Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Timberjack 353 starter  (Read 842 times)
Offline rick f
Re: Timberjack 353 starter
« Reply #20 on: January 17, 2012, 05:33:26 pm »
Please send pictures along the way. :D
664 clark skidder
2- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
Offline Ed_K
« Reply #21 on: January 17, 2012, 06:08:11 pm »
I like the butter knife idea,going into the remember this book.
Ed K
Offline treefarmer87
« Reply #22 on: January 17, 2012, 06:11:09 pm »
my c5 is the same way. it isnt the easiest part to take off. like woody said a long extension and a twelve pt socket
Amazing wife
1987 chevy 7000
Prentice H knuckleboom with FEC sawbuck
1980's Treefarmer C6D
Sthil 460 racesaw
Husqvarna 455
Sthil 360
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #23 on: January 17, 2012, 06:36:31 pm »
I had wheel seal leaking on my C5, i was asking my dad how big a job it was to put new seals in.
NO-NO he says we'll try a butter knife first, i shook my head what ever. He went dug in his tool box and comes up with his special made butter knife. He got down, ran the knife around a few times, that should fix it, he said they get a piece of dirt and when it turns cold the seal gets hard and it leaks. [ hes 86 now]
I owned, 8  Homelite's  , 17 Husqvarna's, 6 Jonsered's,  12 Stihls, 2 Partners,  5 Skidders  4 trucks  3 crawlers 2 tractors
Offline John Woodworth
« Reply #24 on: January 17, 2012, 10:17:20 pm »
A combination of extensions will get you off, just loosen the lower enough to help you get the upper out and replace the same, on your wheel seal, be sure to get a speedy sleeve as well, it goes over the worn portion of the axle and gives you a new seal surface on the axle.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026
Offline madmari
« Reply #25 on: January 18, 2012, 06:30:46 am »
The original 12 pt bolt had been replaced with a hex-head and could not be removed with a socket. The only way to remove it was to take the starter motor apart while on the skidder. This leaves the starter mounting plate accessable. This worked pretty well, and had to have been the way the starter was put on last time.
  As far as the seal goes, I am going to try Lumberjack 48's trick today and then check the vent. This makes sense as the seal leaked a little some time back and then stopped. All of a sudden it's leaking again; consequently both times it's been during wild temp swings with frozen mud on everything.
  There's alot of knowledge on this forum- what a help! Thank you.
I know why dogs stick thier head out the car window.
Offline madmari
« Reply #26 on: January 20, 2012, 08:10:05 pm »
Got the starter rebuilt for $65- new solenoid. Put the bolts back in the right way :). 5 degrees this morning, spun and started like summertime. No ether, turned like three rpm and varoom!!! All along I thought the batteries were weak but not so.
  I tried the butterknife trick and cleaned the axle vent on the rear wheel seal. See tommorow morning if that worked- thanks for sharing Lumberjack48 and all those that helped out.
Little victories!!!!
Saw Anywhere!
