Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: How would you saw this one?  (Read 1213 times)
Offline Bibbyman
    • Warden Sawmill
« on: January 26, 2012, 02:19:17 pm »
Customer brought in a load of this and that to saw up.  One of the logs was this otherwise nice black oak butt cut log.  Otherwise being it was split three ways.  He wanted 2x4, 6 and 8s
How would you tackle sawing this log?
Sawing since '94
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: How would you saw this one?
« Reply #1 on: January 26, 2012, 02:23:48 pm »
Narrow flatsawn lumber by rotating 120 degrees.  Or, if the cracks aren't parallel, cut every 18" at right angles to the pith.   ;)
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline POSTONLT40HD
  • You saw my Ad...I saw your logs. Buy now. David
« Reply #2 on: January 26, 2012, 02:27:12 pm »
Saw what he wants and give him a complimentary bottle of Gorilla Glue.  8)
David
Offline ladylake
« Reply #3 on: January 26, 2012, 02:34:44 pm »
 If it's big enough saw through the long crack a bit below the center turn up a get you 6  or 8''  boards, If too small  not much.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline hackberry jake
« Reply #4 on: January 26, 2012, 03:52:13 pm »
Wedge, sledge, then saw three different pieces.
EZ Boardwalk Jr. With 20hp Honda and 25' of track. 32x18 sawshed. 24x40 insulated shop. 30hp kubota with fel. 1978 Massey ferguson 230. Two stihl chainsaws. Woodmaster 718 and various other woodworking equipment. The tree gave its life to you, its your duty to make something beautiful out of it.
Offline Buck
« Reply #5 on: January 26, 2012, 04:30:41 pm »
I'm in for 18" blocks too Bibby.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #6 on: January 26, 2012, 04:33:01 pm »
If you go ahead and split it like Jake said, it looks like you would be half way to quarter sawing it  :)
Imagine, Me a Tree Farmer.
Jon, Appalatian American Wannabe.
Online Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: January 26, 2012, 04:43:05 pm »
Sounds right to me too.  ;)
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #8 on: January 26, 2012, 05:14:39 pm »
Do the splits run straight or do they spiral up the log  ??? ;D
Offline beenthere
  • EIEIO
« Reply #9 on: January 26, 2012, 05:28:19 pm »
Not enough info.
How far do the splits go? What does the other end look like? Splits come from poor falling or ?
Offline ladylake
« Reply #10 on: January 26, 2012, 05:39:01 pm »
  If the splits are spiral firewood for sure. I'd do my wedging and sledging with the mill.  No need to spilt the short crack as that would in the same plane as the blade.    Steve
Offline Chris Burchfield
« Reply #11 on: January 26, 2012, 05:58:08 pm »
Bibby, I'm with hackberry jake.  First hoping it's the only one, begin the opening from the end with wedges and down the outside with wedges.  Pulling 1/3rd out of the log at a time.  I'd then put the best flat down and saw from the top down for board thickness.  I would then put one good edge on each board, flip it and see what I could get relating to the original request.  A bit of a pain for black oak.  I'd feel better about the amount work if it had been black walnut.  If I were there, I'd be glad to help.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
Offline west penn
« Reply #12 on: January 26, 2012, 09:03:15 pm »
  If the splits run fairly straight I would consider putting the odd split down 90degrees to the bed so the other two are nearly horizontal. then saw 2inch mat. until you get to the heart. save the split stuff so you can show the customer. then turn 90 degrees and cut 2inch mat. from the other half. The third split may well be in one 2x.  You could square it up first but if split because of tension, you may as well wait and edge after.
Offline LOGDOG
« Reply #13 on: January 26, 2012, 09:11:47 pm »
Not enough info.
These would be my questions first.....
Offline jueston
« Reply #14 on: January 26, 2012, 10:00:18 pm »
it could be a new kind of sawing, thirdsawing.... the Forum could apply for a trademark or patent or something, then when thirdsawing becomes the next big thing, jeff makes the big bucks and we have a FF picnic every weekend....
what we need now is someone to make thirdsawing famous so that everyone will want it.... we need a celebrity or something to say how amazing and expensive his thirdsawn oak cabinetry was....
bibby, this could be the beginning of something great.... :o
Offline Bibbyman
    • Warden Sawmill
« Reply #15 on: January 26, 2012, 10:04:09 pm »
You’re right.  Not enough info.  In fact a closer look at the end of the log tells a lot.  There are a couple of minor cracks that have not opened up yet.  Also the stain in the heart area shows it has a lot of bug damage.  Plus the fact that it was standing dead would indicate it was killed by the bugs.  Also the crack twisted a bit and had some random cracks show up as we got closer to the center.  In short, this log was firewood and should not have been brought to the mill.
I did indeed use a 120° , 3 face method and sawed parallel to the bark instead of the heart.  I'm sawing on face two.
Here I’m making the face cut on the third face. Note I had first put the cant bark side down and cut the point of. When flipped 180°, that gave me a flat to stabilize the cant.
Who says you always have to start at the top and saw your way down.  Here I’m starting in the middle and taking a couple of cuts to the bed.  The upper part was pushed off and sawn the same way later.
All the flitches were ran through the edger.  We lost about 50% of the log due to cracks, bad heart and sap rot.  Not very productive or profitable.  Now if it had been an otherwise sound log and of more valuable, maybe this method would have been worth the effort.
I just wanted to see how it would work.  A guy gets bored just sawing four faces every time.
Sawing since '94
Offline WDH
  • April 1998 - August 2008
« Reply #16 on: January 26, 2012, 10:47:43 pm »
Definitely a challenge.
I got some sweetgum that I need to send you  :D.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline tcsmpsi
  • Time is relevant, only because it exists.
    • The Custom Shop/MPSI
« Reply #17 on: January 27, 2012, 06:40:59 am »
Yep.  Sweetgum has six thousand seven hundred and twenty-four faces.    :D
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
« Reply #18 on: January 27, 2012, 07:29:50 am »
Mr Bibbyman, In your first picture, what is the log on the right?
Offline WDH
« Reply #19 on: January 27, 2012, 07:34:06 am »
Hickory!
Saw Anywhere!
