Get your Forestry Forum Hats while they last!
It could be a bad injector nozzle. The affected cylinder should be cooler than the others.
Hi all. I just recently rebuilt my 4239d new main bearings, crank turned, new pistons, liners, etc. Done everthing to the Tech manual specs. Got the motor dropped back in the skidder. Bled the fuel lines fired right up sounded good. Ideling around for the first few minutes per break in instructions. After a 10-15 minute period I started hearing a slight knocking type sound. Almost sounds like it is in the head but cannot be sure. Any ideals would be greatly appreciated.I thought maybe I had injection pump timing advanced to much so I retarded the pump. no change... Thanksduckslayingpro
Quote from: duckslayingpro on January 31, 2012, 07:43:49 pmHi all. I just recently rebuilt my 4239d new main bearings, crank turned, new pistons, liners, etc. Done everthing to the Tech manual specs. Got the motor dropped back in the skidder. Bled the fuel lines fired right up sounded good. Ideling around for the first few minutes per break in instructions. After a 10-15 minute period I started hearing a slight knocking type sound. Almost sounds like it is in the head but cannot be sure. Any ideals would be greatly appreciated.I thought maybe I had injection pump timing advanced to much so I retarded the pump. no change... Thanksduckslayingpro did you use deere parts? already had the rings on the pistons in the liners? how much force did it take to seat the liners? were the wrist pin bushings miked? snap rings ok thet can be installed backwards most dont know that. if that motor came in that skidder new its a 219. you dont just advance the timing on a diesel no no no. you had the crank out are you sure the timing marks line up? oil pump ok? how much pressure? did you do all the work? experinace? could be a dozen different things. if turningthe pump helped then maybe the timing marks are offIn any event I would not try to restart the motor until the cause of the bent push rods is determined.My 2 centsThanksAl
If all the pushrods are bent = camshaft - crankshaft timing. Timing gears or chain not installed properly. Very easy to do if the gears are spiral. Not saying how I know...Usually results in bent valves also.
