened them all ?
Saw Anywhere!
