Get your Forestry Forum Hats while they last!
I would put a quart of transmission fluid in the fuel tank and run it through. Sounds like the pump to me too.
What will the addition of mix or tranny fluid do
Quote from: Corley5 on January 14, 2012, 10:43:46 amWhat will the addition of mix or tranny fluid do Provide some lubrication to the injection system parts, todays diesel fuel is considered very dry. The addition of biodiesel will also help, but not in this cold weather as it must be heated to disperse through the fuel.From what little I know about Duetz engines, it looks like they have a direct injection pump with a mechanical governor included. I suspect the governor is sticking and that is a somewhat common problem in some injection pumps. Check out this web site for parts. http://deutzpartsdirect.com/ beat me to it... yes will help lube up all of the injection system also free & remove deposits in the pup system. seem to think about it about time for a little in my tractor Mark
The 4 cyl Deutz in my C4 forwarder started smoking a few days ago. The smoke is blue/white to black and smells of raw fuel. It's not using or gaining oil in the crankcase. It is low on power and misses now and then but not constantly. Engine oil pressure is a constant 75lbs. Running the loader with the throttle set it runs fine, no smoke, no miss. It idles fine and starts good as it always has. The problem manifests itself when the machine is moving with the engine load changing. It almost seems like it's loading up on fuel I changed the fuel filters a few weeks ago before the problem started and always run clean fuel. My transfer tank has a filter on it and I use Sea Foam on a regular basis. Air filter is fine too. I'm thinking it may be a bad injector Hopefully not the injector pump. Any ideas
