Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Help Woodmizer blades getting hot in wide cypress!  (Read 766 times)
Offline Cypress Sam
  • ON Bayou Bartholomew
Re: Help Woodmizer blades getting hot in wide cypress!
« Reply #20 on: February 07, 2012, 06:31:13 pm »
Thanks for all of the advice.
 Did not get to saw today.
 Found out this morning that I had to run 4500 Lf of v-groove.  Should not have taken that long but the power company was a little low
 on voltage.{ROUGH ON MY MOTORS}
 Log Dog what set are you runing on big cypress? [26"+] making 18" cants.
  Piney Woods I go right past you all the time.  My wife grew up in Lake Charles,  La.  Have to go see the inlaws.
SAM
Offline ladylake
« Reply #21 on: February 07, 2012, 07:09:30 pm »
 With no problems with you lumbermate and trouble with your WM I'd check the blade  speed, I'd bet your Lumbermate is turning the  blade slower making less heat, maybe gear the WM down a bit.  Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline pineywoods
« Reply #22 on: February 07, 2012, 07:44:44 pm »
Think Ladylake is right. there a 3 lumbermates close by, so I am familiar with them. The blade speed is a bit less than the mizer. Most likely some additional set would cure the problem. Stop by and visit, I'm retired and usually here. LeroyC is a couple miles up the road, full time sawyer, cuts mostly big cypress...
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline Cypress Sam
« Reply #23 on: February 07, 2012, 08:07:36 pm »
Going to try .030, .032 if another profile job does not come up.
SAM
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #24 on: February 07, 2012, 08:26:07 pm »
??  I just finished sawing 12,100 bf of Cypress using WM sharpened 10° blades.  I ran about 4 gallons of water with 2 oz. of Cascade per gallon each day.  There was never a blade heating issue.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Cypress Sam
« Reply #25 on: February 07, 2012, 08:32:48 pm »
Kinda startin feal stuuuuuupid!!!!
Did not have this problem till i started cutin these 14, 16, 18" boards.
SAM
Offline tyb525
  • Always learning.
« Reply #26 on: February 07, 2012, 08:40:11 pm »
Before ya'll start bashing Woodmizer and favoring another saw company, maybe do a real good check of your mill setup. Sometimes alignment problem aren't obvious until you start trying to cut wide boards. What lube are you using?
Even WM states using too much lube in dry wood will cause the wood fibers to swell and rub the blade more, causing friction. I have found the same myself. I was once cutting a very old, dry walnut log. I was having to saw very slow, and I thought it was a matter of not enough blade lube (water and soap). Cranking it way up didn't help. I found a sweet spot, just enough of a drip to keep it clean and lubricated, and I was able to cut as fast as normal without excess blade heat. Also note, excess blade lube will soak the sawdust in the gullet to the point where it is no longer carried out of the log, but sticks on the cant/board.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline Cypress Sam
« Reply #27 on: February 07, 2012, 08:49:31 pm »
Not blastin WoodMizer love my little saw.  The problem is most likely a loose nut holding the speed control.  I an just tryin to figure out what I am doing wrong.  I have wished that I had named this pos Help blades getting hot in wide cypress.  I don't want to ofend anyone and I will keep using WM BLADES.  Might just be a diferent wm blade.
Sam
SAM
Offline LOGDOG
« Reply #28 on: February 07, 2012, 10:16:55 pm »
Cypress Sam ...
Starting at .030/.032 you should be in good shape. I've run more set depending on which mill I was running at the time, what I was cutting, and which blades I was running.
I did think about this overnight though. In your original post you mentioned you didn't have trouble with your Lumbermate making these cuts and that did bring to mind possible speed differences. Whether it's blade speed or feed speed.
Don't feel bad. You can get your mill to saw straight and cool, even in those big logs, and even though you might not have the horsepower a bigger mill does. Once you get your blades set up right you'll be in good shape. We'll be pullin for ya.  ;)
Offline ladylake
« Reply #29 on: February 08, 2012, 05:47:44 am »
 As all mills are basically the same  blade speed is the only difference I could figure between his Lumbermate and WM and that sure is not saying to get a Lumbermate , I,d try a smaller drive pulley on the WM.  With higher blade speed you have less torque at the blade and will lug the motor sooner most likely resulting in slower feed rates causing heat.  Cutting smaller logs the higher blade speed will cut faster, it's a trade off just like chain saws.  Most every time I gear the chain speed down a saw will cut faster in big wood while losing a bit when limbing.  Steve
Offline Cypress Sam
« Reply #30 on: February 08, 2012, 07:14:03 am »
Now if the sun would just come up so I can go to work and try this>
SAM
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #31 on: February 08, 2012, 07:16:36 am »
Now if the sun would just come up >
there's a lot of experience here, but....
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline LOGDOG
« Reply #32 on: February 08, 2012, 08:47:33 am »
Man ... don't go changin' drive pulleys. That WoodMizer will cut just the way it is designed to. Make sure your drive belt is tight enough so you're not getting any slippage, put a razor sharp, well set blade on there and don't feed it too fast. You should be good to go.
Offline ladylake
« Reply #33 on: February 08, 2012, 09:05:04 am »
 It sure isn't going to hurt trying a $50 or so pulley,  you can always put the old on back on. My blade speed is quite a bit slower after I put the diesel on my mill with the same pulley as the 3600 RPM gas motor had vs the 3100 RPM diesel, It saws about twice as fast with the diesel .  Steve
Offline Cypress Sam
« Reply #34 on: February 14, 2012, 08:08:07 am »
Only got  to cut one 14" cant. Blades did fine.  Now I am cutting 2x6 to make t&g for a timber frame roof sheath. I will have to wait untill the next order to see how the new set works out on some larger footage.
Sam
SAM
Offline Magicman
« Reply #35 on: February 14, 2012, 08:33:26 am »
Keep us informed.  Followup answers and solutions help everyone with future questions
Saw Anywhere!
