Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Diesel truck, PU or CC?  (Read 854 times)
Offline snowstorm
Re: Diesel truck, PU or CC?
« Reply #20 on: January 20, 2012, 03:35:04 pm »
as to how much fuel it mine burn. had a little snow event here today 7" i plow and sand town roads. started at 3am got done at 3pm took 25gal. 04 f550 6.0 6 speed. as hard as i am on it i would say 2gal per hour was pretty good. as for the IH nice looking truck it uses the same motor that ford had in 08 thru 2010 a 6.4
Offline Bibbyman
    • Warden Sawmill
« Reply #21 on: January 20, 2012, 06:00:23 pm »
While Ford did use the IH engine, but I think in 2010 they developed their own engine.
The MaxxForce 7 engine used in the Terrastar is a new engine by IH - I understand it's not the same as the old PowerStoke.
http://www.truckinginfo.com/trucks-trailers/news-detail.asp?news_id=73650&news_category_id=66
Sawing since '94
Offline snowstorm
« Reply #22 on: January 20, 2012, 07:57:59 pm »
i read the link its the same motor ford had. twin turbo 6.4. ford a IH got a divorce. ih is still building the frame for f650 750 that is due to end soon. ford will be builting there own i think in ohio. it was in fleet owner mag
Offline gspren
« Reply #23 on: February 13, 2012, 05:57:23 pm »
Bibbyman,
      How do you like your Terrastar so far? Can you give a comparison to previous trucks as far as power, comfort, fuel mileage, Etc. Tell me anything you can.
gspren
Offline Bibbyman
    • Warden Sawmill
« Reply #24 on: February 13, 2012, 06:34:52 pm »
I don’t have a wide range of experience to compare the Terrastar to.  We have and been using a 99 Dodge 3500 V10 gas since it was new.  Had a Chevy 1 ton before that.
The Terrastar has a lot of power. 300 hp. The Alison transmission is fantastic.  We just found out that it has and overdrive/road mode that should improve mileage.  I don’t know the mileage because Mary won’t give me the numbers.  She records the numbers when she fills up but for some reason she has never made them available to me.
We have about 2,500 miles on it already.  Seems to be running stronger – what little I’ve driven it.
While most of it says “truck” there are a couple of flimsy things on it I find most disturbing.  There is a plastic trim panel below the door that you could rip off with your bare hands.  In fact,  I complained to the salesman about it and he agreed.  Said they sometimes blow off going down the road.  The grill is flimsy plastic too.  I doubt if it would stand more than a blow of a big bug or a small bird.
The salesman said the biggest thing holding up sales on the Terrastar is that they have not made 4wd available yet.  It’s cataloged, but they’re not ready to build them.
You can order it with class 4 or class 5 springs – same weight range as F450 and F550 and Dodge 4500 and 5500.  We got the class 5 springs – 19,500 gvw.  We’re overloading it and there seems to be little difference in power – loaded or empty.  It rides smoother with loaded.  If you get one, get the air ride seat.
Here is 1400 bf of white oak - 14-15' long.
Here is the flimsy panel I was talking about.  The arrow is pointing to the engine block heater outlet and jump connection point.  It was balow the step and hard to get to.  I took the bracket off and remodeled it and bolted it on so it was above the step.
Here is the flimsy bracket that broke when I took the flimsy plastic panel off.  I think it's a good place for some polished aluminum diamond plate.
Sawing since '94
Offline snowstorm
« Reply #25 on: February 13, 2012, 08:38:17 pm »
nice looking truck. havent seen any around here yet could be cause the 4x4 isnt out yet. theres a place just up the road from here that build snow plows and wings. he rigged up 5 new f550 fords. all said an done there are about $85000
Saw Anywhere!
