Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: dissapointed with wm  (Read 2134 times)
Offline wlf89
« on: January 29, 2012, 10:11:25 pm »
never tried a wood mizer, so had them send me a blade to try, would not cut out of the box.
had to sharpen it after 1st slab, green pine at that.
anyone evey get a blade like this??
Offline Magicman
  • Knothole Sawmill, LLC
Re: dissapointed with wm
« Reply #1 on: January 29, 2012, 10:13:22 pm »
No sir I have not.  Did you contact WM about it?
I also noticed that virtually every post that you have made you were complaining about blades breaking, etc.  You may very well have a sawmill alignment issue.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline cypresskayaksllc
    • Cypress Kayaks LLC
« Reply #2 on: January 29, 2012, 10:14:31 pm »
Call WM. They will make it right
LT40HDDR, JD950FEL, Weimaraner
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #3 on: January 29, 2012, 10:18:54 pm »
Yea, I have, when I dropped it in the gravel when trying to open it. That would be my fault though.
So, the title of the topic, was that just to draw attention? Was it really warranted for one blade that may have been sharp but perhaps the wrong pitch or profile for the wood on the mill?  Wood-Mizer is one of our great sponsors. They and the other companies on the left. They all deserve some consideration when you name a topic because with out them, the forum would not be here, you would not be able to ask for help from the thousands of years of combined experience here.
I hate to get on my soap box for such a new member, but this one kinda ground me the wrong way.  You deserve every consideration when asking for help with a problem or an answer to something like why that blade would not cut right out of the box, and the forum sponsors deserve the same in return.
Offline wlf89
« Reply #4 on: January 29, 2012, 11:04:20 pm »
i have emailed them, will see what they say tommorow.
(quote)I hate to get on my soap box for such a new member, but this one kinda ground me the wrong way.  You deserve every consideration when asking for help with a problem or an answer to something like why that blade would not cut right out of the box, and the forum sponsors deserve the same in return.
i talked to them before ordering, they told me what would be best for softer woods and sent me a blade.
pitch and every thing else was alright, just wuuld not cut.
just wondering if anyone has ever got one from them
or any one else that would not cut..
i just thought is was strange for a big name like them
to send a dull blade.
Offline LeeB
« Reply #5 on: January 29, 2012, 11:07:51 pm »
Wouldn't cut at all, cut poorly, dip or rise, tell us what would not cut is describing.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Offline wlf89
« Reply #6 on: January 29, 2012, 11:12:48 pm »
i am 99% sure there is nothing wrong with the mill.
thats why i ordered a  blade from a different company.
i have checked and triple checked, and set it up to the book.
Offline wlf89
« Reply #7 on: January 29, 2012, 11:17:52 pm »
it would cut straight, just real slow. like it has cut 5 to 600 feet already. almost had to forse it through. after i sharpend it, it ziped right through.
Offline Okrafarmer
« Reply #8 on: January 29, 2012, 11:21:55 pm »
Umm, not to be smart, but-- you wouldn't be the first one to put a blade on backward. I've done it before.  :-[   Did you check to make sure the teeth are going in the right direction? Sometimes the blades come from the manufacturer bound inside-out and you have to flip them right-side out to use them.
Saw wood for freedom!
Just milling around
Offline Okrafarmer
« Reply #9 on: January 29, 2012, 11:22:44 pm »
Oh, sorry, didn't see the last post. I guess that wasn't the problem....
Just milling around
Offline wlf89
« Reply #10 on: January 29, 2012, 11:25:05 pm »
no, that is just how i felt. like a bad first inpression.
but im sure they will make it right.
[quote author=Jeff link=topic=55862.msg808503#msg808503 date=1327893
Offline tyb525
  • Always learning.
« Reply #11 on: January 29, 2012, 11:25:36 pm »
Maybe you got the wrong angle blade, and when you resharpened it you put it to the angle you usually use? Just a thought..
I've bought 30 blades from WM, 15- 10 degree, and 10-7 degree, and didn't have trouble with any of them.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline ladylake
« Reply #12 on: January 30, 2012, 04:18:05 am »
 Maybe you hit some dirt or a small rock right away, that's happened before.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline inspectorwoody
    • Wieland and Sons Lumber Compan
« Reply #13 on: January 30, 2012, 05:16:21 am »
I have an antique grinder but this is what it says in the manual.
"It is recommended that new blades be sharpened before using. When the blades are manufactured, they are sharpened and then set. The setting process twists the face angle out as much as 7 degrees. Sharpening a new blade with the face angle scale set at '0' will true up the face angle of all the teeth to 90 degrees. You should not have to grind any material from the gullet on the first sharpening."
Not sure if this same thing applies today with all the new technology but I'd like to think so and I'll do just what it says before I use a new one.
Lumber Inspector, Wieland and Sons Lumber Co., Winthrop,IA
Online Chuck White
  • Sawing Mobile since 2005
« Reply #14 on: January 30, 2012, 05:36:30 am »
Don't mean to step on any toes.
This really sounds like the blade was inverted.  Right out of the box, wouldn't cut, then taken off and touched up, reinstalled, then it cut really good, who's to say how many times it was flipped!
I might be wrong but I feel just like what okrafarmer said in the beginning of his first post.
I have put a blade on backwards myself, but I noticed it when I was putting the covers on.  I'm sure that was like a "test question" back when my FIL was sharpening blades for me!  ;)
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Kansas
  • In the mountains of Kansas
« Reply #15 on: January 30, 2012, 06:48:39 am »
I had to laugh when I read Jeff's post about the gravel. We used to have a guy work for us where his favorite method to uncoil a blade was to find a concrete pad and throw the coiled blade up into the air.
He doesn't work for us anymore.
I haven't cut a lot of pine, but not all pine is equal. Some is a lot harder than others. Might be they sent one hook angle, and then you sharpened to a more correct hook angle for what you were cutting. You may have also set it differently. First thing when we get blades, including WM, is oftentimes give them more set when we are cutting fuzzy cottonwood. I don't think any manufacturer sends out blades at 35 or 40 thousands per side.
Offline kevinlt15
« Reply #16 on: January 30, 2012, 06:54:18 am »
(QUOTE) This really sounds like the blade was inverted.  Right out of the box, wouldn't cut, then taken off and touched up, reinstalled, then it cut really good, who's to say how many times it was flipped!
I will admit that I have done that :-[  only when there is A bunch of onlookers and neibors watching ;D ;D
woodmizer is A great companygive them A call.
Offline Buck
« Reply #17 on: January 30, 2012, 07:11:42 am »
Inside out is the only way I've ever had a blade not cut at all.  Even my dull ones cut better than what the op described.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Offline ladylake
« Reply #18 on: January 30, 2012, 07:27:21 am »
 He made the first slab with the blade, no way would that get done with a blade on backwards.  I'd bet on hitting some derbis.   Steve
Offline ladylake
« Reply #19 on: January 30, 2012, 07:30:40 am »
 Quite a few new blades are just stamped out then set but cut fine that way, some manufactors do sharpen thier new blades.    Steve
Saw Anywhere!
