Dave, even though it is a field tree, I would call it a "yard tree". Clues are, the trunk is very short before it starts branching off, and once it does branch off, there isn't really a main trunk after that. It is also along a fencerow, so it's likely to have metal in it from the fencing (sawmills hate metal!) I've also seen many trees with that kind of form have rot at the heart.
On the upside, trees like that with bad form CAN have some really nice figure somewhere in the yard.
If you decide to cut it, be VERY careful, especially once it is on the ground. There will be a LOT of tension on those branches sticking out the sides, when they are on the ground.
If you have your own sawmill to cut the log with, it might be worth it. But if you were planning on having it milled, that 8 foot log might not be worth all the trouble of cutting it down, then paying a sawmill to mill it. Maple is not that valuable, unless it has some great figure in it.
