Get your Forestry Forum Hats while they last!
... for good all around performance I stick pretty close to OEM spec,s...
Personally, I've found having the teeth all the same length to be over-rated. If you use the appropriate tool for setting the height of the depth gauges in relation to each individual tooth (rather than the tool that rests across the tops of two or more teeth), you can compensate for a lot of variation in tooth length. I still make some effort to keep the length somewhat close, but I do that by eyeballing them. I don't get worried about minor differences in length. I hand file, and my chains (round-ground, full-chisel) cut straight and fast - generally as good or better than new out of the box chains.
