Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: homemade mill parts with pic  (Read 1028 times)
Offline steve phillips
  • I'm new! but old as the hills lol
« on: January 29, 2012, 03:02:10 pm »
howdy all
i will try this again lol , got the drive axles and idler done . the shafts i left long till later. both shafts are 4140 chrome moly . i added pic of shop and misc in my gallery  , well i hope thats what i did hehheee    steve
if its not broke dont fix it !!!!
Re: homemade mill parts with pic
« Reply #1 on: January 29, 2012, 03:03:07 pm »
lol owell i cant get them to load on the post
Online isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #2 on: January 29, 2012, 03:22:16 pm »
   Marcel
Offline leroy in kansas
  • Don't squat with your spurs on.
« Reply #3 on: January 29, 2012, 03:23:18 pm »
I didn't have any problem viewing them in your gallery. Looks like you have some serious mach. there. I've also got lathe and mill, both Inco. Does the job for me. Keep the pics coming. Really like to see how others do things. Leroy
Offline beenthere
  • EIEIO
« Reply #4 on: January 29, 2012, 03:51:30 pm »
Steve
You did good loading the pics.
Just that you didn't finish the job :)
When bringing up your pic full size (by clicking on it) in your gallery, scroll down a fair ways below the pic until you see the two options to paste it in your post.
Then use the preview button to see if indeed your pic that you wanted is in your post. If not, try it again until you get it.
Real easy, which is easy to say after you do it once. :)
« Reply #5 on: January 29, 2012, 05:46:53 pm »
« Reply #6 on: January 29, 2012, 05:47:48 pm »
hey thanks been there
lol i did it !!!!
« Reply #7 on: January 30, 2012, 07:02:29 pm »
howdy all
got a little done today , got the track about ready to be welded . felt slow today , get my shot tomorrow so watchout , i will be on the move lol
« Reply #8 on: January 30, 2012, 08:24:14 pm »
howdy all
the earlier post , i spell better than that. tried to fix it and comes back the same way
i got some done today , track is almost ready to weld , get my shot tomorrow  . hope to be on the move again
Offline bandmiller2
« Reply #9 on: January 31, 2012, 08:36:49 am »
Steve, are you planning to use automotive type tires for your bandwheels.?Your shafts are marginal diameter,keep the wheels close to the bearings to reduce deflection.If I was building anouther band head I would do it with 1/4" wall square tube say two 6' pieces of 2" parallel with a piece of plate for the engine mount welded in the middle.on the adjustable end short pieces of 2 1/2 tube to slide over the 2" for tensioning the band."V" sheves with short shafts and taper lock bushings between bearings mounted on the tubes.The B series belt on the drive end from the engine also supports the band.Strong, simple,and ridgid.Uprights that the head slides up and down on can also be square tube sliding on smaller tube. Frank C.
« Reply #10 on: January 31, 2012, 08:43:07 am »
gm bandmiller
yes auto tires is what i will be using , they are made of alumn. my shafts are 1 1/2 od they do look small in picture lol. they are also 4140 metal so the are hard.
 the bearing blocks will be 3 inches apart i think is the way i drew it up, drawing in the shop .
   if it dont work well can start over lol
Offline Riggs
  • philippians 4:13
« Reply #11 on: January 31, 2012, 11:56:48 am »
Nice thread, keep posting, it'll be nice to follow your progress.
Keep the pictures coming. :)
Every man's life ends the same way. It is only the details of how he lived and how he died that distinguish one man from another.~Ernest Hemingway
Norwood ML 26
Offline D._Frederick
« Reply #12 on: January 31, 2012, 01:47:22 pm »
Steve,
How did you mount the shaft to the hubs, I see one is welded and one is bolted? What keeps the shafts from turning in the hubs?
I hope that you didn't weld the shafts to the hubs, a bad idea!
« Reply #13 on: January 31, 2012, 04:32:12 pm »
howdy all
d. frederick hows everything ,good i hope
on the axle that you see the bolt , i installed 2 sealed bearings in the hub then put a hole in my shaft and threaded it . that way i can service them . on the drive hub , i turned a piece of 1 3/4 down to go inside the hub. from there i drilled a hole in this piece 1 1/2 which is my shaft size . i left an 3/8 inch on the end with a 1/2 in hole . then i welled everthing together . stuck in the lathe and trued every thing up . full length of shaft is 2ft . i have no more than .003 out of round anywere on the hole shaft .
Offline bandmiller2
« Reply #14 on: January 31, 2012, 09:02:22 pm »
Steve you should be fine with 1 1/2" they do look smaller in the picture.Have you considered those donut spare tires,narrow with good diameter. Frank C.
Offline Hilltop366
« Reply #15 on: February 02, 2012, 06:59:27 pm »
I really like the home built stuff ! Keep it coming.
« Reply #16 on: February 02, 2012, 07:18:44 pm »
howdy all
sorry no new pics , i had an ms attack so it will be awhile befor im back on my feet
but i am still reading post from time to time      peace
Saw Anywhere!
