Get your Forestry Forum Hats while they last!
It would be great if you can do that Scott. No use re-inventing a tool. I'm kind of disappointed that the limit switch was not set so the blade can not hit.
I try and set up with either the cross-members close up to the log, or right at the end of the track. That way you can't actually flip the blade over top of it. Once you are clear of the log, you are also clear of the cross-member, or else you hit the track end stops before you reach it. Sometimes, different size logs, obstructions or terrain make this tricky and you just need to be careful.
