Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: how do I harvest this  (Read 775 times)
Offline Dave VH
« on: January 29, 2012, 02:24:02 pm »
Hey yall, I'm not sure the best way to drop this tree, and harvest the logs out of it.  The main trunk is 50" diameter,  the limbs are over 24" diameter, the first limb is 8½' off the ground.  My largest saw is a 440 magnum with a 28" bar.  It would be easier to drop it to the left of the picture, as far as room on the ground.  This ametur would love some advice from some professionals.
I've got a lot to learn
Offline tyb525
  • Always learning.
Re: how do I harvest this
« Reply #1 on: January 29, 2012, 02:27:54 pm »
Cut as low a stump as possible, cut the rest into 18" lengths ;D
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline Dave VH
« Reply #2 on: January 29, 2012, 02:34:32 pm »
really?  I thought that the trunk being hard maple might have some value as a mill log.  Truth is, I don't know.
Offline Ianab
« Reply #3 on: January 29, 2012, 02:41:41 pm »
How far from the stump to the first big branch?
If it's 8ft or more, then you have a potential saw log..
Otherwise, firewood is probably the most value.
The tree appears to be growing in an open area which results in the heavy branching from a low level, and no good sawlogs to be had.
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline Dave VH
« Reply #4 on: January 29, 2012, 02:47:16 pm »
yeah, it's over 8', just barely.  My father in law (the farmer) asked me to take it out.  He doesn't like big trees on the edges of fields.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #5 on: January 29, 2012, 02:54:42 pm »
Be very careful when limbing it up.  :o   There will be some extreme pressures involved and potential danger when sawing those limbs off.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Dave VH
« Reply #6 on: January 29, 2012, 03:02:54 pm »
that's kinda my question, do I limb it first, or drop the whole thing and limb it on the ground?
Offline Magicman
« Reply #7 on: January 29, 2012, 03:25:58 pm »
Personally, I would fell it first, just be very careful when sawing those underside limbs off.
This Oak tree fell to the left.  Some of the limbs sprung over 6' when I sawed them off.
Offline chevytaHOE5674
« Reply #8 on: January 29, 2012, 03:26:51 pm »
Looks like nothing but firewood to me. I would drop it in the easiest place possible and start cutting and splitting the firewood from there.
Offline beenthere
  • EIEIO
« Reply #9 on: January 29, 2012, 03:45:03 pm »
Might have a sawlog worth messing with in the butt but would expect some fence wire. Maybe not.
I'd approach this one with knocking off the big limb to the right, then notching on the left and back cutting on the dotted line. Weight of the limbs on the left (without that one on the right) should go where you want it no problem.
After down, then work up the tops for firewood. No decent lumber in the tops, that wouldn't be a pain to dry straight. IMO
Offline Ianab
« Reply #10 on: January 29, 2012, 03:57:40 pm »
Ahh.. I understand now, you want a plan to get it on the ground (safely)
Is it obviously weighted in any one direction? Hard to tell from one photo. Maybe it would naturally tend to fall away from where the pic is taken?  If you can't tell then it's probably near enough that you can wedge it over.
Lopping one branch off is an option, IF you have a safe way to do it, but lopping of a heavy branch 10ft in the air has its own hazards...
Another option is to set a long cable as high as you can in the tree and attach it it another tree stump or some heavy machinery. Just take the slack out, then make your felling cuts. Then pull it over from a safe distance.
Edit: As MM suggests, the heavy limbs could also make the butt spring back over the stump, or roll to the side as the tree hits the ground. You want to be making large steps along your escape path as it starts falling. Having it bounce 6 ft in some random direction isn't so bad as long as you are 12ft away and heading in the other direction.  ;)
Offline tyb525
  • Always learning.
« Reply #11 on: January 29, 2012, 04:00:20 pm »
Sorry, I meant the trunk might have some lumber in it, but I wouldn't try for lumber from the top, just firewood IMO.
Offline steve phillips
  • I'm new! but old as the hills lol
« Reply #12 on: January 29, 2012, 04:10:40 pm »
hey dave
i would drop it ,cut from butt to the 1st limb , saw the lumber 1/4 sawn and sell it to luithers . even if its on ebay . just my 2 cents worth
if its not broke dont fix it !!!!
Offline Dave VH
« Reply #13 on: January 29, 2012, 04:33:00 pm »
thankyou everyone, that's the advice that I was looking for.
Offline Woodhauler
  • Logging is in my blood!
« Reply #14 on: January 29, 2012, 05:01:43 pm »
It is a firewood tree ! Cut it down and saw it into stove wood and be happy you are warm!!!!
2006 westernstar tri-axle with 2010 rotobec elite 80 loader!Sold 2000 westernstar tractor with stairs air ride trailer and a 1985 huskybrute 175 T/L loader!
Offline Dave VH
« Reply #15 on: January 29, 2012, 05:46:45 pm »
alright, teach me.  what are the signs that tell all of you that it's just firewood.  I don't understand.  I want to see what yall see.
Offline Ironwood
    • http://www.branchandburl.com
« Reply #16 on: January 29, 2012, 05:56:55 pm »
That aint a pretty drop. I like to cut a notch, start the back cut and then get a VERY long cable to a winch, heavy equip, etc,... then pull it till it snaps. That thing is dangerous. As stated it can "spring" up off the limbs, and the dynamics are NOT good. Firewood.
Ironwood
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #17 on: January 29, 2012, 06:07:46 pm »
It's too dangerous to cut down as a sawlog, so it is suggested that it is just firewood. Doesn't it have to be cut down to make it into firewood?   ???  ;D
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
http://www.xmission.com/~sherwin/sawyer1.
Offline treefarmer87
« Reply #18 on: January 29, 2012, 07:41:49 pm »
If the butt doesnt have metal in it you might get a 8 ft log, the rest could go for nice pulp or firewood :)
Amazing wife
1987 chevy 7000
Prentice H knuckleboom with FEC sawbuck
1980's Treefarmer C6D
Sthil 460 racesaw
Husqvarna 455
Sthil 360
Offline Dave VH
« Reply #19 on: January 29, 2012, 07:51:44 pm »
  so the the main reason that it is considered firewood is due to the danger of droping it nice, right?  that I understand.  I don't really need the firewood, I cut up the top of every log that I take into firewood already.
   I guess that that is why I asked the best way to harvest it.  I'll just try what Beenthere suggested and see what happens.  Maybe its rotten, maybe it'll crack on landing.  If so, then yall are right, firewood.  Thanks for clarifying.  I've got a lot to learn.
Saw Anywhere!
