Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: How do you charge for small scale logging/forest maintenence  (Read 1130 times)
Offline Spalted Dog
  • Doing the best I can with what I have
« on: January 27, 2012, 03:04:01 pm »
I have started a small scale logging business and am interested in how you charge for your services.  I do only very small pieces of land and am maily cutting walnut.  I also cut roads, food plots, TSI, firewood.  I am working with a small tractor w/winch and grapple, arch, and am currently building a forwarding trailer.  The last couple of jobs I have done I feel that things are coming up a bit short in the end.   What is your typical production with your smaller equipment?  It is very possible that  I am just plain slow.
The older I get the less I used to know.
Offline thecfarm
Re: How do you charge for small scale logging/forest maintenence
« Reply #1 on: January 27, 2012, 03:16:05 pm »
I have seen fast messy jobs, and slow neat jobs. If not getting wood out,I would change by the hour. If getting wood out half and half would seem about right.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline madmari
« Reply #2 on: January 27, 2012, 06:52:19 pm »
For TSI, roads, trails, cleanup, etc- by the hour. With a tractor/winch, should be ok at about $65-75/hr. Don't sell yourself short. You'll starve and get frustrated under-charging. It's hard starting out because you need the work and references, but believe me, nobody remembers the charity work!
  For timber, I pay a percentage for stumpage based on timber quality, skid distance, terrain, landing availability. If it's typical softwood logs, I pay 40% and $2/ton for the pulp. Really top quality hardwood, you might pay more to the landowner.
I know why dogs stick thier head out the car window.
Offline CuddleBugFirewood
    • CuddleBug Firewood & Forestry Products
« Reply #3 on: January 27, 2012, 08:36:46 pm »
right or wrong I started charging .20 per board foot.  I also try to maintain the margin if I bid on any tracts.  My ideal tract would be 10 to 20 acres and about 20,000 to 50,000 board feet, as I do this part time and don't have the time necessary for much more than that.
I directional fell, use a 548g skidder equipped with a winch and a grapple to extract logs and pulpwood, and a skid steer to maintain and organize the landing.  Trucking is usually included in the mill quote for all the grade logs, but the tie logs/pallet logs I end up taking care of the trucking.  I generally don't pay on the pulpwood as it is done as more of a service to get the hardwood tops on the ground and reduce the appearance of the ground being logged.  I think I probably losing money trying to recover some of the pulpwood  ::) I also smooth out and clear off the permanet trails (atvs and horses), close the secondary skid trails, and put water bars on the slopes with the skid steer or skidder.
This has figured out about 40% me 60% landowner on a average/good quality timber, and more like 60 to 70% me on a poor quality timber site.  I explain to the landowner the charges as we are looking at his timber so he knows what to expect.  I found this works out better than trying to keep track of percentages.  Each mill slip gets copied and submitted to the landowner with a check for his portion.
Depending on the TSI work to be done, it goes anywhere from 100 an acre to 500 an acre depending on the level of work and chemical required.  I will be starting to do some of that this year.  My dad has been doing all his own on the farm, and has done over 80 acres the past two years.
I am interested to see what other people charge.
Offline g_man
« Reply #4 on: January 27, 2012, 09:01:13 pm »
madmari, if spruce/fir is going for $300 mbf at the mill, for example, are you saying that you are typically paying $120 for stumpage (40%)? Or are you selling at the landing and paying 40% of that, and what would that amount typically be ? Just curious and trying to learn - Seems like if a mbf is 4 or 5 tons paying $120 for $300 worth of logs and $10 for $200 worth of pulp( if pulp is $40 a ton) is a big difference. What am I not seeing? Thanks
Offline FFLM
« Reply #5 on: January 28, 2012, 05:30:11 am »
What I do when working on a % job is trucking comes off the top and then split what is left with the land owner.  So when I get mill check I take the trucking out and then do the %age with the land owner.  Most jobs around here the mill dose not pay trucking.  My wood gose to a concentration yard and he will pay trucking on veneer.  I do small scale work like you, only in winter and sometimes I feel like I am working for peanuts!  Good luck, no one dose this stuff cause they think they will make a million, but just love puttin the wood out  ;D
208 Jack, 372's and F450 Stroker
Offline Spalted Dog
« Reply #6 on: January 28, 2012, 06:15:16 am »
I am going to try  % next for walnut anyway.  Around here larger logging companies charge 35-40% for walnut, otherwise they get 125-150 per thousand I think.  I definitely do not expect to get rich, but we need to put food on the table.   I have a cabinet shop that is VERY slow right now.  I feel there is an opportunity with this and it is something that I love to do.  The forester that I am working with is setting up the jobs and has a few coming.  I am hoping to come out better than I did on the last job.
What kind of production are you able to get.  I know this depends on a lot of things.  I do not set the world on fire, bigger equip would definitely help.
Do any of you cut firewood for folks?  I told a couple of people around here what I charge per hour and I thought they were going to have a heart attack.  +/-50 per hour.  I don't think that they realize how much the insurance, tractor all attatchments, saws, etc,etc cost.
Offline madmari
« Reply #7 on: January 28, 2012, 08:08:20 am »
Here we are getting $275 fir/spruce deliver to the mill and $350 for #1 white pine. Ship about 10mbf WP#1's a week- pulp is additional.
Gross- $3500
Trucking-$700- ($70/mbf)
 Now from the remaining $2800, we pay 35% stumpage to the landowner, or $980, leaving us  $1820.
 From that, deduct fuel, insurance, saw chain, oil, parts, maintenance supplies, tax, etc. Salaries come last.
 We're probably slower than most and concentrate on small lots where you HAVE to do good work. Two of us work 8 hrs a day and run a small skidder.
  Really good lots will produce faster with big logs adding up fast. My advice is to get a job through a respected forester, do good work and get repeat business.
  Hardwood pulp is paying good right now and sometimes we get jobs "for the wood". Likin' that.
  Despite the breakdowns, weather and unexpected expenses, it's hard to get this out of your blood.
Offline Rick Alger
« Reply #8 on: January 28, 2012, 08:33:44 am »
I do something similar to you. I use horses to skid, and I manage the yard with a farm tractor. I generally work alone. Typical production in spruce/fir is a tri-axle load a week. I aim to pay around $100/mbf for logs and as close as I can get to nothing per ton for pulp.
I have done on-site firewood harvesting and forest grooming. I charge  $600 to $750 a week depending on variables.
The biggest factors for a small scale operator's production are size of the wood and length/difficulty of skid. With 18 inch White Pine and a short skid, I can double or triple my production. With 6 inch hardwoods in rocky going I'm lucky to get a cord a day.
My rates are ridiculously low, reflecting the fact that my area has mostly huge tracts of woodland  primarily managed for fiber.  Not much tree hugging around here.
If you possibly can, get away from the production model. Sell yourself as a silvicultural service. Any wood sold comes off your bill.
Good luck.
Offline Spalted Dog
« Reply #9 on: January 28, 2012, 08:58:16 am »
Good point
Offline Spalted Dog
« Reply #10 on: January 28, 2012, 09:11:18 am »
I should say that I am a bit scared to buy timber yet, I am only doing the labor.  I work with a forester that coordinates the deal.  I am real new to the business end of logging and do not know enough to take the chance yet.
Sounds like production is similar.  There are good days and bad.
I agree with getting away from the production model.  I am trying to work on a way to sell it.
Thanks for all the input.
Offline thecfarm
« Reply #11 on: January 28, 2012, 09:22:26 am »
Most people I find out want the money fast. they don't want to stretch the job out 3 months when a big guy can come in and do it in 3 weeks.They could care less about the land, But when they see a mess,they are the first to cry about it. Most jump at the first logger instead of checking past jobs and than complain about it. Most landowners can not understand why it takes one man and one tractor that long to cut a piece of land when 2 guys with a forwarder and a harvester can do it quicker. or one guy with a skidder.
Offline madmari
« Reply #12 on: January 28, 2012, 09:39:39 am »
I used to worry about production AND doing a good, clean job. Once the money is gone, the worry of a messy job will last forever.
  I don't try to compare production with anyone else. It is what it is.
Offline shortlogger
« Reply #13 on: January 28, 2012, 10:21:15 am »
Evert job is differnt depending on the distance to mill quality of timber and the terrain the best thing to do is to talk to some local loggers . I usually on the ton give about 2 to 4 dollars less than the tree lenght guys . if its close to the mill and good ground I may give the same . But it may be differnt where you live than it is here .
1 Corinthians 3:7 So then neither he who plants is anything, nor he who waters, but God who gives the increase . "NKJV"
Offline Spalted Dog
« Reply #14 on: January 28, 2012, 12:10:18 pm »
I think I am having  hard time when I hear how much some of the local crews can do in a day or week.  I really need to just do a good job.  I have always said in my cabinet business "I would rather be known as slow and good than fast and crappy".  That seems like the way to go in this direction as well.
Offline madmari
« Reply #15 on: January 28, 2012, 02:57:24 pm »
Slow is smooth, smooth is fast. You'll get more on the log pile at the end of the week by taking your time and doing things right. Make the best use of every move.
  Anytime I ever got into the "death spiral" ( hang up a hitch on a stump, hit unmarked trees, break saws, etc) it seemed to only get worse until I stopped... slow down....think.... and get back on track. The "death spiral" rears it's ugly carcass when you don't take time to think things through, usually to meet production goals you dreamed up yourself that are probably unrealistic.  At the end of the day I guarantee you will have more timber on the landing than bulling and jamming. And you won't have to spend the last hour of the day cleaning up your own mess back in the woods.
Don't mean to preach...but I've made the mistakes and hope to help others from doing the same.
Offline John Mc
« Reply #16 on: January 28, 2012, 03:05:46 pm »
...I really need to just do a good job.  I have always said in my cabinet business "I would rather be known as slow and good than fast and crappy".  That seems like the way to go in this direction as well.
I think that is the way to go, especially if you are dealing with small lots. Remember, you probably dealing with what amounts to your customer's back yard, not some large, remote timber holding.
The big boys don't typically want to mess with these small jobs (unless tings are really slow for them). There is just too much involved in getting their equipment to the site and getting set up to justify taking on a small job. If you are cutting on percentages, I'd go for a higher percentage than a large outfit would. Your customers may not have any options. I'd rather be known as the guy who "costs a bit more, but is worth it", than be the guy people come to when they are looking for a quick cheap job. You may lose some potential customers, but my bet is that the ones you do get will be better to work with, and more suited to your style. If you're intent on doing a good job, you want customers who appreciate that.
Small time fire-wooder in a neighborhood cooperative.
Offline thecfarm
« Reply #17 on: January 29, 2012, 05:09:11 am »
madmari,how right you are and how true it is. But there is always someone that says,claims,they can do it better,neater,faster, and make more money than you. I know of a few like that. I just about tell them not on my land you will do it. They are also the same ones that can build or fix something better than me too.  ::)
All that matters to me is that I did not get hurt or break anything and that I'm happy with what I got done that day.
Offline Spalted Dog
« Reply #18 on: January 29, 2012, 03:36:41 pm »
I think you are right.  Keep the quality high, and get paid for it.  I do not want to overcharge, but I need to make profit.  The smaller equipment takes more time, but I don't mind.  I think it is a pretty good nitche and I don't think there is anyone else in the area doing it.  I will keep work ing on it.
Thank you all!
Offline shortlogger
« Reply #19 on: January 29, 2012, 11:37:12 pm »
Most of the people I run into are not as worried about the land as they are the cash. So I look for that nich like the small tracts or that lot that is about to be pushed over and  burned for development sometimes those are freebies the big boys need volume to operate , I also look for pond sites and bug kills working that nich is the secret for me .
Saw Anywhere!
