Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: debarker  (Read 1523 times)
Offline steve phillips
  • I'm new! but old as the hills lol
debarker
« on: January 17, 2012, 03:07:24 pm »
howdy all
its the new guy  again .
have a question and open to all opinons
looking at putting a debarker on my mill , i though about a 12volt motor with some chain to slap off the bark .
or is this a real thing that really helps the blade keep sharp, i can see the point.
thanks
if its not broke dont fix it !!!!
Offline beenthere
  • EIEIO
Re: debarker
« Reply #1 on: January 17, 2012, 03:15:40 pm »
I didn't follow that reasoning, but there are debarkers that will remove the bark and keep your band sharper longer.
Did you have in mind to re-invent something?
Offline POSTONLT40HD
  • You saw my Ad...I saw your logs. Buy now. David
Re: debarker
« Reply #2 on: January 17, 2012, 03:29:10 pm »
I have the debarked on my LT40. This is the best investment I've ever made.
As far as you building your own, I'm probably not very much help on giving advice. But I'm sure someone on here can help. I hope it works out for ya. A debarked is worth it's weight in GOLD!
David
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: debarker
« Reply #3 on: January 17, 2012, 03:40:09 pm »
The Wood-Mizer debarker is a 1/4" kerf circular blade which saws a groove ahead of the band.  This blade and its motor have mounting which allow it to bounce, or you to move it, out of the way sometimes over the highly irregular log surface.  It is not a flail, but rather a saw.  It will only saw so deeply, if you get logs with deeply textured bark full of mud it may not get through to the clean wood.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Re: debarker
« Reply #4 on: January 17, 2012, 04:21:55 pm »
hey been there
yeah i am making this thing ,   i am doing some machining on some frame parts a just thought of a debarker
so yes i will be building it
i have an ole jointer planer i use for parts was thinking about using the cutter out of it ,run it off a belt from motor. add a arm with a spring so it will be pulled against the log
what do you think ?
Offline Magicman
  • Knothole Sawmill, LLC
Re: debarker
« Reply #5 on: January 17, 2012, 04:53:31 pm »
The blade needs to be pulling out of the log.  That way it can climb over irregularities as terrifictimbersllc mentioned.  Some folks have used stacked circular saw blades.  The tooth angle is really too steep on them so maybe turn a couple backwards.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline redbeard
    • whidbeywoodworks.com
Re: debarker
« Reply #6 on: January 17, 2012, 05:10:07 pm »
  Timberking debarker is a pretty simple design I use a dado stackable 8" blades middle ones reveresed. It really is a blade   saver.
whidbeywoodworks.com     06 B-20 Timberking 30hp gas    86 F-700 boom truck    JD 2240 50hp Tractor with 145 loader
Re: debarker
« Reply #7 on: January 17, 2012, 05:33:59 pm »
hey redbeard
yeah i like it ,i like it
straight out and forward ,simple , cant be beat lol
Offline learydeere
Re: debarker
« Reply #8 on: January 17, 2012, 07:10:41 pm »
I was going to build my own too but got stopped when i went looking for a 12v motor.  I found plenty of 1.5hp 12 motors but they were all around 86amp and for a 20 amp was almost $900.  Is there something else that can be used?
Offline JFarmer
Re: debarker
« Reply #9 on: January 17, 2012, 07:25:22 pm »
I wouldnt own a mill without a debarker, for me it's a must!
LT40 electric,woodmizer twin blade edger,cooks catclaw sharpener,suffolk setter
Offline millwright
Re: debarker
« Reply #10 on: January 17, 2012, 07:28:19 pm »
I know a guy that used a motor off of a 12volt backup sump pump with good results.
Offline bandmiller2
Re: debarker
« Reply #11 on: January 17, 2012, 08:26:55 pm »
Steve, what you really need is to see the woodmizer debarker and note the linkages and take a couple of measurements.There are alot of mizers in Va. Frank C.
Offline YellowHammer
Re: debarker
« Reply #12 on: January 17, 2012, 11:05:01 pm »
For me, the debarker upped my production significantly, but it's got joints, springs, linkages and adjustments that allow it to be aligned, adjusted for depth of cut/pressure, log diameter on the fly, and resist impact damage.  Lots of ways to make it work but I would expect a good bit of tinkering to get a homebuilt one optimized.  As suggested, seeing one in action would be key.
YH
People who say they can't, don't.
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660
Offline eastberkshirecustoms
Re: debarker
« Reply #13 on: January 17, 2012, 11:48:08 pm »
Here are a few photos of my debarker. It is still a work in progress....
Offline redbeard
Re: debarker
« Reply #14 on: January 18, 2012, 12:10:14 am »
Live edge slabs are becoming or coming back to popularity with woodworkers and artists, it  is a niche market and a debarker is a must for this type of cutting. Some buyers do complain about the groove it leaves and I have charged accordingly to those that dont want the debarke r groove in there slabs.
Offline bandmiller2
Re: debarker
« Reply #15 on: January 18, 2012, 06:35:44 am »
I've used a debarker alot when I ran the LT-70,it works well but I was glad to shut it off.My current debarker is an axe and wire brush,have no plans to build one of those complicated swinging buzzsaws. Frank C.
Re: debarker
« Reply #16 on: January 18, 2012, 08:24:59 pm »
hey all
hey bandmiller2 thats a good idea , i have a cousin that has a mill ( woodmizer) . next time i go  to visit mom im going to check it with some paper ,pencil,camera . if you going to do it dont play right ? ( without playing hard on the wallet)
  hey eastberk nice set up ,very clean work . i am heading towards a belt drive instead of buying motor . after checking on dc motors and prices and were they are made at ( china ) , i see belt and pulleys in my future lol
Offline Magicman
Re: debarker
« Reply #17 on: January 18, 2012, 08:32:23 pm »
Due to the vast range of movement that the Debarker has to make, there are very valid and practical reasons why sawmill manufacturers use a separate DC motor.
Online hackberry jake
Re: debarker
« Reply #18 on: January 18, 2012, 09:53:13 pm »
Why not a direct ac motor? Too fast? Too heavy? Or just trying to find something that will run off mill power?
EZ Boardwalk Jr. With 20hp Honda and 25' of track. 32x18 sawshed. 24x40 insulated shop. 30hp kubota with fel. 1978 Massey ferguson 230. Two stihl chainsaws. Woodmaster 718 and various other woodworking equipment. The tree gave its life to you, its your duty to make something beautiful out of it.
Re: debarker
« Reply #19 on: January 18, 2012, 10:02:22 pm »
hey hackberry
lol im just tight , na i want to try to set it up on its own power. the dc motors and  good ones are out of my range . but i am always checking craigslist ect .  i am retire so there are days that the only thing i can do is look up info .
everyone in here have been supportive just wanted to say thanks
Saw Anywhere!
