Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Wavy Cuts w/photos  (Read 2611 times)
Offline ssgerken
Wavy Cuts w/photos
« on: February 02, 2012, 08:28:51 pm »
Hey everybody,
I've had my mill set up for a few weeks now (woodland mills 126) and just cant quite get everything set just right.  When I cut wide boards/cants, I get pretty wavy cuts.  I've read over many articles on here and have tried about everything mentioned.  Today I put on a new blade (lennox brand not sure about anything else, it's just what they recomended when I bought the mill), and tried cutting a 24" pine log.  I went extra slow being carefull not to bog down the engine at all.  I still ended up with a wavy cant.  I have not been around much rough cut lumber, is some variation in the boards acceptable or should they be very accurate?  Please see attatched photos.
 I also emailed Neil at woodland mills and am awaiting his reply.  Thanks in advance for all your help.
Steve
Woodland Mills HM126
Offline ssgerken
Re: Wavy Cuts w/photos
« Reply #1 on: February 02, 2012, 08:33:16 pm »
Ok so looking at my post the 2nd picture is kind of decieving.  The cant really is not as wavy as it looks.  I was just trying to show how must the blade had raised up from level with the guides.  Thanks,
Steve
Online hackberry jake
« Reply #2 on: February 02, 2012, 08:41:22 pm »
I would try more set on the band if the band is clean. If the band is dirty I would change to a 1/3 bar oil and 2/3 diesel lube mix.
EZ Boardwalk Jr. With 20hp Honda and 25' of track. 32x18 sawshed. 24x40 insulated shop. 30hp kubota with fel. 1978 Massey ferguson 230. Two stihl chainsaws. Woodmaster 718 and various other woodworking equipment. The tree gave its life to you, its your duty to make something beautiful out of it.
Offline tyb525
  • Always learning.
« Reply #3 on: February 02, 2012, 08:49:17 pm »
In the 2nd picture, I can see the blade is deflecting upwards quite a bit. Make sure the mechanism that locks the head in place is working properly. Make sure your guides are properly aligned and the bolts are tight. Make sure your band is tight using the flutter test, it is tight when it doesnt flutter at full speed.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline pineywoods
« Reply #4 on: February 02, 2012, 09:19:03 pm »
Are you saying it saws OK on small logs? It appears the blade tried to climb out the top of the log. Usually an indication of not enough set, or dull blade, or both. cutting big pine, you need a minimum of 25 thou set, 30 is even better. Unless you specify otherwise, new blades normally won't have nearly enough. Blade tension has to be correct, or maybe a bit on the tight side. The blade guides need to apply a bit of down pressure on the band.
My bet is a good sharp blade with 30 thou set will cure the problem...
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline ssgerken
« Reply #5 on: February 02, 2012, 09:26:23 pm »
Thanks for the repays. How do I know how much set the blades have?  What do they come with if you don't specify?  I will be using a sharpening service, so this is all new to me. Thanks,
Steve
Offline pineywoods
« Reply #6 on: February 02, 2012, 09:51:13 pm »
Beg, borrow or steal a dial calipher. Measure the thickness of the band body. Most are .035, .042, or .045. On a small mill, most likely .035. Then measure the thickness of the band plus one of the bent (set) teeth. The difference in the 2 measurements is the amount of set. Don't have a setter ? go here setter]=http://www.forestryforum.com/board/index.php/topic,50749.msg732898.html#msg732898]setter
Offline ladylake
« Reply #7 on: February 03, 2012, 07:01:49 am »
 I'll agree with more set, for sure if the logs are dried out some.  I think most new blades come with around 22 thousands set. Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline taw6243
    • Tim's photobucket pictures over 500 pictures
« Reply #8 on: February 03, 2012, 08:55:05 am »
get the tooth set gauge from woodmizer
http://www.woodmizerblades.com/maintenance/ToothSetGauge.aspx
Part number 060490
$99.99
Tim
Online Meadows Miller
  • The Walkabout Sawyer
« Reply #9 on: February 03, 2012, 09:00:40 am »
Gday
the fellas have covered your problem I reckon and a side clearance gauge comes in handy  ;) with setting ill add a cheap way to do it is get a good ole heavy hand held handsaw setter I did my bands with one of them for years without a drama in the world I found it in the shed the other day and im utting my old auto sharpener back together and giving it a spruce up this week ;)
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline tcsmpsi
  • Time is relevant, only because it exists.
    • The Custom Shop/MPSI
« Reply #10 on: February 03, 2012, 09:48:58 am »
24" wide cut is a lot for a small mill.  I see you mentioned you slowed 'way down'.  Not sure what you mean by that, but if the pine is pretty knotty or has a lot of resin, you need a lot of lube and very slow cutting.  Even with a fresh blade, you may have to hold the mill back some, for those 'soft to hard' wood cuts can get your blade the 'wrong direction' and seemingly (engine sound/feel) cutting fine...until it gets way off.  Blade tension is especially critical in cutting wide cuts.  I live with the blades I get, as I do not sharpen and set my band blades.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
« Reply #11 on: February 03, 2012, 01:12:53 pm »
Another indicator is what the saw does when exiting the cut.  Does is drop or raise?  It should not do either.
The picture doesn't show your guides, how are they setup and adjust to be level? Many folks have found that deflecting the saw down slightly with the inside guide improves the cut.
Finally are you using the saw manufacture's recommendation for tension?
I know you said you were going extras slow but, is the wave the same across the log or deeper in the middle?  If deeper then your saw is not tensioned correctly or your saw is too low of beam strength and is curving backwards in the cut.
Offline NeilB
    • Woodland Portable Sawmills
« Reply #12 on: February 03, 2012, 01:33:15 pm »
Hey everybody,
Steve
Hi Steve,
Josh emailed you today with regards to this. It looks like your blade tension is much too loose. Don't be shy with the "T" handle blade tensioner. :) Read over his suggestions and give us a shout if you have any questions. Josh is out this afternoon, but back after 6:00 if you want to call...
Thanks,
Neil
Neil B
Woodland Mills
Offline Bogue Chitto
« Reply #13 on: February 03, 2012, 04:55:01 pm »
I had the same problem.  I would go in the log say at 4" and it would rise to 5" on a 8' log.  I thought it was the mill. After about a month of of adjusting this and that on the mill it turned out to be the new blades.  The blades were set wrong.
Offline Dave VH
« Reply #14 on: February 03, 2012, 05:14:24 pm »
when my mill was doing that just a couple of weeks ago, it was because the blade kept running down on the shoulder of the guide wheels.  the angle was a bit more extreme, it was because the band wheels weren't pichted right.
I've got a lot to learn
« Reply #15 on: February 03, 2012, 05:16:01 pm »
A Mill Is Only As Good As Its Saw I say  ;) ;D ;D 8) 8) I had $150k mills that would cut like a pig because the owner got cheap with the saws   :o ???  :) :) ::) ::)
Offline swampbuggy
  • Norwood MX34
« Reply #16 on: February 03, 2012, 06:26:25 pm »
As a noob to this sawmill stuff there is so much to learn. Piney's statement on offset got me to thinking and researching and calling around and looking..you get the picture. So I discovered this about my blades.
1. My blades have a 3 blade set meaning they go left offset, right offset, neutral, and then repeat.
2. My offset is 1/2 the blade thickness meaning that I use a blade that is .35 and each offset is .17 giving the total blade cut of .70.
3. When I find my cuts to be wavy it is time to sharpen and tighten the blade.
Since mine is a hobby mill and my blades don't spin at 100 miles an hour, I take it slow.
Am I suppose to have more of an offset as Piney suggests?
Just asking. Swamp
"Don't ya just love the feel of morning wood"?...Swamp
Offline customsawyer
  • www.thecustomsawyer.com
« Reply #17 on: February 03, 2012, 06:52:46 pm »
I don't know if this applies here but if it is a brand new mill your drive belt might need to be tightened. If the belt is a little loose the blade speed will slow down in the wider cuts.
Offline hamish
« Reply #18 on: February 03, 2012, 07:17:40 pm »
The bands you have, only have a set of 0.019" per side, as Pineywoods suggested increase you set........0.023 to start and go from there (as you have a lower hp motor).  To check you set just use a cheap dial caliper, does the same thing as the fancy $100 tooth set gauge.
Band tension is most likely low, Lenox run about 20-25000 psi.
Offline ssgerken
« Reply #19 on: February 03, 2012, 07:22:53 pm »
Thanks everyone for all the replies.  Josh from woodland mills just called me and his thought as many of you have suggested is to go with a little more tension.  We are about to get 8 to 12 Inches of snow so it may be a day or two before I get to try it out.  This forum is a great wealth of knowledge and I appreciate everyones replys.  Thanks again,
Steve
Saw Anywhere!
