Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Best Chain for large bucking?  (Read 953 times)
Offline Richard Karwowski
« on: January 13, 2012, 10:51:54 pm »
My first post.
I volunteered to help out a local camp cut up some fallen trees after last winter's heavy snowfall. Took my trusty 025 Stihl and upon seeing some 60" fallen black oaks decided I needed a bigger saw. Now have a Stihl 660. Have cut for hours with it and am using the chain it came with, sharpened over and over...
   The question I have is what would be the fastest cutting chain? Don't care about the smoothness of the cut, just want to make max use of my time in cutting. It's all split for firewood...
Offline Clam77
Re: Best Chain for large bucking?
« Reply #1 on: January 13, 2012, 10:54:34 pm »
Maybe .404 half-skip...
The pros would be better able to answer..
Andy
Stihl 009, 028, 038, 041, MS362
Mac 3-25
Online T Welsh
  • Woodmizer LT-40-HD and a whole lot of toys!
    • Welsh Tree Service
« Reply #2 on: January 14, 2012, 04:52:37 am »
Richard Karwowski, Welcome to the forum! as for your 660. Stihl  33 RSC or RSK full comp chisel chain or Oregon 72LGX is what we run on our bars over 36". but keep the chain off the ground and out of the dirt,chisel chain will dull fast when hit with a rock or dirt and take about a half hour to sharpen a 36" or longer bar. Tim
Offline Al_Smith
« Reply #3 on: January 14, 2012, 06:40:01 am »
It's all a preference and often debated .Myself I prefer 3/8" chisel for saws under 100 cc and .404 chisel  for saws over 100 cc .
One might also take note that it's a lot easier to maintain a sharp chain by filing before it gets dull as opposed to spending a half an hour reworking one that got dull .
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #4 on: January 14, 2012, 08:09:26 am »
Welcome to the Forestry Forum Richard Karwowski.  Your saw probably came with a "green link" anti-kickback chain.  The guys on here suggested that I use a "yellow link" chain, and I have been very pleased with the way it cuts.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline thecfarm
« Reply #5 on: January 14, 2012, 08:41:15 am »
MM,Would it come with a chain like that on a saw that size? I have never seen a chain like that. I saw a picture of one on here,but never at a dealer. I don't look at the small saws anyways,but thought a 660 was good size saw.
Richard welcome to the forum.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline Magicman
« Reply #6 on: January 14, 2012, 08:53:16 am »
I was thinking smaller saw, but he was not pleased with the cutting speed of the original chain.  A quick look should tell.
Offline Al_Smith
« Reply #7 on: January 14, 2012, 08:54:19 am »
If that thing came with semi chisel anti kick back chain ,just use it up until it's all gone then replace it .The stuff  cuts okay it's just not as fast as chisel .
On the other hand you could hang to old loop on a nail to use as a "stumper " to save the better cutting chain should the occasion arrive to cut a stump .
Offline Al_Smith
« Reply #8 on: January 14, 2012, 09:00:21 am »
Often in conversation about 36" loops the comparisson of skip,semi skp or full comp comes up .
From my perspective which is strictly northern hardwoods I've found very little difference .Now maybe on the left coast in the pine,spruce and fir trees there is .
I kinda figure they all cost about the same as far as price per driver so you'd just as well get all the cutters to begin with .
Now if you're trying to run a long bar on a smaller saw there might be a difference  but unless that 066 is a wimp it will pull it no matter what it is .
« Reply #9 on: January 14, 2012, 02:27:41 pm »
Wow! Thanks for the great responses!
Think I'll just try different chains as suggested. When cutting pine seems I can do a whole tree w/o stopping to sharpen but find the black oak dulls the chain fairly quickly. Still developing a feel for when to stop and sharpen.
Thanks everyone!
Offline beenthere
  • EIEIO
« Reply #10 on: January 14, 2012, 02:51:04 pm »
I sharpen at minimum every tank of fuel. Usually just needs a touchup. More often if the tip ever hits into the dirt. You will notice an immediate change in the cutting then.
If the chain doesn't drop through the log without any force, then it needs sharpening.
Over time, you will become very familiar with that change from cutting good to mediocre. But it all has to start with a sharp chain, cause there isn't much change in performance from a dull chain to a more-dull chain. :)
Offline chevytaHOE5674
« Reply #11 on: January 14, 2012, 03:26:55 pm »
If the wood is nice and clean you can use square filed chain (Oregon CL series and I forget what Stihls square is). I have a few loops that I use on clean wood and boy does it cut, but takes some experience and a flat file to get it sharpened correctly (grinder is best). But if the wood is dirty or ever close to the ground I use round filed full or semi chisel chain.
Offline shelbycharger400
  • m14/04 0
« Reply #12 on: January 14, 2012, 08:06:40 pm »
i sharpen all my chisel chain with a round stone.  it dosnt cut as fast as square ground.  I cut A LOT of dirty wood, in flood plains and such.  I bring atleast 2 saws with, nothing worse than cutting then cant finish the truckload cause a dull chain.  i use a dremel, its not perfect, but i test cut before i leave the house then touch up and go.
Offline DebarKing
  • Gimme that saw!!!
« Reply #13 on: January 15, 2012, 10:51:53 am »
What size bar did you buy your 660 with? i got my 362 with the 25" bar and both the bar and chain were "yellow". Im sure that also has to do with your dealer's inventory as well. The 33 RSC seems to work pretty good in any clean wood, until you saw through that one random shotgun slug >:( :D
Nick
Stihl MS 362
Stihl FS 55 Trimmer
Stihl 036 Pro Saw
Stihl MS 660 Magnum (Work Saw)
One MEAN Dodge Dakota
  • m14/04 0
« Reply #14 on: January 15, 2012, 11:12:19 am »
full chisel runs awsome until you run into a hollow log filled with dirt..
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #15 on: January 15, 2012, 03:19:31 pm »
Welcome to the Forum Richard  ;D  What I'm not understanding is not being able to tell when the chain starts getting dual. You should be able to feel emediately  when you lose the edge on the chain.
  Over 30 yrs of hand filing I've tried about every way to get the best performance out of a chain in hard wood and soft wood. How much angle, pitch, a cutter should have and how low the rakers should be. Over all these yrs i never had a chain on a grinder. When i put a new chain on it didn't come off the saw on till it had to be shortened or threw away. I've cut wood so dirtying on the landing i used a chain every day.
  When cutting hardwood you want to keep the chain speed at peak rpm, you want that 66 throwing chips 20', working the throttle just like the Monster trucks do.
  Use a Full Chisel chain, filed at 40 degree angle, 10 degree pitch, with a 5/32 file, rakers 35 Thou, 30 degree slope on rakers. When this is all done right it will cut that Oak like hot butter.
I get excited thinking about it, i wish i was there to give you a hand.
Back when i bought a new saw, the Dealer couldn't put a Chisel chain on it because of liability. He'd hand me the chisel chain and I'd have to change it.
I owned, 8  Homelite's  , 17 Husqvarna's, 6 Jonsered's,  12 Stihls, 2 Partners,  5 Skidders  4 trucks  3 crawlers 2 tractors
Offline Al_Smith
« Reply #16 on: January 15, 2012, 04:06:46 pm »
 FWIW those Dremels are okay if you rock a chain but IMO it's far better to just use a file unless the chain has been damaged .
For less than ten bucks you can buy an Oregon file guide which comes with a file or two plus the instructions and if you follow them you can't miss .
If you're not up to speed on filing that will get you the basics and be just as sharp as a grinder too boot .If you want to get fancy and free hand file you can catch that train after you ride this one a while .
Offline islandlogger
    • www.independentlogging.webs.com
« Reply #17 on: January 15, 2012, 10:23:05 pm »
I'd follow lumberjack48's advice...he's been there and done that and knows his stuff. I wish I could get him together with a old logger I learnt off of, they talk the same lingo and bet they would swap lies and half truths till the crack of dawn and hit it off real well...
Yeah, chain off the shelf will cut, but chain off the shelf with a bit of modification will REALLY cut!!
islandlogger
Offline Al_Smith
« Reply #18 on: January 16, 2012, 12:43:14 am »
That cut really good thing  is something you only learn after you've "been around the horn " so to speak .
« Reply #19 on: January 16, 2012, 05:06:54 am »
I want to thank everyone for their input based on experiance. Obviously I have much to learn! I use a 36" bar on the 660. The last time I was cutting there I pretty much had the bar totally buried all day in the oak. I wrote Stihl about it and they sent me a hat! Need to read up on some of the terminology to fully understand everything thats been said here!
   The wood has a sweet gum smell when cut. One log had a black ooze flowing out after I cut near the base. It was tens of thousands of black ants! Now I know where they go when it snows!
   I'll try to post a couple of pictures if I can figure it out.
   Once again thanks everyone for this novice!
Saw Anywhere!
