Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: ez board walk saw  (Read 1551 times)
Offline Magicman
  • Knothole Sawmill, LLC
Re: ez board walk saw
« Reply #20 on: January 24, 2012, 06:03:35 pm »
Welcome to the Forestry Forum, peanuts roost.   :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline ladylake
« Reply #21 on: January 24, 2012, 07:07:51 pm »
I would think that if the mill was "perfectly level", that the EZ Boardwalk sawhead would practically pull itself through the log!
 It has too make it easyier to push, if it was at a 45* angle you'ld have to hold it back.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline steve phillips
  • I'm new! but old as the hills lol
« Reply #22 on: January 24, 2012, 08:40:47 pm »
howdy all
man what a day , went out and trades for a military wisconsin  motor , i like motors with history
well anyways  the wood i will be cutting here 1st will be poplar . but i will be cutting a little of everything including burls
 until i was told by the docs to stop . i used to build banjos on the side. i wored for harley davidson for over 20 years untill i had to stop so now i have a complete machinse shop and build a lot of stuff , more than i want at times  but   all my musical building buddies want me to do some sawing for them.
 the better neighbor fence thing comes 1st already have a court date for assult , shouldnt slapped my lab lol
if its not broke dont fix it !!!!
Offline peanuts roost
« Reply #23 on: January 24, 2012, 10:49:07 pm »
 I wish to Thank all of you for the welcome and the good advice.I agree I should include hydralics but my pocketbook just won't allow at this time unless I locate an affordable used mill.Thanks Again
Offline Ozarkian
  • "Veni. Vidi. Vici. (I came. I saw. I conquered.)"
« Reply #24 on: January 24, 2012, 11:36:30 pm »
Hello Peanuts,  I will be purchasing a Mill in the next few weeks as well!  So I understand your excitement.  I don't believe you got much of a "specific" response regarding which mill would be better for you.
First, there is one major difference between these two mills.  From what I have gathered off of their websites that difference is the diameter of log that can be cut.
Model: 26 - Capable of cutting 26" dia. x 12' or 18' long log.  (Depending on which model you select, 26B12P20 or 26B18P20).
EZ Boardwalk 40 - Cuts 40" dia by 16'6" long logs.  You can purchase additional track extensions available in 4', 6', 8' and 10' lengths.
That is a difference of 14" in diameter  :o, something to consider.  However, the 26B18P20 come's with an additional 18 inches of length.
Motor size:
EZ Boardwalk 40 - 24HP Honda or 25HP Subaru ES, Electric start engine
MisterSawmill (Model 26) - Honda 20 H.P. twin cylinder, electric start engine.
Tow Package:
Model 26 - Both versions; the 12' or 18' come with the tow package included in the price.
EZ Boardwalk 40 - The tow package is optional and cost an additional $600.00. However, it does include the log turner with the package.
These are a few of the biggest difference I noticed between these two mills.  It is up to you and your needs which one would be the best option.  Both seem to have their advantages!
You did not mention the type of disability, so I would not be able to address that issue directly. I will assume if you are considering one of these then you understand the potential limitations for certain types of disabilities.  I personally have a dis(ability). Yet, it will not interfere with having to manually push a mill.
Feel free to message me or reply to this topic if you have any further questions.  I am doing plenty of my own research and am happy to share information.  I will be purchasing either a used EZ Boardwalk Jr., or a new Woodland Mills HM 126.   ;D
13h.p. EZ Boardwalk JR.
Offline paul case
« Reply #25 on: January 24, 2012, 11:50:31 pm »
Ez boardwalk MDL 40 will swallow a 40'' log but the max board width cut is 36''. PC
EZ Boardwalk and WM 94 LT40 hd
pc
« Reply #26 on: January 25, 2012, 12:38:23 am »
   Thanks. I think most of my milling will be Loblolly Pine mostly 14 to 20 inch. Also have a lot of Red, White and scrub Oak  18 to 26inch. I have some trouble with my heart and had 4 disc in my neck and 2 in my lower back ruptured. I can do pretty good except jerking recoil starters that is why i definately want electric start.But I have alot of time and not in a hurry.
Offline thecfarm
« Reply #27 on: January 25, 2012, 08:40:26 am »
peanuts roost,welcome to the forum. With that much damage I would keep away from wood in general. Hard to handle logs,lumber. But maybe that's what is keeping you going.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline Ozarkian
« Reply #28 on: January 25, 2012, 08:53:27 am »
I am also disabled but hope to purchase a small mill in the next few weeks for my own use only.
I would suggest consulting with your Primary Doctor prior to any purchase to make sure you are physically capable of running a sawmill without further injuring yourself.  If you have family, possibly they could run the mill for you if the doctor does not clear you.
I hope I'm not breaking any rules asking for advise
I believe that is what this forum is all about, getting AND giving advice.  Ask as many questions as you like.  ;D
 8) 8) Welcome to the Forestry Forum. 8) 8)
-Ozarkian
Offline plowboyswr
« Reply #29 on: January 25, 2012, 09:19:07 am »
Steve Phillips by what I've read you're building your own mill. I'm guessing that you're gonna set it up as a manual, why not build with the intent of usin hydrolics on it later. Guess what I'm tryin to say is to make sure that your design is easily modifided when you get the funds and time to add it. Working with limited funds is doable just takes longer.  :D
Offline paul case
« Reply #30 on: January 25, 2012, 05:49:00 pm »
Welcome steve phillips, for what its worth I have pushed P. Cases mill through wood and it is a lot easier than my mill. PC's is a boardwalk and mine is home build not on angle. The angle does help pull the head through the wood. bg
Has anyone else ever tried the ez and another mill to compare? Just curious. PC
pc
« Reply #31 on: January 25, 2012, 07:40:37 pm »
howdy all
hey ozarkian  i always TRY hehee to do what the doc says but like my mama said  " boy you are one hard headed child '' LOL what more can i say . but all joke aside i do listen and hes cool .
  howdy plowboyswr
yeah i am building a home made mill .  it will oneday be a lot of hydralics on it . but for now got a lot of fencing i need to build this summer . i have about 1/2 of tall poplars to cut on , some are close enough to end up in bed with me one nite
« Reply #32 on: January 26, 2012, 12:51:34 am »
 Appreciate the concern. But I have friends to help and I can't stay inside. Had a long talk with Ezboardwald today and planning on ordering a Ezboardwalk jr with optional 15 hp subaru with electric start. Not very familure with subaru but does have 3year warranty. Sounds pretty good to me. What do ya'll think? opinions will be very appreciated. Thanks
Offline paul case
« Reply #33 on: January 26, 2012, 09:12:06 am »
I say, I think, I say,I think you made a wise choice. The ez boardwalk mdl40 is a tough rugged well though out ,very user friendly mill and the jr. is a chip off the old block.   You will be sawing logs day and night! PC
pc
« Reply #34 on: January 27, 2012, 07:54:56 pm »
howdy all
 i just like to say you guys are great , thanks for all the help.
           steve
« Reply #35 on: January 27, 2012, 11:01:06 pm »
    Steve ,Hope you post pictures as you build your mill. Good Luck!
« Reply #36 on: January 28, 2012, 07:56:37 am »
howdy peanuts roost
thats a good idea im charging the battery in camera as we speak
  i got the drive axle hub finished , will finish the idler shaft today i hope. will send pictures
 i have a picture to take when i go to my moms of a log left on loading deck , its white ash and across the stump its at least 4ft if i remember right. should be some pretty wood its from the swamp area down home.
Offline eastberkshirecustoms
« Reply #37 on: January 28, 2012, 09:38:40 pm »
Hey Steve, have you checked out http://www.diybandmill.com/index.php?option=com_frontpage&Itemid=1. Lot's of good info for the DIY'ers.
Saw Anywhere!
